Results 1 to 16 of 16
    May 21 2007
    Nashua, NH
    New to Stage 3!!
    Well, sort of.
    I just finished putting in my GIAC Stage 3- software, 5 bar fpr, and Hitachi MAF. The car is faster than I expected and throttle response is great. I love the feeling of 17psi! Now I can't wait till I can finally go full stage 3 and be up around 400whp.
    Only problem is a little sputering or hesitation around 3300 rpm. I think I need to change the plugs and put a smaller gap on them. Does anyone know what the correct plug gap should be?
    Veteran Member Four Rings Quattrocket's Avatar
    Sep 02 2004
    2001 Audi S4
    Guelph, Ontario
    Re: New to Stage 3!!
    I believe most people are running at .028.
    MITCH
    "Audis are like strippers. They only work when you throw money at them."
    FORGE MOTORSPORT DVs*K04 TURBOS*034 TURBO INLETS*STAGE 3 SOUTHBEND CLUTCH(MANGLED PP MOD)*
    Active Member Four Rings RogueStatus's Avatar
    Nov 13 2007
    B5 S4 Avant
    Boston
    Quote Originally Posted by Quattrocket View Post
    thats what i hear...stock is .032 i think
    Jan 25 2006
    A4 2.0T
    MD
    What turbo?
    Senior Member Two Rings Allaidback's Avatar
    May 23 2008
    Columbia, SC
    what plugs are you going with and are you going to change out the coil packs too?
    Sep 27 2007
    00 S4 6sp, 06 Mazda3 HB Auto
    Columbia, SC
    is 17psi the normal Stg 3 boost?
    What if I wanted a boost setting at 15psi or so (maybe better longevity on the turbos).
    I'm contemplating going that route (got the turbos, thinking on what to do next) but with slightly lower boost.
    00 B5 S4 - K04, Stern Soft MM, Stern Snub, DTS, Neuspeed Rear Sway, Oinkies, GIAC stg 2 XR, Vogtland GT, SSAC copy. Soo... Stg 2.31456?
    06 Mazda3 - Wife's car and autox car
    96 Eclipse GSX - Gone
    03 Acura CL Type S - Gone
    96 Soarer GT - Gone
    93 RX7 R1 - Gone and missing her
    Jun 14 2007
    2000 S4
    Connecticut
    Quote Originally Posted by Dimcorner View Post
    no, however 17PSI on Stage 3- (K04 turbo upgrade on stock fueling) with upgraded FPR is normal...If you go too much higher you will lean out the motor because your injectors on 3- are being maxed out....
    I was stage 3- for 5 months with VAST... only downside to 3- is the 5 bar FPR can stress your stock fuel pump to its limits and sometimes cause them to die early. Some threads on AW show that....
    Typically a stage 3 file will hit 22-24/25 PSI and taper to 20-22 depending on file and location... Someone with pump 93 can hit 24 psi with K04s, which is right around the top of their effienciency range. Running lower boost *wont nessasarily* help the longevity, what will is proper care, which is NOT hitting any boost until oil temps are up around 175-200 minimum and obviously the water temps as well. At the time your oil is up there your coolant is too. And then after a few pulls or whatever you do, staying out of boost the last mile or so from shutdown and then a 30second idle will help not create gunky oil buildup @ the turbo
    May 21 2007
    Nashua, NH
    Well I was told I can just change the plugs to see if that is the problem with the sputering. As far as I know the coils are good and do not need to be changed. I'm new to working on my S4...are spark plugs a difficult task to handle?
    Veteran Member Three Rings Calif_Kid's Avatar
    Oct 14 2006
    2001 A6 6 spd, 2001.5 AWE stage3 Nogaro 6-speed (sold), 2000 Honda Civic racecar (sold)
    Sunnyvale, Calif
    Changing the spark plugs is pretty easy - just takes a little time and patience. There is a good write up at http://www.audiworld.com/tech/eng.html with the article around 3/4 the way down the page in the A6,allroad section labeled 'Spark Plug Swap (C5, 2.7t)'. I usually just take the whole airbox out instead of just the top half. You will just need to figure out what plugs to use - SFTA as there are different opinions on what plugs are best for the various stages. - Jim (Calif_Kid)
    Senior Member Two Rings SpoolPastYou's Avatar
    Jul 15 2008
    Miami
    it sounds like a gapping issue, change the plugs, my guess is run the coldest plugs you can get...like audisport said, never hit boost, if you have a gauge this is actually very easy to do...these cars have ALOT of torque, so getting through revs without going into boost is real easy..sometimes ill drive the car for a few days without ever bringing it into boost...or anything past a feathered 5lbs (on accident) i ran a 00 turbo si on a stock block for over a year...stock bottom ends on a honda with good tunes shouldnt see anything over 12psi..my tune was awesome but the WG spring i had in it would spike to 16lbs...16lbs on a stock honda block 10.1:1 compression! but the tune was awesome and i warmed it up and cooled it down 5min for both no matter what and i never hit boost unless i was racing..as a matter of fact the car never even over heated and it was on a stock radiator and it made 317 whp to the crank...loved that car
    Registered Member Three Rings updaboost's Avatar
    Mar 08 2006
    S4, 997 4S & S2000
    Chicago
    Are you at 400whp yet??
    01.5 Nogaro Blue S4, 6sp
    VAST Stage 3 - Piggies - Neuspeed - RS4 Clutch - Samco - Hyperboost DVs - AMS TBB - Stratmosphere SS - Flik Justice/SSR Comps - Vogtland - AWE DTS - H-Sport Sway
    360whp/400wtq
    May 21 2007
    Nashua, NH
    I heard that the stock plugs are best. Someone said that platinum plugs don't seem to respond well to boost? So the plugs should be gaped @ .28?
    Veteran Member Four Rings SLC_S4's Avatar
    Jul 15 2007
    2001.5 S4
    Utah
    Quote Originally Posted by Grinster24 View Post
    Try out some bosch F5DPOR side fire plugs. They're pre-gapped. I put them in a little over a week ago and love them. I'm APR stage 3
    -Seth
    APR Stage 3 - APR Stealth exhaust - APR downpipes - APR Bipipe - APR snub mount - AWE side mount intercoolers - AWE LWFW - RS4 clutch - ITG panel filter - JHM Shifter - Startup Racing Vogtland GT coilovers - Stern adjustable control arms - Fiber Images vented carbon fiber hood - Fiber Images carbon fiber fenders - Recaro Style Topline seats - A bunch of other stuff I can't remember
    Veteran Member Three Rings Rajan147's Avatar
    Nov 23 2007
    Columbus, OH
    what kind of longevity out of the FireSides? Copper need to be changed about every oil change but they are cheap compared to the firesides.
    although i probably could have searched for this data.
    B5 S4 AWE Stage 3 - sold
    Jul 15 2007
    2001.5 S4
    Utah
    They're a platin plug.....I'd say longevity should be about 50k miles. Someone correct me if I'm wrong
    -Seth
    May 21 2007
    Nashua, NH
    Well I was thinking of going with NGK BKR7E's but no one has them in stock. There is only one place local that carries the Bosch F5DPOR's and they are $12 a plug!?
    However I was told I need the plugs gapped @ .28 yet the pregapped ones everyone is saying to get are gapped stock @ .32? Any help. Thanks
