Results 1 to 24 of 24
    Jan 30 2008
    2004 Moro Blue B6 A4 1.8T Quattro Ultrasport / BMW E46 M3 (track car)
    Chicago, IL
    Central Locking System
    So recently, my S decided that the auto door locks wouldn't work with my key fob or the switch on the driver's door panel. Well, I just assumed it was the fuse so I found the time to take a peak at it tonight and checked both of the fuses in the fuse panel that correspond to the Central Locking System, but to no avail, both fuses were good. I even switched them with another fuse to make sure.
    Everything else in the car seems to work, it is just the doors.
    Also, as a side note...I was looking and it and messing with the locks and my key fob and I disconnected the battery and reconnected it. Now my Radio went in to "Safe" mode. How do I go about clearing that so I can use my stereo again?
    Thanks in advance. I searched and somebody on here had a similar problem but not quite the same.
    Established Member Two Rings S E B's Avatar
    Jul 12 2008
    2001.5 S4
    East Coast
    Re: Central Locking System
    Sorry can't help you with the lock problem.
    For the radio, you're gonna have to enter the radio code again. It should be in your owners manual, and if you can't find the code then you'll have to go to an Audi Dealership and pay them to enter your vin number into the computer to get you a code. Cost me about $70
    Jan 29 2007
    08 S4 00 S4
    MD
    Quote Originally Posted by My2ndProject View Post
    You're gonna need the radio code to get it out of safe mode. Look in your manual and glove box bundle if you got it with the car...
    The door lock issue: Does it unlock the doors and just not lock from the driver's door? You can resynch the key fob by pressing lock or unlock on the remote and then sticking the key in the door lock and turning it to lock or unlock within a minute.
    Jan 30 2008
    Chicago, IL
    Quote Originally Posted by Seblun View Post
    That is ridiculous. I don't have the owner's manual. I do have the manual for the Stereo though. Hopefully it is in there.
    Jan 30 2008
    Chicago, IL
    Quote Originally Posted by mholme View Post
    It unlocks no doors. And it isn't just the Fob, the switch on the driver's door does not work either.
    Here is a question? When you manually unlock the doors with the key, is it supposed to unlock the trunk. The reason I ask is because when i use the key it will not enable the trunk button to work, so I am unable to get into my trunk. Maybe the mechanism in the trunk is jammed and not allowing the locking system to work?
    Jan 29 2007
    08 S4 00 S4
    MD
    So pressing the button on the driver's door does nothing..got it.
    The trunk only unlocks if you turn the key twice, and it will unlock the other doors too. Try it and let us know. Stick the key in the trunk, turn it left and push in. Trunk should open.
    Oct 05 2006
    Baltimore, MD
    When you press the lock/ unlock buttons do you hear a buzzing sound kinda like a fuel pump coming from the rear of the car? If so you central locking pump is done.
    Jan 30 2008
    Chicago, IL
    Checking these things now...will be back to report.
    Jan 30 2008
    Chicago, IL
    Ok, using the key simply unlocks the driver's door and disarms the alarm. It will not unlock the doors when turning twice, but the power window feature still works when I hold it to the left.
    The trunk will not unlock. I stick the key and it will depress all the way but refuses to turn at all.
    There is no sound when i try to unlock/lock the car with the fob or with the switch on the door panel.
    So, there is a central locking system pump? As in pumping fluid? As in it is a hydraulic system? Where do I check fluid? Is there a write-up on how to replace the pump somewhere around the net?
    Thanks in advance.
    Jan 29 2007
    08 S4 00 S4
    MD
    Thanks in advance.
    It's a vacuum system, no hydraulics. And it's time for a VAG-COM
    So you stuck the key in the trunk, turned it left and pushed in, and it didn't open??
    Jan 30 2008
    Chicago, IL
    Correct, I tried to turn it left but it would not turn what-so-ever. Maybe something is jammed there messing up the system?
    Anybody live in the Chicago area or a little South there of want to VAG my car for me, so I do not have to buy the equipment yet?
    Veteran Member Three Rings jeproks's Avatar
    Jul 14 2004
    Bahay Kubo
    Check for a sticker on the spare tire well, radio code should be there.
    Veteran Member Three Rings JD797's Avatar
    Apr 10 2008
    dont mean to thread jack or anything, but I have a locking problem as well. Everything works fine except the driver side unlock button. It will lock doors, but not unlock, and the key and everything else works fine with locking and unlocking... any ideas?
    Registered Member Two Rings
    Jul 24 2007
    2000 Audi S4
    Bronx N.Y.
    Same, same problem for me... I think it's the central locking pump, anyone now how much this unit cost? I did hear the buzzing!!!
    2000 S4 6spd- GIAC Chip | H&R Coilovers | 4 Point Harness | Lojack | Blitz DTT DC Turbo Timer | DrainTake Mod | APR Bipipe | RS4 Clutch | Light weight flywheel
    Oct 05 2006
    Baltimore, MD
    The unit is about 500.00 from the dealer, that why I still need one. I have seem them on ebay for 100.00-150.00 but I keep forgetting to keep up with the bidding.
    Oct 31 2005
    Ashburn
    Quote Originally Posted by speedracer9k View Post
    Or you could just buy one from Shokans.com
    It will cost about 265 but it will have a 30 day warranty also.
    - Instagram: @Sinister_rs5-
    Jul 14 2004
    Bahay Kubo
    I have 1 central lock pump available.
    Jan 30 2008
    Chicago, IL
    Is there a write-up on the net somewhere on how to replace the pump and maybe a diagram of the system?
    Jan 30 2008
    Chicago, IL
    Also, is there a safety latch that i can pull from the inside of the trunk by reaching it through the backseats. Beings I can't get in the trunk via the key, I was hoping they build in some manual pull release, I know GM does it because I used to own a GTP. Any ideas would be great?
    Apr 10 2008
    i hear a noise coming from jsut infront of the gas dor area if thats it, not quite sure its a buzzing but its a noise, and the only thign that doesnt work is the unlock of the drivers button, the lock works and the keys work =\
    Veteran Member Three Rings IamEzraM's Avatar
    Jul 21 2005
    2001.5 Audi S4 Santorin
    Bedford/MA
    there's no reason you shouldnt be able to get into your trunk turning the key, there is a fully mechanical mechanism there along with the vacuum system lock/unlock
    My car is fast
    Jan 29 2007
    08 S4 00 S4
    MD
    It's plug and play. There's 3 harnesses that plug into it. The pump is in the right hand corner of the trunk behind the lining, straight down.
    Jan 30 2008
    Chicago, IL
    Thanks for your help. I will have to look for the manual release in the trunk so I can get into it and hopefully fix the mechanical latch that is jammed.
    Senior Member Three Rings jblinga's Avatar
    Jul 24 2008
    '01.5 S4, '96 Maxima
    Mor_onville U.S.A.
    I hear this noise from my '01 but everything still functions. Is it just a matter of time before the pump takes a shit?
    '01.5 S4 6MT 2+
    '96 Maxima (DD)
