    Veteran Member Four Rings nikkobdenis's Avatar
    Oct 24 2007
    SLC, UT
    Puddle of water after wash!?!?!
    Took my car to a new car wash near my house today. The kind you pay, then drive your car in yourself. I was not paying close attention in the wash. Got to the end and got out so they could vacuum it. The manager walked over to me and asked if I have ever had a problem with water leaking into my car? No, I have not. About an inch of water puddled into my passenger floor!!! I looked everywhere and I have no idea where it could have come from! You guys have any ideas?
    Oh... And now my car does not beep when I lock my doors? i have checked to make sure all doors are closed tight, and windows up. Could that have anything to do with the water getting into my car?
    Thanks in advance
    Veteran Member Four Rings AMC's Avatar
    Jun 15 2007
    '19 Spektrum Golf RS, '18 Audi TTRS
    Re: Puddle of water after wash!?!?!
    have a sunroof? could be your sunroof drain and needs to be cleaned out, i was having issues with my s4 and ended up being the wire goin from the battery to the sub (shop forgot to seal it in the firewall) and it ended up leaking up to an inch in the driverside for a year before i found it
    clean out your car have some1 pourwater around the passenger side and check to see if its leaking anywhere
    Driver Supply
    Current
    '19 Spektrum Golf RS DAZA
    '18 Audi TTRS
    Sold
    '07 Stage 3 2.7t swapped B7 A4
    '01.5 Stage 63463 Silver S4
    '13 black Audi S7
    '03 Porsche 911T
    Senior Member Three Rings G-Bus's Avatar
    Aug 25 2008
    Montreal, Canada
    On 2002s there was a recall on the drains because they used to get clogged very fast and therefore leak inside the car. Call your dealer and see if it was done.
    Oct 24 2007
    SLC, UT
    Awesome! I'll call the dealership first thing in the morning! Thanks
    Veteran Member Four Rings supamannn99's Avatar
    Nov 15 2007
    Orange County, SoCal
    maybe they left a window open and tried to cover it up
