    Deactivated Four Rings
    Apr 09 2008
    Willow Grove, PA
    ***NOW SHIPPING*** A.W.E. Tuning DV1 Diverter Valve
    Hi Everyone,
    We've come up with a new, lower priced solution for the all too common problem of failed stock diverter valves.
    Our new AWE Tuning DV1 Diverter Valve is the by-product of some extensive power development we've been doing on late model Porsches. DV failure on some of these models has been 100% absent.
    Even when pushed to beyond 750hp, and no matter the climate or operating environment, we've yet to see one of these Porsche DVs fail.
    It was a lot of leg work, but we were able to get exclusive access to this part, as it is normally not available separately from the turbo unit.
    Using some clever and simple companion parts, we're excited to be able to offer this economical yet durable solution to the chronic torn DV issue.
    No permanent modifications are required for install and it is designed as a serviceable and cheaper alternative to the Bailey Motorsport DV30. The Bailey Motorsport DV30 comes with a Lifetime Warranty vs the shorter 6 month warranty of this unit, hence the lower price.
    Our DV1 Diverter Valve is a vacuum actuated Diaphragm Type Diverter Valve, as opposed to the Piston Type Valve manufactured by Bailey. Both designs have proven to be extremely reliable in street, track and dyno testing.
    Some highlights:
    Direct 1/2 hour bolt on with no permanent modifications to vehicle
    Very similar response time to the OEM DV valve.
    Extensively street, track, and dyno tested on multiple cars
    Priced at $129.95 for the complete kit
    In stock, and ready to ship!
    http://www.awe-tuning.com/pages/shar...rain&IL=awedv1
    Apr 09 2008
    Willow Grove, PA
    Re: ***NOW SHIPPING*** A.W.E. Tuning DV1 Diverter Valve
    Bump!
    Apr 09 2008
    Willow Grove, PA
    Bump!
    Apr 09 2008
    Willow Grove, PA
    I have gotten quite a few messages asking questions about our new DV1 Diverter Valve. Thought I would share a few of the more common/interesting ones along with the answers to them.
    How does it sound compared to the stock DV?
    Our DV1 will sound very similar to stock.
    Have you experienced any honking/fluttering issues?
    We have not experienced any of these issues in our testing. The honking of other aftermarket and OEM DVs concerned us too, so we did extensive testing of this valve on several platforms with no issues.
    Is it serviceable?
    The DV1 is 100% maintence free. It does not need any lubrication or servicing like some other DV Kits on the market. It is a true plug, play and forget piece.
    Should you need to disassemble the DV1 for any reason, you can do so by removing it from your car and simply unscrewing the 3 bolts. When you are done, just make sure the components inside are alligned and screw the 3 bolts back on.
    How much are rebuild kits?
    If needed, rebuild kits can be purchased for approx~ $50.00. We have not seen one of these valves fail, so at this time we do not anticipate the need for a rebuild kit, however if a customer does need one they will be available.
    How does the performance of the DV1 compare to the Bailey DV?
    The performance of these two valves will be very similar. Theortically, piston style DVs have should react have more friction that a diaphragm style DV and therefore have a slower response time. In reality the difference will be so minimal that you will not be able to notice the difference.
    These are just some of the more common questions I've been asked. If you have any others, please feel free to ask.
    Apr 09 2008
    Willow Grove, PA
    The DV1 has been a very popular item. Here are two about to be packaged up and sent out to customers.
    Our Shipping Department just received 30 additional diverter valve housings from the anodizing company. I was able to photograph these before they were assembled into complete DV1 Kits.
