Page 1 of 4 123 ... LastLast
Results 1 to 40 of 149
    Registered User Four Rings
    Feb 26 2006
    Over 20! too many plant pots!
    Earth
    Audi A4 VR6 Turbo - PHASE II
    Just thought I would share some eye candy with forum members.As usual Javad & crew do amazing work and the following is testiment to that fact.....sell your supra and skyline.There is a new big boy in town!
    Quote Originally Posted by 2931cc 24V Engine
    Project Specs:
    ENGINE:
    * Lower Half : The Block & Oiling system
    - BDF Block bored to 83mm + align honed Main's
    - 83mm 9.0:1 JE Pistons
    - 90.3mm OEM Crankshaft
    - 034 Motorsport Forged Rods + ARP bolts
    - ARP Main studs
    - 034 Motorsport ARP head studs
    - 034 Motorsport Coated connecting rod & Main bearings
    - 034 Motorsport VW Touareg modified oil pan
    - 034 Motorsport Custom 12-lb Aluminum Flywheel
    - 034 Motorsport Custom starter Motor
    * Upper Half : The Head
    - R32 Cylinder Head - Given 034 Motorsport Stage-3 porting Job
    - Stock Intake Valves
    - Stock Exhaust Valves
    - 034 Motorsport High-Rate Valve spring & Ti Retainers
    - OEM Lifters
    - Techtonics Tuning 264/260 Camshafts
    * Ignition,Turbo,Intake & Fueling System:
    - 034EFi Stage IIc SEM system +4Bar Map sensor
    - (6) 034EFi HO Direct Fire Coils
    - 034 Motorsport Plug Wires
    - Garret GT4508R Turbocharger
    - 034 Motorsport Tubular manifold
    - 034 Motorsport Oil + Coolant supply/return kit
    - TiAL 44mm Wastegate
    - TiAL 50mm Blow-Off Valve
    - 034 Motorsport Custom intake manifold
    - Mustang 75mm Throttle Body
    - 034EFi VR6 Fuel Rails
    - 034 Motorsport Fuel Pressure Regulator
    - (6) PRIMARY - Seimens 630cc Injectors (stock location)
    - (6) SECONDARY - RC Engineering 1000cc Injectors
    - (2) Bosch 044 MS Fuel pumps
    (click images for larger resolution)
    Account Terminated Four Rings
    Aug 05 2007
    B5 Nazi Sled
    Indiana
    Re: Audi A4 VR6 Turbo - PHASE II
    What is the reasoning behind running the R32 head?
    Veteran Member Three Rings b5s4tt's Avatar
    Mar 14 2007
    s4
    queens
    looking good!
    Senior Member Three Rings bernB5's Avatar
    Nov 13 2007
    Long Island, NY/ Hartford, CT
    dude.... 45r? is time attack no longer a priority?
    insane, but so sick
    Old: 97 30r'd A4 ---> headaches
    New: Evo IX MR ---> 354awhp/349tq and couldn't be happier
    BERNSTEINphotography
    Mar 09 2004
    99.5 A4 Avant, 01 allroad
    nw michigan.
    Seems like the perfect engine to do an equal length twin scroll. It would have been relatively easy given that half the runners are shorter than the others.
    Also wondering why you guys didn't use the R32 block and R36 crank to make a 3.4 liter. Even Shimmel and the boys take the old block to 3.0. Quicker spool, lower boost threshold, and better throttle response.
    Anyway, it sure looks like a monster.
    Jim
    I Do Werk.
    Veteran Member Four Rings MultiAudis's Avatar
    Mar 12 2006
    01 Allroad 6mt, 01 A4
    NoVa
    oh god yes!!!
    Registered Member Two Rings
    Feb 10 2008
    RI
    I think I can fit my head in the 45r
    Jul 07 2004
    630AWHP A4, Nissan Titan
    socal
    I wonder if they are going to get someone that has more drag racing experiance to drive it this time if thats what they built it for.
    BTW its about time you guys put CF fenders on that car.
    Quote Originally Posted by onemoremile View Post
    Well to do a twin scroll manifold on a 6 cylinder they would need to have 3 runners on the front part of the flange and 3 on the back side. They would run into issue with room plus the T4 flange is much longer then it is taller, which is why they have 3 on top and 3 on bottom.
    Aug 05 2007
    B5 Nazi Sled
    Indiana
    I sure hope they are going to get someone that can actually drive that thing if they built it for drag racing.
    It's obviously built to be a grocery getter, I mean look at that turbo. Teeeny.
    Veteran Member Four Rings 20vpower's Avatar
    Oct 05 2006
    1998 A41.8TQMS
    San Jose, CA
    wowza cant wait for some vids
    Previously: 12vPower
    97 12v fwd CACTUS GREEN (SOLD... thank god)
    98 1.8tqms MELANGE 50 trimd
    Sep 17 2005
    Fremont, California
    Thanks for the compliments, glad you like it
    Just to address your questions, we are under a severely tight timeline on this project, basically everything you see there, including the motor internals and build, have been done in under 4 weeks, and the car needs to be running in the next 2 weeks, all while running 034, doing tons of service and having a full customer fab schedule. We would have loved to play more with runner length and tuning of the header but the time is not permitting, this is something we hope to do in the future, but I'm more than confident this current design will have NO problem delivering a lot of reliable HP.
