Results 1 to 17 of 17
    Veteran Member Four Rings EUROaleksey's Avatar
    Aug 10 2007
    Toronto, Ontario
    Just quickly tell me which one and thats it! :)
    I have an almost completely stock engine.... GFB Hybrid valve, full 2.5" catless mufflerless exhaust, LLTEK air intake + matts heat shield... all that on a stock KO3 setup...
    i wanna get a turbo hose... there are few, but im not sure which one to buy since there were a lot of discussions about fitment issues and numbers of holes...
    can u guys please just tell me real quick which one i have to get?..
    thanks!
    Dec 06 2007
    Re: Just quickly tell me which one and thats it! :)
    neuspeed xtreme
    -Kirk
    BetaAlphaTau Member #58
    Veteran Member Three Rings davidlizard's Avatar
    May 01 2008
    2004 A4 ultrasport 6speed
    Winter
    Quote Originally Posted by AudiA4Turbo22 View Post
    neuspeed xtreme
    +1
    the APR TIP is missing one hole and an other is to tight to connect the hose...
    Go with the Neuspedd extreme!!
    Unitronic stage 2+ / Borg Warner K04 / Milltek / ATP 3" testpipe / Racetec FMIC / Forge TIP / Carbonio / Forge DV / 386cc / 034 25mm rear sway /Joey moded / Podi / JHM 350mm BBK & SS lines / STaSIS street sport/ Michelin Pilot Super Sport / ECS Tuning lightweight flywheel + RA4 clutch kit /
    034 engine & trans mounts / 034 snub mount / 034 front & rear link / Apikol rear diff mount / JHM solid short shifter
    Veteran Member Four Rings Arclight's Avatar
    Dec 20 2006
    8VS3
    Forge is fine as well. I have the APR but DON'T recommend it as it requires a complete reworking to fit properly...
    For Sale: HRE 501s, 19 X 8.5 and 19 X 9.5
    Aug 10 2007
    Toronto, Ontario
    thank u guys :) it doesnt depend on a year B6 does it?... mine is 02..
    so extreme is better than forge..?
    Veteran Member Four Rings Condo's Avatar
    Jan 30 2007
    2001 S4 Avant
    Cincinnati, OH
    APR will work just fine on an 02.
    Veteran Member Four Rings jrau13's Avatar
    Mar 12 2006
    02 Mercedes ML, 04 Avant 1.8t
    Costa Mesa
    Forge FTW!!!
    Cheaper than NS and, well if you don't plan on going BT then its perfect.
    I'll keep my money,
    My Guns, My Freedom,
    & you can keep the CHANGE
    Veteran Member Three Rings phantom b6's Avatar
    Apr 02 2008
    LA
    I had to re-run all my vacuum lines for APR
    Jan 30 2007
    2001 S4 Avant
    Cincinnati, OH
    Quote Originally Posted by phantom b6 View Post
    What year is your car? You don't need to change anything to use the APR TIP on a 2002 A4.
    Aug 10 2007
    Toronto, Ontario
    shit if u guys say that APR will fit fine on my 02 - then ill just go with that, its only 160$... unless Forge is way better...? extreme is too expensive..
    where do i get forge from anyways? ive looked at 4 sites - they dont have em :( apr is for a good price at esctuning..
    let me know guys, thanks
    Veteran Member Four Rings HTA A4's Avatar
    Jul 11 2008
    2002 1.9L HTA3076R A4
    Illinois
    I have an APR TIP that I need to sell. I bought it and never got a chance to put it in and now I'm going BT so I went with the Neuspeed.
    Anthony
    Eurocode Tuning | fifteen52 | Speed Freaks Fabrication
    BetaAlphaTau Member #41
    Jan 30 2007
    2001 S4 Avant
    Cincinnati, OH
    The APR only has issues on the 2003.5 and later A4. I had one on my 2002 last year and it worked perfectly.
    Aug 10 2007
    Toronto, Ontario
    but is APR much worse compared to forge and extreme?... airflow-wise or something?... or is extreme only more expensive becase it has adaptors to bt?
    Jan 30 2007
    2001 S4 Avant
    Cincinnati, OH
    The Neuspeed is larger and flows more but it's overkill for a K03/K04. APR should flow the same as the Forge TIP.
    Registered Member Two Rings zims666's Avatar
    Apr 17 2008
    '05 A4 B6 1.8t 6speed
    Chapel Hill, NC
    link to Forge Tip:
    clicky
    Veteran Member Four Rings Groove1797's Avatar
    Apr 08 2004
    Your mom on a unicycle
    Eating Cheese Curds
    The Apr is a pain in the ass for 03.5 and up but they are fine on the 02's. The APR has an internal wire that adds to the silicon's rigidity to prevent collapse. I would personally get the APR since you are only ko3 unless you are planning to go BT in the future.
    4Runner, Rs5 and Alfa Guilia QV
    Mar 12 2006
    Costa Mesa
    I'll keep my money,
