Results 1 to 40 of 66
Thread: RWD
    Veteran Member Three Rings GetAwayFromMe's Avatar
    Jan 03 2008
    One million dollars all in pennies
    Iowa
    RWD
    I Bought another 99.5 A4 for a DD this one is also 2.8 5speed like my current one. It has over 200k miles and it needs alot of work and i had this thought of making tt RWD so i can have some fun. I only payed $300 for it because it's pretty beat up both body and engine. If there is anyone that did this what all is needed to complete the project? I really would like to do this so give me what you got.
    Before you go saying why? it's quattro blah blah i already have one and just want to have some fun at auto-x and what not.
    Jun 01 2008
    Apopka, FL
    Re: RWD
    yes it's been done before, and no, it's not that hard. Remove the axels, weld the center diff shut. Done. Don't even really need to do the first part if you're lazy, since when you weld the diff they won't get any power anyway.
    Jan 03 2008
    Iowa
    Re: RWD
    Any info on what exacly needs to be welded?
    Jun 01 2008
    Apopka, FL
    Re: RWD
    http://www.audizine.com/forum/showth...version&page=2
    post # 31 & 32 nothing fancy, just something to keep the parts from moving basicaly.
    Jan 03 2008
    Iowa
    Re: RWD
    Awesome guys thanks alot i might be doing this over the weekend.
    Jan 03 2008
    Iowa
    Re: RWD
    Does anyone know if i should weld the rear diff also? If i weld the center diff and not the rear would both rear tires spin or just one? I dont see the reason to remove the front axels if they are not gonna have any power going to them unless there could be a problem it it spins the front diff. I think if i do this it would be fun to go and try some drifting at the track but hearing that the rear diff is weak i shouldnt be launching the car hard.
    Jun 01 2008
    Apopka, FL
    Re: RWD
    you don't need to do the rear diff unless you want one wheel wonders . front diff dust power equally between the front wheels center dust between the front and rear wheels, and the rear diff dust power equally between the rear wheels.
    Mar 09 2004
    99.5 A4 Avant, 01 allroad
    nw michigan.
    Re: RWD
    Pick up a Porsche 944 rear diff and machine the bearing bosses to fit the Audi bearings. Now you've got a great limited slip in the rear for a fraction of the cost of a new Torsen.
    Jim
    I Do Werk.
    Jan 03 2008
    Iowa
    Re: RWD
    I'm gonna look for a used center diff that way i have spare just in case i want to go back to AWD. There is one out of a 00 1.8t are they any different than the 2.8?
    Oct 29 2005
    10speed
    San Francisco, CA
    Re: RWD
    Quote Originally Posted by GetAwayFromMe View Post
    same thing
    - Clint
    Mar 09 2004
    nw michigan.
    Re: RWD
    Keep in mind that although the stock drivetrain is overbuilt those rear axles were meant to see about 40 hp each. Not that I think you'll break a lot of parts with a V6 but it bears saying anyway.
    Jim
    I Do Werk.
    Jan 03 2008
    Iowa
    Re: RWD
    Quote Originally Posted by onemoremile View Post
    They do look pretty small, i think i herd them clicking so they might be going out anyway. I was gonna beat on it and do some launches and drifting, it's a $300 car i cant loose to much.
    Mar 09 2004
    nw michigan.
    Re: RWD
    Beat the hell out of it. Let us know what it takes to break it.
    Jim
    I Do Werk.
    Jan 03 2008
    Iowa
    Re: RWD
    How much does a used center diff go for? The guy at the local junk yard does not want to separate which i understand. Anyone has one for sale?
    Apr 22 2007
    Riverbank, Ca
    Re: RWD
    100-200 range for center diff. How much does he want for the whole trani? Its a good idea to keep a spare one if your going to beat on it..
    Senior Member Two Rings audee3's Avatar
    Mar 15 2008
    montreal,canada
    Re: RWD
    i actually have done the rwd conversion to my car and it is alot of funhttp://www.youtube.com/watch?v=xxP6loGqHMg
    Jan 03 2008
    Iowa
    Re: RWD
    Quote Originally Posted by audee3 View Post
    Nice vid. Did you do anything else besides welding the center diff? I was thinking on not even removing the front axels since they wont get any power either way.
