Results 1 to 35 of 35
    Registered User Four Rings
    Feb 26 2006
    Over 20! too many plant pots!
    Earth
    Audi A4 VR6 Turbo - PHASE II - S4 What....
    Just thought I would share some eye candy with forum members.As usual Javad & crew do amazing work and the following is testiment to that fact.....sell your supra and skyline.There is a new big boy in town!
    Quote Originally Posted by 2931cc 24V Engine
    Project Specs:
    ENGINE:
    * Lower Half : The Block & Oiling system
    - BDF Block bored to 83mm + align honed Main's
    - 83mm 9.0:1 JE Pistons
    - 90.3mm OEM Crankshaft
    - 034 Motorsport Forged Rods + ARP bolts
    - ARP Main studs
    - 034 Motorsport ARP head studs
    - 034 Motorsport Coated connecting rod & Main bearings
    - 034 Motorsport VW Touareg modified oil pan
    - 034 Motorsport Custom 12-lb Aluminum Flywheel
    - 034 Motorsport Custom starter Motor
    * Upper Half : The Head
    - R32 Cylinder Head - Given 034 Motorsport Stage-3 porting Job
    - Stock Intake Valves
    - Stock Exhaust Valves
    - 034 Motorsport High-Rate Valve spring & Ti Retainers
    - OEM Lifters
    - Techtonics Tuning 264/260 Camshafts
    * Ignition,Turbo,Intake & Fueling System:
    - 034EFi Stage IIc SEM system +4Bar Map sensor
    - (6) 034EFi HO Direct Fire Coils
    - 034 Motorsport Plug Wires
    - Garret GT4508R Turbocharger
    - 034 Motorsport Tubular manifold
    - 034 Motorsport Oil + Coolant supply/return kit
    - TiAL 44mm Wastegate
    - TiAL 50mm Blow-Off Valve
    - 034 Motorsport Custom intake manifold
    - Mustang 75mm Throttle Body
    - 034EFi VR6 Fuel Rails
    - 034 Motorsport Fuel Pressure Regulator
    - (6) PRIMARY - Seimens 630cc Injectors (stock location)
    - (6) SECONDARY - RC Engineering 1000cc Injectors
    - (2) Bosch 044 MS Fuel pumps
    (click images for larger resolution)
    Oct 29 2005
    10speed
    San Francisco, CA
    Re: Audi A4 VR6 Turbo - PHASE II - S4 What....
    Issam your insane
    - Clint
    Veteran Member Four Rings BITRBO's Avatar
    Mar 08 2007
    Mr. Worl-Wye
    wow, that's a whole lotta-fachina... I mean turbo!!!
    edit: I love the second pic; it looks like they needed an engine hoist to pull the turbo out
    '13 C63 AMG -
    '14 Tiguan - sold
    '09 JSW - sold
    '04 GTI - sold
    '01 S4 - sold
    Veteran Member Four Rings audirs's Avatar
    Mar 22 2005
    Kitchener, Ontario
    so beautiful
    Q5 3.0T S-line
    VW Tiguan R-Line
    A6 2.7T AWE Stage 3
    Coupe Quattro
    Active Member Four Rings
    Dec 11 2006
    Boston
    Holy Moley.
    Needs a bigger turbo.
    Stage 3+ RS6's
    Mar 11 2007
    1990 R32 GT-R
    Somewhere in CT
    Quote Originally Posted by deb38 View Post
    Or more Cow Bell.
    This looks like its going to be fast as hell. What numbers are you expecting to put down?
    Senior Member Three Rings gaspeedracer's Avatar
    Jun 02 2007
    2001 Imola Yellow S4
    Daytona Beach, FL/Conyers, GA
    its huge!! (and thats what she said )
    "A true leader has the confidence to stand alone, the courage to make tough decisions, and the compassion to listen to the needs of others. He does not set out to be a leader, but becomes one by the equality of his actions and the integrity of his intent."
    -Douglas McArthur
    Semper Fi!!!
    Active Member Four Rings NYCVR6's Avatar
    Queens, NYC
    4508R huh? Trying to one up my VR! hahaa looks sick brother!
