Results 1 to 40 of 69
    Stage 3 Forum Advertiser Four Rings VMRSport's Avatar
    Apr 25 2008
    Irvine
    VMR Sport | B7 Audi A4 Stainless Steel Test Pipe Turbo Downpipe - *$69 SHIPPED*
    BRAND NEW STAINLESS STEEL TEST PIPE
    Made for 2006-Present Audi A4 2.0T
    If you are interested in ordering, you can send payment ($69.99 dollars shipped, within the US) via paypal. Our paypal address is: [email protected]
    In the notes/comments section, include a link to this thread, so that we know what the payment is for, and also include what car it is for and what part you are ordering.
    Price is $69 shipped, within the US
    Fitment Information:
    Audi
    2006-Present A4 2.0T
    Fits Manual and Automatic Transmissions
    Fits Quattro and non-Quattro vehicles
    You are viewing a brand new test pipe made specifically for the B7 Audi A4. This test pipe is designed to bolt on and replace the stock catalytic converter**.
    Benefits:
    - Uses a 2.5 inch inner diameter pipe
    - Removes exhaust backpressure caused by the restrictive catalytic converter
    - Increases efficiency of the turbo
    - Increases lower end Torque
    - Allows for higher sustained boost pressure
    - Allows for faster throttle response
    - Provides sufficient flow for up to 450hp
    - Flanges have been casted and welded both inside AND out to assure long term durability
    Includes:
    - Fully-Polished 304 Stainless Steel Pipe
    - High Quality Stainless Steel Nuts and Bolts
    - Test Pipe-to-Downpipe Gasket
    - Downpipe-to-Turbo Gasket (other test pipes do NOT include this piece)
    - 1-Year Limited Warranty***
    ** Since this test pipe replaces the catalytic converter, it will cause you to fail smog. It is designed for off-road use only. It may not be legal to use this item on public roads, so please check with your local smog regulations.
    *** Warranty is limited to all workmanship and durability of the product.
    If you guys have any questions or need help with anything, let me know.
    thanks.
    -Don
    [email protected]
    This box does not currently receive PM's. Please direct all inquiries to Charles (VMRWheels) or Peter (Peter@VMRWheels).
    B5/B6 Audi A4 Test Pipe w/ Heat Shield
    VMR Sport | Integrated Vent Gauge Kit
    B7 Audi A4 Test Pipe - $69.99
    DUH! an Audi
    los angeles, CA
    Re: VMR Sport | B7 Audi A4 Stainless Steel Test Pipe Turbo Downpipe - *$69 SHIPPED*
    sick don!
    Apr 25 2008
    Irvine
    Thanks. I sent you a PM. Check it out.
    Veteran Member Three Rings volcomic's Avatar
    May 10 2008
    B9 A4
    Kirkland, WA
    That looks really nice! Great price too
    ◊ 20x10 Avant Garde M590's - Brushed Clear ◊ 255/30-20 Hankook V12's ◊ H&R VTF Suspension ◊ APR Tune ◊ ECS Luft-Technik Intake ◊ ECS Carbon Fiber Front Lip Spoiler ◊ ECS Carbon Fiber Grille Accents ◊ Color Matched Reflectors ◊ 15% Tint ◊ 2 JL Audio 12w6V2's ◊ JL Audio 1000/1 Amp ◊
    Apr 25 2008
    Irvine
    Thanks. I think it is set at a very reasonable and affordable price.
    If you guys have any questions, feel free to ask.
    -Don
    Veteran Member Four Rings EMAXX's Avatar
    Jul 12 2008
    That pipe is so pretty! The welds look great. Great price too!
    Nov 01 2007
    B7 A4 2.0TQT
    PA
    only 69 bucks? that's way lower than the other testpipes out there...
    Nov 26 2007
    Wont this test pipe throw codes?
    Veteran Member Four Rings supamannn99's Avatar
    Nov 15 2007
    Orange County, SoCal
    Yes, it will. If you have APR stg II, the test pipe file should delete it. Otherwise you can do the old fashion defouler mod posted somewhere on vwvortex
    goodjob Don :D
    Oct 09 2007
    socal
    Yes it will give you a check engine light but definately well worth it considering the price. I bought one a while back and its great quality product.much props to you guys at vmr I'd like to see more products from you in the future!
    Dec 27 2005
    New Orleans
    wow thats a deal..even cheaper than my J pipe!
    Active Member Two Rings shortyepic's Avatar
    May 09 2008
    Las Vegas, NV
    Quote Originally Posted by bander9 View Post
    you think this mod is worth having a check engine light always lit up on your dash?
    Apr 25 2008
    Irvine
    You can always get your car flashed, so that the light does not turn on. Plus, with a reflash, you'd be able to fully optimize the cat delete.
    -Don
    May 09 2008
    Las Vegas, NV
    Quote Originally Posted by VMRSport View Post
    -Don
    i already have a giac-x flash so would i have to reflash with the testpipe?
    Veteran Member Three Rings kharsnett's Avatar
    Oct 24 2006
    Indianapolis IN
    looks like the jeff psi testpipe. just wondering if i could buy just the gaskets? i bout a test pipe awhile back but lost the gaskets
    B7 A4 Non sline Sline Edition, High flow fog light holes, Titanium license plate screws, Cross drilled lug bolts, greasy axle, Coolant relief valve on cylinder head, Pressure relieving boost hoses, Cylinder Head Exchange program, Custom cam grind, used fuel pump follower, variable geometry front Control Arms, Automatically shifted manual transmission, 87 octane APR tune, detuned 83 Octane APR tune, Custom high flow Flex section, Custom built spark plugs, Ebay sponsored!