    Jan 03 2008
    Iowa
    Re: RWD
    Quote Originally Posted by andyrew View Post
    Around $600 but it's a 1.8t tranny and my is 2.8 so i would probably have to replace the final drive if i was to use that tranny.
    Feb 15 2008
    E46 323i 5-Sp
    616/MI
    Re: RWD
    Not if you're going to make it RWD. The 2.8 has a 3.70 ring gear vs the 1.8T's 3.89. As far as the center diff goes, if you have a one piece put in a a one piece. Same deal with the 2 piece setups.
    As far as welding it up and what not, go for it. I'd remove the front axles, I don't know who said it didn't matter but it does, or should. The other option would be to remove the front half of the Torsen while welding the rear half. Not sure I'd go that route since the input shaft(pinion shaft) for the front diff wouldn't be supported in the rear at that point.
    One last thing. If you remove the front axles, make sure you go to the junk yard and pick up a pair of junk out CV joints. Remove the insides and bolt them in place like a normal CV. This will save your bearings, those wheel bearings need to be held together, not just pressed in.
    Mar 15 2008
    montreal,canada
    Re: RWD
    ya the front axles must be removed as your center diff is now locked leaving them on will remain quattro but locked diff, also i unplugged my abs/traction control to allow wheel spin
    Jan 03 2008
    Iowa
    Re: RWD
    Thanks guys, i will be doing this soon and will let you know how it went.
    Mar 09 2004
    nw michigan.
    Re: RWD
    I was wondering what all was needed to run on a 2wd dyno and this really helped. I assumed it but didn't know it as fact so thank you very much.
    If I wanted to run as FWD on a dyno should I assume that I could swap in a welded diff and remove the propshaft? Seems much quicker since the front end of the shaft has to be disconnected to pull the diff housing anyway. Am I on the right track here?
    Jim
    I Do Werk.
    Jan 03 2008
    Iowa
    Re: RWD
    Another question. Wouldnt i go through tires really fast since both rear tires will be moving at the same time?
    Sorry ONEMOREMILE I'm a noob i this thing so i have no idea.
    Apr 22 2007
    Riverbank, Ca
    Re: RWD
    Your rear axles is not welded solid , just the transfer to the rear is welded solid...
    From my understanding
    Mar 15 2008
    montreal,canada
    Re: RWD
    exactly your rear is not locked it still goes from left to right but only in the rear
    May 09 2008
    '99 A4 TQ aka Michelle
    Phoenix, AZ
    Re: RWD
    audee3...
    first... what year is your?
    second... what exact steps/mods did you do to your car?
    (rear is easy... front is concern. need old axles to hold together? details!)
    i think there are a lot of us looking for a step by step how to!!!
    love the video!!!
    1999 Audi A4 1.8T Quattro 5spd
    Mar 15 2008
    montreal,canada
    Re: RWD
    sorry i didnt take any pics but after i put the center diff back on the car install rear drive shaft. the front axles i did not have a spare set which would of been better but anyway you remove the outer boots and then knock the bearing ends of the shaft with a hammer, now the shafts you wont be needing but the part you removed (with the abs speed sensor ring on it)usually what the boot is protecting you need to bolt that back into your hub so your wheel bearings dont come apart because thats what holds it all together my car is a 96 by the way with a 1.8t
    Mar 09 2004
    nw michigan.
    Re: RWD
    If you weld the center you've still got open fronts and rears. This vid shows why our cars can really use a real mechanical rear diffy.
    http://www.youtube.com/watch?v=92agFA9daQI
    Jim
    I Do Werk.
    Feb 15 2008
    E46 323i 5-Sp
    616/MI
    Re: RWD
    Yes.
    If you weld both the front and rear gearsets of the center diff you will have a straight 50/50 split. Removing power to one of the axles (front or rear, not left or right) will make the trans only power the connected wheels.
