Results 1 to 18 of 18
Thread: new member
    Aug 27 2008
    lincoln nebraska
    new member
    hi everyone, name is kelvin living in lincoln nebraska and ive got an 02 audi a6 2.7t with tiptronic. 86k miles and its my daily driver right now. im no expert on these cars, but i love the look and the modifications ive read about that i can do to it. right now its stock, but it needs some maintenence before anything. exterior i plan on a spoiler (rs6?) smoked taillights, and some headlights that are not foggy. for performance i was looking at a giac or apr engine chip, along with a giac transmission chip. for wheels i have not decided, but im open to suggestions.
    ive also got some side projects other then this that im currently working on. first off i have a 1994 eclipse gsx that is in the process of becoming a drag car. its almost done and should hopefully be around 6-700whp, high 9 car trapping around 140mph. i also have a 1969 baja bug thats on hold becuase the dual port 1600 decided to blow a piston through the case.
    here are a few pictures of my audi that ive taken in the past few days. im no expert at taking pictures as you can see :)
    Veteran Member Four Rings audirs's Avatar
    Mar 22 2005
    Kitchener, Ontario
    Re: new member
    the stock bbs' look pretty nice painted, although that first pic it doesnt look like your car has any wheels at all lol.
    welcome and happy modding
    Q5 3.0T S-line
    VW Tiguan R-Line
    A6 2.7T AWE Stage 3
    Coupe Quattro
    Veteran Member Three Rings Kemer1's Avatar
    Aug 26 2008
    05 Audi A6 3.2 Quattro
    Sin City
    Re: new member
    Welcome aboard. That a pretty well kept little stocker.
    Veteran Member Four Rings wofman's Avatar
    Apr 01 2008
    2010 Jetta TDI
    Re: new member
    You're in for a treat (but how much HP in Eclipse? whew!). And as you'll hear from all on this forum you need to do timing belt and water pump. And while at it maybe look into down pipe changes along with your GIAC chip(s). Gigi has similar GIAC modded tiptronic. Minor other changes go with chip - diverters, for example.
    Looks like sport suspension on 17s or 18s?
    Exterior is another story and 5 guys will give you six suggestions. Not sure what to make of the rims (too much black for me), but if you're doing stark black/white, change grille, debadge rear and put on black rings, presumably clear corners on headlights (?). All very cheap. Smoked tails to match rear license plate surround looks nice on light color C5s.
    How "foggy" are your headlights? I'm looking for a used set.
    Enjoy!
    wofman
    Nothing going to bring it back: 2000 C5 2.7T 6sp MT
    Ming Blue, S6 Blades, EuroSpoiler,
    GIAC-93, AWE DPs to Milltek Catback,
    RS4 Clutch, JHM DT-Stabilizer, VAST Short-Shifter,
    H&R Sways, Eibach Pro-kit, Bilstein Sport Shocks, etc., ...
    NOW: '10 Jetta TDI w 6MT, Revo Tune Commuter Car
    Aug 27 2008
    lincoln nebraska
    Re: new member
    stock suspension, it must be how the car sits? tires are 245/45/17s if that tells you anything. i havent tried sanding the headlights yet, but the meguiars plastix didnt do much at all. the driver side headlight cleared up alittle, but the passenger has alot of debris in it, so i think the seal is broken or something might be wrong with it (condensation accumulates)
    when i do decide to modify, i was looking at putting it all on at the same time. ecu chip, tranny chip, diverters and upgraded charge pipe. exhaust wise i havent found much other then the rs6 exhaust, but i cant find that anywhere. any suggestions?
    Apr 01 2008
    2010 Jetta TDI
    Re: new member
    Search threads in A6 forum -- quite a bit on this. APR, AWE, ESP, VAST have downpipes and/or catbacks. Some guys use Magnaflow components and less expensive custom pipes with local installation (see Endee). I just have gutted piggies then original. One issue is "free-flow" cats vs. pipes, of course (and related O-2 sensors, check engine lights, emissions & inspections); the others are sound/performamce (mostly the former if gutted or free-flows are in place). And no, our exhausts are not same as S4 2.7s. And I'm not sure if your tip is even same exhaust set-up as my manual (Daft is expert on all that is engineering around here -- I can only pass on what I absorbed in last several months with my "new" C5 6sp)
    Condensation = seal problem. I'm appalled at price of new ones. You have to buy the whole enchilada. Hence my pouncing on you your first day on forum.