    We stayed with the 24v block as it offers much more cylinder wall thickness than the 84mm bore of the R32, this motor will not only be heavily boosted, but heavily loaded in full race conditions, it is worth the extra strengh and reliability to sacrifice 10% displacement. This motor will make its power with boost and revs which its very well suited to do.
    Thanks again for the interest
    Javad Shadzi
    034Motorsport
    Oct 30 2006
    B8 A4 Avant 6spd
    Holy mother of god. Any HP goals set for this puppy?
    -18 718 GTS
    Sep 17 2005
    Fremont, California
    Quote Originally Posted by Militant-Grunt View Post
    We're holding our hand for now, look for some actuals in the not too far off future
    Oct 27 2007
    2001 Golf 2004 A4 USP
    In the lab
    Quote Originally Posted by Javad@034 View Post
    Nice to see you on here Javad, hopefully youll stick around for a bit... Btw, this project makes my dads B6 you will be building soon look a little less impressive haha
    Sep 17 2005
    Fremont, California
    Quote Originally Posted by 317ssayzarc View Post
    Awesome, but I dunno, that is still one of the most favorite cars we've helped build
    Oct 27 2007
    In the lab
    Doing air to water? Think your going to need a bolted compressor outlet :D
    Feb 26 2006
    Earth
    Quote Originally Posted by ILoveT View Post
    Larger intake ports
    3.2 blocks produce hair line cracks @ the bottom of the bore when under alot of stress.A 2.8 block is much better suited for the job and no need for stroke....we have enough displacement.
    Veteran Member Four Rings Lazer Viking's Avatar
    Nov 06 2006
    garage ornaments
    southeastern pa
    that may be a hint
    -Nic
    My Car
    old junk new junk, red junk blue junk
    Oct 06 2004
    Minnesota
    Nice work guys. That car was a monster, now I am lost of words to describe it.
    Instagram r_michals
    '12 Q7 TDI- Glacier White
    Veteran Member Four Rings Nebone's Avatar
    Jan 21 2006
    6MT BT Avant Ti
    RI
    I hope this performance surprises people even more than the old setup. 034 should be the new overhauling TV crew.
    Ibis White 2008 Audi A4 2.0T Avant 6MT S-Line Titanium APR Stage 3
    Deep Sea Blue Pearl 2010 Audi A4 2.0T Premium Tip
    Dolphin Grey 2005.5 Audi A4 2.0T Avant 6MT *Sold after 7 years of ownership*
    Goodwood Green Pearl 2002 Audi A4 1.8T Sedan Tip
    Santorin Blue Pearl 2001.5 Audi A4 1.8T Sedan 5MT *Sold after 9 years of ownership*
    Feb 15 2008
    E46 323i 5-Sp
    616/MI
    Holy mother of god.
    That's exactly what I said.
    ... Then I added, "It's about damn time they put a 24V on that thing!". That's what I wanted in the first place.
    Twin 044 pumps, 630 + 1000cc injectors, BAMFT, only the best SEM, ... you guys better strap this thing down tight on that dyno.
    Curious, what's the 90* AN fitting going in the back of the trans for? Cooler w/ an external pump?
    EDIT: What #'s did you end up w/ on the 12V? I remember a 600+whp dyno pull on YouTube, did you end up making anything more than that one?
    Veteran Member Four Rings chris164935's Avatar
    Apr 18 2007
    2016 Audi A3 2.0tQ; 2001 Audi A4 1.8tQM
    Orange Park, FL
    So, the turbo fits without any modifications to the hood and/or frame rail? How big is the down pipe and does it clear between the body and the transmission without any modifications as well? I am also dying to see some pictures of how you guys are routing the intercooler piping and if you're going air-to-air or air-to-water...
    "You know you have a bad idea when Ford guys are making fun of you."
    Veteran Member Three Rings big_greasy_taco's Avatar
    Apr 28 2008
    Houston, TX
    Good lord... that is a monster. That turbo is bigger than my head!
    Veteran Member Three Rings Bic-Ball's Avatar
    Mar 29 2007
    Is the street.
    Long Island, New York
    lol is the turbo being lowered in on a winch? thats awesome
    Sep 17 2005
    Fremont, California
    Quote Originally Posted by djwimbo View Post
    Us too, but sometimes you have to strategize with the budget you have, AAA VR6 motors are practically free, the 24v took some penny saving
    Yep, tranny cooler, our trans has a pump built in.
    648whp at the Eurotuner GP 2007, 42psi boost, but the 12v is such a limited tuning platform for real big power, with almost twice the flow in this head, we're looking forward to some significant power increases as well as a much broader power band **rubs hands together, pining for the moment he can tune this beast**
    Sep 17 2005
    Fremont, California
    Quote Originally Posted by Bic-Ball View Post
    Yup, weights almost 60lbs, it gets tiring with one person!