    Random thought though, what if somebody only welded the rear gearset and left the front alone? That way the front wheels could spin a different speed for corners, but you'd always have immediate power to the wheels. Instead of being translated by the TBR first.
    Registered Member One Ring DriftNasty's Avatar
    Aug 28 2008
    2000 Audi A4 1.8TQ
    Dothan
    Re: RWD
    so this whole rwd thing can be done to the b5 1.8 too?
    im just curious cause i wanna slide on the real.
    how much would this setup cost?
    Mar 09 2004
    nw michigan.
    Re: RWD
    Quote Originally Posted by djwimbo View Post
    A rear spool would create a lot of understeer and maybe some popping and chunking around tight corners. Definitely not fun on the street and probably not on the track unless talking about drifting, rally, or something along those lines.
    Jim
    I Do Werk.
    Veteran Member Three Rings dmaize's Avatar
    Jan 26 2007
    Saint Paul
    Re: RWD
    does anyone know if you would get better MPG? could it be worth it to switch it in the summer.
    why didn't i buy a rs4 gill when they were $60
    Jun 04 2007
    01' A4 1.8TQM;15' Wrangler
    Austin/DFW, TX
    Re: RWD
    Quote Originally Posted by DriftNasty View Post
    Just man up and learn how to whip it around. haha
    jk, but seriously, why not just AWD drift?
    And for the MPG, i think it would only get like 1-2 mpg anyways./
    BetaAlphaTau Member #12
    01' A4 1.8TQMS 5spd swapped
    My 5-Speed Swap DIY
    - B6 USP
    Aug 28 2008
    2000 Audi A4 1.8TQ
    Dothan
    Re: RWD
    to be completely honest ive never been able to get the car loose.
    and i mean i have whipped that car countless times in the rain and it just wont do it.
    its so damn depressing :\
    but i found a guy who will weld my center diffy for fifty bucks.
    and he said the rear should easily be able to handle 200hp.
    cant wait to go pick my apr chip up :DDDD
    Feb 15 2008
    E46 323i 5-Sp
    616/MI
    Re: RWD
    on stock power the car can barely get out of it's own way. Snow is another story, rain takes some more practice.
    Jun 04 2007
    Austin/DFW, TX
    Re: RWD
    Get an upgraded rear sway bar, and get a small front one.,
    My 5-Speed Swap DIY
    - B6 USP
    Feb 15 2008
    E46 323i 5-Sp
    616/MI
    Re: RWD
    Quote Originally Posted by biketsai View Post
    F- That. H-Sports FTW. I forgot how nasty stock sport suspension was until last week when I got to beat on a customer's car. I thought I had 10 fat chicks in the back.
    Aug 28 2008
    2000 Audi A4 1.8TQ
    Dothan
    Re: RWD
    your sayin a sway bar upgrade will help me slide because from my understanding the sway bars only help keep it level during cornering, now i understand how this could help slide the car but that by itself i dont think will make it nasty sideways......because i know all the drifters i roll with are rockin lsd's and i just wanna be the only audi sliding around.
    and i get no snow in bama. :[
    oh second question, what kinda coilovers should i get if i wanna slam my a4?
    and anyone know a hookup on some rs4 18' replicas?(maybe already wrapped)
    Jun 04 2007
    Austin/DFW, TX
    Re: RWD
    Yea, im not so sure about getting nasty sidewayzz, but that would just give quattro a bad rep. haha. But i know that there are some rs4 reps for sale in teh classified, and if not, ill sell you mine at the right price ;]
    My 5-Speed Swap DIY
    - B6 USP
    Apr 22 2007
    Riverbank, Ca
    Re: RWD
    If you want more grip on the front, tighten the rear. If you want more grip on the back, tighten the front.
    THUS. get the biggest rear sway bar you can get. ALSO upgrade to metal end links AND reinforce your sway bar mounting bracket. If you look at it under the car you'll figure it out.
    If you still have a problem getting it sideways after all that, disconnect the front sway bar (disconnecting one link will do just fine).
    FYI I can go sideways JUUUST fine, and hold it under power (I do a lot of long sweepers at the autox sideways so I can flick it on the next corner).
