Results 1 to 10 of 10
    Jul 17 2008
    d
    Cleaning worn textured lip
    What do people generally use to clean and bring out the black in the front lip spoiler? Mine has a relatively large white spot which I assume is caused by wax.. how do I get rid of that and just make everything black again? I used mothers back to black and it didn't help much. Any help is appreciated
    Active Member Two Rings Rampid's Avatar
    Dec 14 2006
    Chicago IL
    Re: Cleaning worn textured lip
    tireshine
    Account Terminated Four Rings
    Aug 05 2007
    B5 Nazi Sled
    Indiana
    I just painted it. It took like 20 minutes.
    I used rubberized primer and sprayed some black paint on. Looks nice and wet.
    Feb 27 2005
    North Wales, PA
    mothers back to black works well
    Veteran Member Four Rings sixfiveoh's Avatar
    May 19 2007
    Bay Area
    I spray mine with trim paint every time I change my oil. Don't even clean it, prep it, or primer it. Simply hit it with the trim paint.
    SIXFIVEOHphoto
    2001 Brilliant Black 1.8TMS A4
    Unitronic|APR|H&R|Neuspeed|Falken|Carbonio|Apex'i| VDO|VMR
    FS: Buncha B5 parts, CLICK
    Veteran Member Four Rings Jibberific's Avatar
    May 22 2008
    az
    I also use back to black on my front and rear valences, it works great except you've gotta reapply it like once a month or they get all faded looking again. And if you accidentally get it on your paint, it leaves some gnarly smear marks
    {99.5 Avant}
    Veteran Member Four Rings boostedup's Avatar
    Sep 01 2005
    01 a4 1.8T,00 suzuki GSXR 600, 1974 Mako 171
    internationally known, Florida
    clean it up and paint it FTW. all of those other products wash off or just stop looking good after a couple of days.
    Santorin Blue 2001.5 Audi A4 1.8turbo Quattro with Sports, Celebration, Cold Weather Packages.
    Engine:APR 93 octane. Catch Can. Air Intake/Heatsheild. 710N .
    Interior:VDO Vent Boost gauge. Short Shift. Garmin GPS. 2-10" subs. Suede interior
    Exterior:19" ASA St4's/NITTO rubber. Neuspeed Race/Bilstein Sport shocks. 15% tint. Debadge. Clear Corners. 4300K HID. MS Design Front lip
    Veteran Member Three Rings BrokeDown[20V]'s Avatar
    Sep 06 2007
    Take it off and respray it with this. The result is like Brand new OE.
    You can get it at any Home Depot or Lowes.
    Original.
    Jun 04 2007
    01' A4 1.8TQM;15' Wrangler
    Austin/DFW, TX
    Mothers Back to Black
    BetaAlphaTau Member #12
    01' A4 1.8TQMS 5spd swapped
    My 5-Speed Swap DIY
    - B6 USP
    Sep 01 2005
    Quote Originally Posted by BrokeDown[20V] View Post
    x1000