    Apr 25 2008
    Irvine
    Quote Originally Posted by shortyepic View Post
    Yes, if it wasn't previous flashed with the testpipe code in it, then you'll need to have it reflashed.
    We can't sell just the gaskets, sorry.
    -Don
    Veteran Member Three Rings pretarion's Avatar
    Jan 02 2007
    Plano, Texas
    I know I will get flamed for asking, but...
    Will this fit the FWD CVT?
    2012 Audi TTRS Carbon Package
    Nov 26 2007
    Will the car sound louder with this?
    Veteran Member Four Rings Doctor's Avatar
    Jun 02 2008
    A4 B7 20vt Quattro,Golf MKV GT
    Greece
    Does it fit the 1.8T B7 A4 too...?
    DUH! an Audi
    los angeles, CA
    when you flash your car, with giac you will need to get a tp file added, revo has to be stage 2(has test pipe file in it) and apr not sure....
    else you will have codes on display, but as many mention it is well worth it. You will feel a bit more gains and your car will be a tad louder =)
    -randy
    Nov 16 2007
    Westerly//Providence
    why are you able to sell this product so much cheaper than the other leading competitors?
    Veteran Member Four Rings Audized's Avatar
    Oct 22 2006
    Eh?
    Quote Originally Posted by CoreyRandmetz View Post
    because they are VMR and sell quality stuff for much less.
    Nov 16 2007
    Quote Originally Posted by autumn View Post
    ok but 69 dollars shipped is a huge difference than 309+ shipping for an AWE test pipe....
    Oct 22 2006
    Eh?
    I don't know why AWE charges so much for a SS tube with ends welded on it. FYI, a Eurocode TP is only $150.
    Veteran Member Four Rings gaede's Avatar
    Jun 06 2008
    fourbanger
    Carlsbad, Ca
    it's also a 2.5" instead of 3" tp.
    this is what i've been looking for, good job don
    Veteran Member Three Rings TunaRollZ's Avatar
    Feb 20 2007
    911 TT/A5 3.2L/S4 4.2L
    Sunnyvale CA
    man that's such a good price
    08 Audi A5 s-line 6MT - new daily
    06 Audi S4 6MT - JHM'ed :)
    01 Porsche 911 Turbo 6MT - some mods ;)
    06 Scion Xa - road trip monster
    May 06 2007
    Rockin' with Audi
    Hi, I have MTM stage 1 software, with MTM catback exhaust, will this throw a CEL? I'm not sure if MTM allows cat deletes. If you can check and let me know I'll take one of these!
    Veteran Member Four Rings Mr.Audi's Avatar
    Feb 26 2008
    none
    BALTIMORE
    pm sent...
    just waiting on some info to help clarify some questions!!!!!
    B8.5 S-line prestige
    #fourringarmy
    Apr 25 2008
    Irvine
    Thanks for all of the comments and replies guys.
    All PMs replied to.
    If you didn't get a reply back, I either didn't get your PM, or I must have deleted it by accident.
    -Don
    Feb 26 2008
    none
    BALTIMORE
    sent payment and all needed info.
    will i get a tracking # once it is sent?
    my email is [email protected]
    #fourringarmy
    Apr 25 2008
    Irvine
    We ship it out via USPS priority mail, and they don't have tracking numbers available. You should be getting it sometime next week though.
    -Don
    Jan 02 2007
    Plano, Texas
    If you ship Priority Mail, YOU DO get a tracking number. Actually, if you make your labels online, tracking is FREE! I know this as I have an Ebay store and ship out each day via USPS Priority. So, you should have a tracking number.
    Jun 02 2008
    Greece
    Quote Originally Posted by Doctor View Post
    bump
    Apr 25 2008
    Irvine
    Quote Originally Posted by pretarion View Post
    Do you mean delivery confirmation number? Does the number that USPS provide you track the location of the package as it goes from one location to another? If so, I've never noticed it before.
    -Don
    Jan 02 2007
    Plano, Texas
    When you send a package USPS online, Delivery Confirmation is free. The number for the Delivery Confirmation IS the tracking number. That number is what I send to my buyers. Now, USPS will not update the info online as far as... where the package is during transit. They only update the info when it has left the terminal and again when delivered.
    Most buyers are happy with just getting a delivery confirm number. That way they have something to confirm you shipped it out.
    Apr 25 2008
    Irvine
    Only fits 2.0Ts.
    Apr 25 2008
    Irvine
    Not going to argue with you. I just wanted to confirm what I was thinking of was right. If you want to continue it, you can PM me.
    thanks for the clarification.
    -Don
    Apr 25 2008
    Irvine
    Here is a link to the B5/B6 1.8T fitment, for those who were interested in it.
    http://www.audizine.com/forum/showth...34#post2831434
    Apr 25 2008
    Irvine
    Thanks for the orders guys.
    All orders should be getting processed today and shipped out over the next couple of days.
    Let me know if you guys have any other questions.
    -Don
    Veteran Member Four Rings RedS-line's Avatar
    Mar 19 2008
    2019 S5, 1990 944 S2
    the price is unbeatable but for those of us who want to pass emissions, have you ever considered building a high flow cat for the b7? if you priced it like the rest of your product line, im sure they would move.
    2019 S5 BO.SS
    1990 944S2 Cabriolet
    2009 R8 6 Volt :)
