Results 1 to 4 of 4
Thread: wiper motors
    Senior Member Two Rings NYCS4Avant's Avatar
    Apr 23 2008
    B6 S4 Thunder Wagon
    wiper motors
    Since picking up my car in April, my wipers have always had a mind of their own. Most recently however, they can't make a full pass of the windshield. No matter what setting I try on the stalk, the wipers get stuck. The only fix is to get out of the car and manually push the the wipers and the lever at the same time. Anyone else experienced this before? Wiper motors gone bad?
    B6 S4 Avant: Nogaro / JHM Tuned/ Piggied / Milltek Non-Res / JHM SS Trio / Hardwired V1 / SS Brake Lines / CC Mod / Stern Snub / LED License Plate / 18" TSW Vengeance / 20% Tint / DIY Blackout Grill / Black Window Trim / Thule Bike-Ski-Fishing Pole Rack / Full Timing Chain at 68k oh wel...
    Active Member One Ring benstohlen's Avatar
    May 10 2008
    NOVA
    Re: wiper motors
    Yes, i just recently experienced the same problem. I originally thought it was the wiper motor to, however upon further investigation it turned out to be the wiper (track)that the the wiper arms connect to. The problem with it is that the pivots on the (track) are not sealed very good so when water gets down in there they rust and seize up.
    Senior Member Two Rings lmmike's Avatar
    Jan 03 2007
    N/A
    KC / STL
    Re: wiper motors
    I have an 05s4, mine just did this a month ago. It was the wiper arms between the blades and the motor that went bad, which in turn caused the motor to go bad. I don't remember the bill, but it was around $500 I think.
    Apr 23 2008
    B6 S4 Thunder Wagon
    Re: wiper motors
    Quote Originally Posted by lmmike View Post
    Covered under warranty?