    There are different "stock" suspensions. Your stock is a lot lower than mine was, so I presume you may have "sport" stock suspension. Folks here gently laughed at my "stock". Neighborhood dogs used to be sleeping on my wheels when I came out in mornings.
    wofman
    Veteran Member Three Rings 04A6SLine's Avatar
    Oct 16 2007
    Brooklyn NY
    Re: new member
    awesome pictures... very nice.. i think you and frank will get along here..
    Veteran Member Four Rings FrankA6's Avatar
    Mar 30 2008
    2004 A6 2.7T, 2012 Volvo S60 R-Design
    Pittsburgh
    Re: new member
    Quote Originally Posted by 04A6SLine View Post
    Me? because im a picture slut? lol i do have alot new pictures, and i ordered my 18" winter wheels with spacers so theres even more to come lol, anyways welcome.
    2004 Audi A6 2.7T
    Apr 01 2008
    2010 Jetta TDI
    Re: new member
    Frank -- I guess I missed your winter wheel decision while away -- what did you decide (and why no accompanying image with your post here?)
    Veteran Member Three Rings onewicked's Avatar
    Sep 25 2007
    2001 A6 2.7t
    Dirty Jersey
    Re: new member
    Looks good......
    2001 Audi A6 2.7t
    THE C5 UNION
    Past cars:
    1998 BMW 528i Sport
    1995 Eagle talon TSI w/ 6bolt swap(for sale)
    1996 VW jetta VR6
    1998 VW jetta 2.0 Turbo
    AMS AUTOWERKS #1
    Senior Member Three Rings GhostSquadGarage's Avatar
    Jul 05 2008
    SLR32 \ IS300
    Re: new member
    Lovin It Man !!! Loovvveee Innnnn It !
    Established Member Two Rings EnviedA6's Avatar
    May 06 2008
    Minneapolis, MN
    Re: new member
    Wow, looks almost like mine when I first picked it up except my BBS's weren't painted black. Clean car!!!
    Envied A6
    2001 Silver Audi A6 2.7T Tiptronic, APR Stage 2 chip, Blitz custom intake, Dynomax Turbo custom exhaust, Custom down pipes, Turbosmart MBC, Carbon Fiber interior trim, arm rest, engine cover, air box cover, hood,trunk, mirrors, B pillars, eyebrows,Tinted tails & side markers, H&R lowering springs, H&R 5mm and 10mm wheel spacers, 19x9 Konig Next wheels, 245/35/19 Toyo Proxeys 4
    Feb 13 2008
    Re: new member
    welcome aboard. enjoy the ride. there's lots of good info and people here in the a6 forum.
    Aug 08 2008
    1970 Porsche 914 2.0
    Washington
    Re: new member
    did you paint the wheels yourself or did you have someone coat them?
    Veteran Member Four Rings Stampy's Avatar
    Oct 02 2007
    A6, A8, X5, etc
    Windy City
    Re: new member
    Can't go wrong with Taco Bell !
    Village Idiot!!!
    (\__/)
    (")_(")
    lots of rings in my garage
    Mar 22 2005
    Kitchener, Ontario
    Re: new member
    ^^ lol whats with the pink writing.
    Q5 3.0T S-line
    VW Tiguan R-Line
    A6 2.7T AWE Stage 3
    Coupe Quattro
    Aug 27 2008
    lincoln nebraska
    Re: new member
    i did them myself, no prep work at all so up close they suck. im looking for some workmeister wheels, does anyone sell them here?
    Jul 05 2008
    SLR32 \ IS300
    Re: new member
    Talk to this guy on Ebay
    http://cgi.ebay.com/ebaymotors/_Car-...4506.m20.l1116
    He imports directly from Japan so you can tell him what you want and when he finds it will get it over here for you at a almost unbeatable price.
    He can find the rarist stuff and I've dealt with him many times before, he's good people.