    Sep 17 2005
    Fremont, California
    Quote Originally Posted by chris164935 View Post
    Pretty much "fits", yes. DP is full 4", it touches in places but the engine is solid mounted, not a ton of room down there though. Intercooler is a massive air-to-air, see:
    Feb 15 2008
    E46 323i 5-Sp
    616/MI
    This is probably one of the bigger displacement big turbo cars you guys have built(to my knowledge), I'm glad you guys are stoked about it, not afraid of it.
    Any reason for not running a tangential?
    and is that a stock radiator? Are they good enough for a 800+hp car?
    Sep 17 2005
    Fremont, California
    We're not really afraid of tuning cars, its what we do for a living With a # of engines in the 4-500HP/L range, this one will be par for the course.
    Turbine housing? We are...
    Yes, for now, we'll likely upgrade to an S4 front core support and custom radiator at some point, but for time attack duties, the smaller A4 radiator has been fine for 3-5 laps max.
    Jun 01 2008
    Apopka, FL
    that's still pretty amazing considering it was engineered for 150-190HP engines that usualy dosent see past 4.5K rpms , are you even still running some off the shelf coolant?
    Established Member Two Rings ricebeater's Avatar
    Mar 02 2008
    98 a4 1.8TQM
    Malvern, PA
    that turbo is big enough to eat a baby!
    How much would this thing cost to replicate?
    1998 black 1.8t A4 QUATTRO
    MODS:S4 front bumper:S4 gauge cluster:S4 seats:S4 Grill:VDO boost gauge:Forge SMIC:Neuspeed Exhaust:Forge Spltr DV:18"x8" ADRs:
    Coming Soon: AWE DTS, A/F and OP Gauges, two tone paint job, lowering springs and more...
    Sep 17 2005
    Fremont, California
    Quote Originally Posted by blmlozz View Post
    Yes, they certainly have plenty more capacity than is needed, we commonly run them on heavily tracked 400HP A4's no problem. We run water and water wetter only, no coolant.
    Sep 17 2005
    Fremont, California
    Quote Originally Posted by ricebeater View Post
    No 1kHP+ capable car is cheap to build, hard to say but its a good chunk of change, the labor alone will be the biggest thing in a build like this, to do the work and install yourself would save a lot of the expense.
    Veteran Member Four Rings Kyle H's Avatar
    Sep 21 2006
    98 A4 1.8tQM
    San Diego, CA
    Are you guys still running the stock transmission (minus clutch), driveshafts, axles and diffs?
    I'm just curious if the stock drivetrain can really handle all of that power.
    "Einstein: Any man who can drive safely while kissing a pretty girl
    is simply not giving the kiss the attention it deserves. "
    because racecar.
    Jun 04 2007
    01' A4 1.8TQM;15' Wrangler
    Austin/DFW, TX
    Quote Originally Posted by Kyle H View Post
    I was looking on their site earlier, and I think they are running stock a4 axles, and an s4 driveshaft
    BetaAlphaTau Member #12
    01' A4 1.8TQMS 5spd swapped
    My 5-Speed Swap DIY
    - B6 USP
    Sep 17 2005
    Fremont, California
    We were up until the Long Beach Grand Prix, we are now running B5 S4 front axles and front uprights, B5 S4 drive shaft with Stasis 01E short ratio trans. An 01A would not hold up to these power levels on track, in our experience, over 350whp seems to strip teeth off gears (not drag racing, but where uneven surfaces and turning are involved). Stock 2001 A4 rear axles.
    Sep 21 2006
    98 A4 1.8tQM
    San Diego, CA
    That bolded part made me laugh, nothing like good ol' drag racing stereotype coming true.
    Is this new car still going to have the low end for a time attack car with the gt45 (i'm assuming no)? What direction are you guys planning this car to head with the new setup?
    Can't wait for the dyno video!
    because racecar.
    Registered Member Two Rings deadleavesdie's Avatar
    Aug 04 2008
    B5 Audi A4 1.8TQMS
    Alexandria Bay/Canton
    dear god that is a massive snail
    Sep 17 2005
    Fremont, California
    Like many of the cars we build, it will be dual purpose, with two or 3 different turbo setups for different use, a GT45R would be a poor choice for Time Attack or road course work, so a 35R setup will be used for those sort of events
    Mar 09 2004
    nw michigan.
    Javad Shadzi
    034Motorsport
    C'mon now, I heard it was nothing but hammocks and Coronas in that shop. Something about a massive delivery of limes...
    I totally understand the budget and time crunches. Real life has a nasty habit of getting in the way. It looks like you guys built one hell of a car there.
    The 24v head is a major upgrade from the 12v. So much so that it hardly needs any head work at all other than proper cams. I can't remember for sure but I think it was Schimmel that put a ton of work into a head and only got 8% more flow.
    I'm sure you guys have a ton of connections but if you ever need anything VR6 specific Chris Collier at C2 Motorsports in Louisville is a great guy and has some deep roots.
    Now I've just got to convince the wife that buying a 2002 S6 and sending it to California for a big turbo VR6 is a good family decision. She'll come around eventually...
    Jim
    I Do Werk.