    Justin- 01.5' Pearl S4 24V VR6 Turbo Pow Pow
    034 Motorsport
    FFE Racing
    MoTec
    Tuned By Shane T
    Boost Factory!
    Drive your car, not your dyno sheet
    Account Terminated Two Rings wreckedimolas4's Avatar
    Jun 11 2008
    silver b5 stg 2+ 95 m3
    almont
    just imagine if they used a 3.2 r32 setup
    Oct 31 2005
    Ashburn
    I'm to lazy to look it up, but what's the difference between this and the A4 vr6 you guys ran at the euro tuner Gp other than turbo size?
    and it being an S4 Chasis
    - Instagram: @Sinister_rs5-
    Aug 06 2008
    Canadia
    what an awsome idea! I like that the engine is even bigger than the S4's in displacement, for more POWA!
    also, where the hell do you get hose CF front fenders?
    Feb 26 2006
    Earth
    Quote Originally Posted by wreckedimolas4 View Post
    We used the head....good enough
    Cohen I could never top your VR ;)
    Active Member Four Rings RogueStatus's Avatar
    Nov 13 2007
    B5 S4 Avant
    Boston
    hooooly shit, whats the power/torque goal?
    Veteran Member Four Rings lrg8683's Avatar
    Nov 01 2005
    S4
    VA
    how much $$$$$$$$$$$$$ is it to get one of these into an S.. i'd LOVE a single turbo Vr6
    -Luis
    Apr 05 2007
    these need to be built and sold as turn-key. I'd pop one in a coupe quattro.
    Veteran Member Four Rings RolledMySTi's Avatar
    Jul 06 2007
    2001 S4 Sedan Laser Red
    San Jose, CA
    This is basically what you would experience driving that car
    http://www.youtube.com/watch?v=HB7tc9pVvYg
    Amazing work guys.
    01 Laser Red S4 Stage 3 | Vast Fueling | Clutchnet 6 Puck Disk with RS4 PP | APR Downpipes | Aluminum Flywheel | Neuspeed Exhaust | SRM Side Mounts | ECS Pulley Kit | RS4 Airbox | UUC Short Shifter | ST Coilovers| Samcos | AWE DTS Bar | JHM Center Diff | 034 Track Motor Mounts + Street Trans Mounts | Apikol blue rear diff mount and bushings | Areomotive Fuel Pump | ECS 2.0T Coil Conversion | Hooked on Meth
    Nov 13 2007
    B5 S4 Avant
    Boston
    Quote Originally Posted by RolledMySTi View Post
    Amazing work guys.
    "they've gone plaid!" hahaha
    Veteran Member Four Rings Korben007's Avatar
    Nov 08 2007
    00 Celica Supercharged, 02 S6, 04 S4 Avant
    Lake Tahoe, CA/NV
    this looks like a really appealling motor setup for my cq. And much easier to source then the euro 2.2L 5 cylinder. I will be watching this thread with big eyes !
    Current Rides:
    2000 Toyota Celica GT-S Supercharged - 2008 Audi A3 VRT(SOLD) - 2003 Audi RS6 Avant - 2013 Audi Q7 Prestige
    2000 Audi S4 Stage 3(SOLD) - 2008 Audi TT 3.2 (SOLD) - 2002 S6 Avant Manual w/ S8 PES Supercharged - 2015 Porsche Cayman GTS
    1990 Audi Coupe Quattro(SOLD) - 1993 Toyota MR2 Big Turbo(SOLD) - 2001 Audi S6 Sedan (SOLD)
    @audijedi
    Veteran Member Four Rings FLACO X3's Avatar
    Jun 05 2008
    B5S4, B7A4
    Thornton & Elbert County, CO
    HOLY SHIT!! Will the car be for sale when it is complete?
    2000 S4
    2008 A4 2.0TQ
    Senior Member Three Rings jblinga's Avatar
    Jul 24 2008
    '01.5 S4, '96 Maxima
    Mor_onville U.S.A.
    Go big or go home! jk
    That thing os going to be sick!
    '01.5 S4 6MT 2+
    '96 Maxima (DD)
    Mar 08 2007
    Mr. Worl-Wye
    ^^hahaha. That's fuckin' hilarious!
