Results 1 to 3 of 3
    Active Member Two Rings Racer Doc's Avatar
    Jan 31 2007
    Need tire size advice for my 2001 S4
    My S4 has a H&R suspension and RS4 replica Wheels with the following specs:
    Diameter - 18"
    Width - 8.5"
    Offset - ET38
    PCD - 5x112
    Weight - 26.5lbs
    Centerbore - 57.1mm
    Lug Bolts - 14x1.5 27mm R13 Ball Seat
    I am looking for an aggressive but would like to avoid tire rub for my daily driver.
    What tire size would you guys recommend
    Deactivated Four Rings
    Oct 06 2006
    South Bend, IN
    Re: Need tire size advice for my 2001 S4
    245/35R18
    Jun 14 2005
    Anaheim, CA
    Try a small spacer if your looking to save money on tires.
    -Charles@VMRWheels
    www.vmrwheels.com
    Brandon @ VMR Wheels
