Originally Posted by
tgiblin
I brought my car to my local Audi dealership to get my driver's window checked out. They said the rivets were worn and needed to be replaced. They also did a scan of the rest of the car.
The estimate:
$196.79 Replace rivets in window
$535.00 O2 sensor
$221.39 Engine Coolant Temp Sensor
$219.00 Right Side Tie Rod End Loose
$229.00 Alignment
What should I DIY? What should I have the dealer do?
Ahahahahah Are you f'king kidding me? That's a $15 part and a 3 second install/swap. Any monkey can replace the Temp Sensor with 1 eye and a hook for a hand.
You can buy o2 sensors for a hell of a lot cheaper then that, and if your not afraid to get under the car it would be cake.
Get your alignment somewhere else, most places charge $90, NOT $230.
If you can take off your wheel, the tie rod end should be easy to "tighten" if it doesn't need replacing, just re tightened.
Don't know about the rivets, sorry.
This place is trying to rob you of money. Go somewhere else... actually, anywhere else would probably be better. I'm sure there are some reputable shops in NJ that can help you out.
