Results 1 to 4 of 4
    Account Terminated Four Rings
    Aug 05 2007
    B5 Nazi Sled
    Indiana
    FWD Rear Suspension
    I have SEVERE camber issues. Both of my rear tires are really worn down on the inside. My rear suspension also looks really weird. There are two different struts; one being black and one being blue. I could not find a part number. I suspect this may be causing my camber problems. With front trak you cannot adjust the rear camber. So that is why I am suspecting the struts. Now will a rough alignment help my tire wear any? And where can I get a set of stock rear sport struts for the FWD? I just don't want to have to buy new tires AGAIN!
    Registered User Four Rings Mike@PureMS's Avatar
    Jul 19 2007
    San Diego, CA
    Re: FWD Rear Suspension
    Rear camber is NOT adjustable on the FWD B5. If your camber is out of whack, it's most likely due to a bent solid axle.
    The rear shocks won't have any bearing on the camber adjustment. Lowered, stock, the camber doesn't change.
    Aug 05 2007
    B5 Nazi Sled
    Indiana
    I know the camber is not adjustable.
    How the fuck do I have a bent solid axle? I'm going to kill kittens.
    Veteran Member Four Rings Nebone's Avatar
    Jan 21 2006
    6MT BT Avant Ti
    RI
    Bad wheel bearing?
    My brother bought a Mk4 with a bent rear axle beam. The car looked like it had a drifter-x cars rear camber.
    Ibis White 2008 Audi A4 2.0T Avant 6MT S-Line Titanium APR Stage 3
    Deep Sea Blue Pearl 2010 Audi A4 2.0T Premium Tip
    Dolphin Grey 2005.5 Audi A4 2.0T Avant 6MT *Sold after 7 years of ownership*
    Goodwood Green Pearl 2002 Audi A4 1.8T Sedan Tip
    Santorin Blue Pearl 2001.5 Audi A4 1.8T Sedan 5MT *Sold after 9 years of ownership*
