Results 1 to 5 of 5
    2003 A4 1.8TQM
    Markham, Ontario
    Brake Question - Rotor sizes
    Just a quick question on rotor sizes. I've checked the FAQs, and it states the fronts for a B5 S4 are 321mm dia, while the B7 A4 are 320mm dia.
    I'm assuming that a 1mm difference isn't really important, (seeing as they are going on a B6 A4) but would like confirmation - especially when the B5 S4 rotors can be had for less $$$ (from Adam's rotor buy thread)
    TIA,
    Nick
    Veteran Member Four Rings pondside36's Avatar
    Feb 15 2008
    AWE powered B6 1.8T
    Severna Park, MD
    Re: Brake Question - Rotor sizes
    You need to buy the rotors that match your calipers..shoot adam a pm and he'll hook you up, I bought mine for $300 for all four
    Goodwood Green is money...$$$$
    Arclight "You need to post pics already Pondside - enough w/ the prom dress teaser BS!"
    Veteran Member Four Rings akaEsCo01's Avatar
    Dec 08 2006
    Jersey
    IIRC the B5 S4 rotors are also thicker so they would not work with the B6 caliper
    2003 A4 1.8TQM
    Markham, Ontario
    Hmm - now I'm confused. Per the FAQ, the B5 S4 is 321mm x 30mm, while the B7 A4 is 320mm x 30mm - I would have thought that they would have been interchangeable, as the caliper would only be .5mm off.
    Does anyone know for sure?
    2003 A4 1.8TQM
    Markham, Ontario
    Now I'm even more confused....
    Checking the ECS website, they state both the B5 S4 fronts and B7 A4 fronts are 321mm x 30mm...
    So, if that's true, the same rotors will work with either the B5 S4 or B7 A4 calipers....
    Secondly, which is the prefered caliper between the two? The FAQ states the B7 A4 is prefered - is this due to the B5 S4 HP2 calipers being larger, and having the 4 pad / 2 piston set up? Or is it something else??
    Anyone? Help!!!