    '13 C63 AMG -
    '14 Tiguan - sold
    '09 JSW - sold
    '04 GTI - sold
    '01 S4 - sold
    Account Terminated Four Rings
    Aug 06 2007
    audi, subaru, dodge, ford
    Truckee, CA
    Quote Originally Posted by Korben007 View Post
    TJ: is your CQ red?
    if so I have seen you driving around Tahoe City
    Nov 13 2007
    denver
    I hope the manifold is strong. That turbo could eat the whole engine if that thing breaks loose!!!
    Nov 13 2007
    denver
    Are you putting headlights in?
    Active Member Four Rings bassed's Avatar
    Sep 24 2005
    always in design
    Quote Originally Posted by JaredVL View Post
    TJ: is your CQ red?
    Nope it's black go to the South Lake more:)
    Veteran Member Four Rings b00st's Avatar
    Oct 17 2004
    04 B6 S4, 08 RX350
    St Charles, IL
    is this the same build up we have been reading in ET? 800HP audi or bust?
    The RIDES:
    2015 M3 - BM3 stage 2
    2011 335 Msport - FBO + E85 sold
    04 S4 - JHM 93oct Tune | JHM Piggies | FI CB | JHM Intake Spacers | JHM Stage 4 Clutch | JHM LWFW | JHM LW Rotors | Snub | K&N | 034 Density Motor Mounts |SOLD
    99.5 A4 PC16 K04 - SOLD-
    http://www.cardomain.com/ride/2404758
    AMA Member
    JHMFTW!!
    Veteran Member Three Rings s4nicetry's Avatar
    Nov 29 2007
    Calgary / Vancouver
    Daaamn! You'll need warning signs to keep pets and small children clear of that intake.
    Veteran Member Three Rings nateS4's Avatar
    Apr 25 2008
    01.5 Nogaro S4 6spd, 02 GSXR, MkIII TDI
    Baltimore
    That is pretty bad ass. Maybe I missed something, but are you still running the S4 drivetrain??
    2001.5 S4 Nogaro Stage III
    Test Pipes|AWE Twin1|Forge Hybrid BOV/BPV|JHM MBC|VAST Tuned|FrankenTurbos|034 Mounts|Hotchkis S-bars|RS4 Grille/Knob|50w HIDs|Vogland/Bilstien|JHM SS
    02 Suzuki GSXR Telefonica Movistar
    88 Bimmer E30 Vert
    98 Jetta TDI
    90 Corrado G60 Sold!
    92 Audi 100 Sold!
    http://photobucket.com/nateS4
    Established Member Two Rings VelocityS4's Avatar
    Nov 23 2006
    South Florida
    Quote Originally Posted by b00st View Post
    No, thats their 80q 5cyl.
    05 B6 S4 - Slow
    02 B5 S4 - 11.3 @ 125 (k04's w/ spray) - SOLD
    Veteran Member Four Rings GURUMAN's Avatar
    Mar 13 2007
    2.9L PTE 6766 1000 Bhp single Monster !
    Montreal
    Jeff did you ever figure out whats wrong with your setup ...
    I'm about ready starting tuning my 034 standalone...
    GURU energy drinks
    www.guruenergy.com
    10.58 @ 140.17 mph
    10.51 @ 137.56 mph
    http://www.youtube.com/watch?v=1kG98vSWkT4
    WATERFEST 15 RUN 10.92 @ 133.55 mph
    Nov 23 2006
    South Florida
    Quote Originally Posted by GURUMAN View Post
    No, guy that took over the project (Chris Green) has it on the back burner to his 996 Turbo. I want to buy it back
    05 B6 S4 - Slow
    Feb 26 2006
    Earth
    DOM!
    Mar 13 2007
    Montreal
    What ?
    GURU energy drinks
    www.guruenergy.com
    10.58 @ 140.17 mph
    10.51 @ 137.56 mph
    Veteran Member Four Rings Reich's Avatar
    Oct 14 2007
    2001 s4 ; 2001 jetta tdi
    Val-Belair
    Looks good Issam. Do you have any idea of how many #s you'll have?
    Feb 26 2006
    Earth
    I will be in mtl tomorrow!
