    Mar 24 2008
    chicago
    1998 audi a4 2.8 100k miles P0302, Ginding Noise When I Turn to Left
    On my Audi I just bought the car knowing it needed a new transmission. I bought it and fixed the transmission. It had a check engine light before i fixed the transmission P0302. Then I found out it needed a new battery. So i replaced that. And I still get P0302 which I know is Cylinder 2 misfire. Could the battery have caused this? Other than plugs/wires what else can it be?
    Also, not sure if this is related,when i turn left the wheel feels tight and it feels like it is grinding on something.
    The brakes and rotors and tires are all pretty new.
    Any ideas on either of these two issues?
    Veteran Member Three Rings GetAwayFromMe's Avatar
    Jan 03 2008
    One million dollars all in pennies
    Iowa
    Re: 1998 audi a4 2.8 100k miles P0302, Ginding Noise When I Turn to Left
    I would check the plugs and see in what condition they are. Swap the wires from cyl 2 to ?? and see what happens. If you still get the misfire code than next thing would be the coil to check. If that doesn't do it than you might be in some shit. As far as the grinding noise for your tires i would check the tie rod ends and your steering rack.
    Established Member Two Rings Sobo's Avatar
    May 14 2008
    S4
    east aurora
    NGK plugs fixed my misfire problems.
    Bosch's sucked and i had serious misfire problems.
    2000 S4.
    Jul 28 2008
    Everywhere
    Say your plugs and coils are replaced and you still get the misfire in cylinder 2, what wouls the problem be?
    Thanks
    Jan 03 2008
    Iowa
    Did you check the spark plug cable? I have also seen a plug crack and cause problems. Next thing would be a blown headgasket/ cracked exhaust valve. Did you try swaping cables and plugs like i mentioned earlier?
