Results 1 to 4 of 4
    Established Member Two Rings audicribb's Avatar
    Jan 16 2008
    Lexington, SC
    Torx Bolt Size..Help Please.
    Hey,
    I have to replace my hood hinges and do notknow what size torx bit i need. Don't own ant torx bits. I think its a torx bolt, hexagon shaped? Anyway has anyone removed their hinges, and what do I need.
    Thanks So Much
    Veteran Member Four Rings MattzWarsteiner's Avatar
    May 22 2008
    is full of crap
    sandville
    Re: Torx Bolt Size..Help Please.
    You can press a piece of cardboard against the bolt and get a pretty good outline that can be carried to Advance or Sears for the right bit. If the head is clean, put some grime on it first.
    Veteran Member Four Rings GetBoosted84's Avatar
    Apr 10 2007
    01 Audi A4 1.8T Quattro / 88 Mazda RX-7 GXL
    Eastern PA
    Go out and pick up a set of hex bits if you plan on keeping the car for any length of time. Those bolts are all over the place and you will thank me later.
    Veteran Member Four Rings arorem's Avatar
    Mar 24 2008
    '99 A4 1.8TQ, '74 Triumph Spitfire
    Illinois
    t47 i think
