Results 1 to 23 of 23
    Jan 24 2008
    Minneapolis, MN
    I'm going to the dealer to get parts for my TestPipe install.
    I only have the TP what else do I need?
    Veteran Member Four Rings widgget's Avatar
    Dec 18 2007
    nj
    Re: I'm going to the dealer to get parts for my TestPipe install.
    Quote Originally Posted by Zorfunk View Post
    the gaskets that go between the turbo and the cat, and between the cat and the downpipe. you will need the bolts, washers, and nuts to connect it all up.
    it's just replacing one pipe with another, the only part that makes it hard is the location of the bolts.
    oh yeah...... depending on your tune, you might want to get a spacer for your 02 sensor so you don't throw any codes.
    Feb 15 2008
    AWE powered B6 1.8T
    Severna Park, MD
    A new gasket from the turbo to cat and gasket from cat to Downpipe. Two gaskets total.
    Buncha motorcycles
    Memphis, TN
    if your TP didnt come with new bolts go ahead and get them, you will certainly need the cat to turbo nuts and TP to DP nuts/bolts
    and dont forget a six pack of belgian bud lights, and some band aids
    APR Stage 2/AWE Intake
    Registered Member Three Rings SlappyB6's Avatar
    May 14 2008
    W-S, NC
    Quote Originally Posted by Papachristou View Post
    Haha, classic!
    And some Rust Buster/PB Blaster/WD40 (or all of the above).
    02 A4 - 5spd - Sport - VM DP
    Capt. Obvious - "Not me. I fart rainbows, shit rose pedals and piss excellence."
    Dec 18 2007
    nj
    Quote Originally Posted by SlappyB6 View Post
    Haha, classic!
    shit yeah, i forgot the PB BLASTER! i pulled it out of my trunk this morning to lube up the hood catch on my bosses GMC 1500.
    Although i have to admit that i gave up on the CAT to downpipe after about 24 hours of hardcore soaking and since i was replacing the entire setup anyway i just left the cat and test pipe connected and hacksawed the testpipe from below and pulled the unit out as one chunk , and to this day the cat and half of the downpipe are still connected and prob will be when i drag it to the scrap dealer.
    Registered Member Two Rings
    Feb 07 2006
    ouellette
    that's more or less what I had to do too. Except I took it out in one piece, and used a torch to cut the bolts off the cat when it was out.
    Jun 30 2007
    Raleigh, NC
    Quote Originally Posted by widgget View Post
    not to vulture - but PM me if you wanna sell me your cat.
    and you might need an impact gun to get a few of those bolts off (cat to downpipe) if you don't have a torch lol
    12.5 best ET -- 113 best trap
    The Awesome™
    BetaAlphaTau Member #42
    Feb 19 2007
    2001 BMW 540i M-sport
    Charleston, SC
    I run with no gaskets. No leaks what so ever, Just make sure the two surfaces are flat and sand them down a bit too, too remove any rust/grime
    -Sami-
    Veteran Member Four Rings aaaudiprotein's Avatar
    Apr 17 2007
    2003 RS6
    Chicago Burbsss
    I thought dealer will never do anything like deleting your cats???
    BLACKHAWKS 2010, 2013 and 2015 STANLEY CUP CHAMPIONS
    Windows 7 WAS MY IDEA
    Dec 06 2007
    ^^exactly what i was thinking, i was supprised no one cought it.
    -Kirk
    BetaAlphaTau Member #58
    May 24 2007
    Southern California
    ^^^they are only supplying gaskets and bolts/nuts. not installing.
    Kyle
    2.0L Revo GTRS Eliminator
    Jan 24 2008
    Minneapolis, MN
    Wow, maybe I'll wait until I do a K04. Would it be a lot easier then?
    Veteran Member Three Rings phantom b6's Avatar
    Apr 02 2008
    LA
    It's just a pain to reach all the bolts... My bolts at the exhaust end of the downpipe were so rusted that nothing was getting them off.. not an impact wrench or all the liquid wrench in the world.
    The piece the downpipe is connected to is sleeved to the rest of the exhaust in the middle of the car. What we basically did was unbolt it from the sleeve and then wiggle the cat from the top until we could sawsall the cat in 2 at the thin part near the rear bolts. It was a royal pain in the ass.
    Feb 15 2008
    AWE powered B6 1.8T
    Severna Park, MD
    Not really since the turbo bolts aren't the issue. It is the original Cat to downpipe bolts that will be rusted and hard to get at. Open your hood and take a look at the back of your cat and you'll get the picture. You need to take the front tire off, remove the heat shield, and have some long extensions to get at the bolts (three in total). You will also need, or should I say it will help, to have the O2 sensor wrench attachment ( a special crows foot). I have been putting off installing mine but my bolts aren't rusty since I had an AWE Cat back installed a few months ago. Good luck.
    Feb 15 2008
    AWE powered B6 1.8T
    Severna Park, MD
    ummm this isn't a good idea, even though everything is great and you don't have a leak now. If you develope a leak you could potentialy damage the flanges of the DP, testpipe, and turbo, depending on where the leak forms. Where if a gasket fails, it forms a void for the gasses to escape without damaging the flanges... just from my experience with Diesel engines. If a gasket is required it should be used.
    Feb 19 2007
    Charleston, SC
    Quote Originally Posted by pondside36 View Post
    There are many people on this forum that even run with no gaskets PRE-turbo. I just dont use gaskets POST-turbo.
    I have been running like this for so long, and no problems....Our 1.8t dont put out that much exhaust gas anyways, lol
    -Sami-
    Jan 24 2008
    Minneapolis, MN
    So it would be easier to get a full exhaust and do it all at the same time.
    Feb 15 2008
    AWE powered B6 1.8T
    Severna Park, MD
    It is all good, I know you are an automotive tech and have cleaned everything up nicely before reinstallation. It just isn't something I would recommend to someone doing things for the first time with no experience.
    Also being a mechanic myself I perfer to use the recommended gaskets/orings/seals where required. There are many ways to skin a cat with that being said, in regards to gaskets/o-rings (material for instance) or even going metal to metal if allowable.
    Feb 15 2008
    AWE powered B6 1.8T
    Severna Park, MD
    If you go full exhaust you can avoid breaking the troublsom flange, as people have stated above by just removing the cat attached to the down pipe. It will be more work but you'll have a full turbo back system.... a lot more money at around 1k for a pre-made cat back exhaust.
    Veteran Member Four Rings HTA A4's Avatar
    Jul 11 2008
    2002 1.9L HTA3076R A4
    Illinois
    Will REVO software throw a code with a TP?
    Anthony
    Eurocode Tuning | fifteen52 | Speed Freaks Fabrication
    BetaAlphaTau Member #41
    Feb 15 2008
    AWE powered B6 1.8T
    Severna Park, MD
    ^^ I believe they have a cat delete feature that they can install.
    Dec 03 2005
    2 pedals 1FG
    connecticut
    Your best bet is to follow Martini's instructions from his APR 3+ install. I did that when I installed my cat-back with the OEM cat. I wound up disconnecting the cat from the turbo and dropping the entire exhaust down low enough to get an angle grinder in and cut off the cat to downpipe bolts.
    Get yourself nice 8mm bolts with copper lock nuts (same stuff that your exhaust manifold is bolted to the head with) for the TP to downpipe flange. With those, it won't come loose on you.
    http://a4mods.com/index.php?page=web...ages/apr3.html
    -Doug
