Results 1 to 9 of 9
Thread: Spare tire
    Senior Member Two Rings GermanAudi's Avatar
    Jun 01 2008
    2003 Audi A4 1.8T Multitronic
    San Diego, CA
    Spare tire
    I am thinking of upgrading to 18" RS4 reps, but before I do that, do I need to get an 18" spare tire? Right now, I have the stock 15". Also, will an 18" tire fit in the spare tire compartment without modifications?
    2003 1.8T Multitronic CVT, Canvas Beige Metallic
    GIAC Stage 1 || 710N TT Diverter Valve || 6000K Xenon HIDs || VMR Vent Boost Gauge || Eibach Pro/Bilstein Sport Suspension
    Veteran Member Four Rings mattman's Avatar
    Oct 23 2007
    1978 Honda CB400T Cafe Racer
    Ontario, Canada
    Re: Spare tire
    Quote Originally Posted by GermanAudi View Post
    don't bother. If you get the right sized tires you're overall diameter should still be the same...so as long as your using your spare as a spare ONLY, it'll be fine for those few miles.
    Meet Shanice...
    For Sale:
    Stock suspension, slightly damaged stock painted lower front
    Senior Member Three Rings edge19lw's Avatar
    Mar 24 2007
    03' a4 3.0
    Queens, NYC
    Re: Spare tire
    why wouldn't it fit? your just getting a bigger rim not a bigger tire so it wont hav any problems. As for getting a spare rs4 rim you could if you like but it wont make a difference, you can use the 15in rim as a spare (just as long as you dont go with a bigger brake kit)
    2003 A4 3.0 | Trunk Lip Spoiler | CC mod | Bilstein/H&R | RS4 Rear Sway Bar | K&N drop in filter | 23% Tint | Magnaflow 14851's & Magnaflow 10415's
    -Thomas
    Veteran Member Four Rings 617 Bones's Avatar
    Wife's - MK3 GTI VR6 Vortech S/C
    Boston
    Re: Spare tire
    you don't actually NEED an 18" spare, just as long as the 15" spare is the same, or very close, overall outer diameter as your 18.
    Use this calculator: http://www.miata.net/garage/tirecalc.html
    Also, I can fit an 18" wheel with a 235/40/18 tire in my spare tire well... I am an avant though... may want to double check with a sedan owner. Just in case.
    B7 A4 Avant 2.0T 6MT - Arctic | H&R + B5 Perches | JHM S/S + 4:1 Center Diff | Apikol Snub + Rear Diff Mount | Hawk HPS | Tyrolsport Caliper Kit | AWE Exhaust | 034 RSB + Spherical End Links | 19" VMR v710
    In Limbo Four Rings
    Sep 27 2006
    2005 Audi B6 1.8t Ultrasport
    New Jersey
    Re: Spare tire
    is a .6% dif ok or no?
    Buncha motorcycles
    Memphis, TN
    Re: Spare tire
    first off, many audi a4s and s4s come with 18" rims stock (my USP has a matching spare) but i dont even carry it but it fit at any rate
    and even if you have a BBK, just move a back tire to the front and put the spare on the back
    APR Stage 2/AWE Intake
    Feb 15 2008
    AWE powered B6 1.8T
    Severna Park, MD
    Re: Spare tire
    I have a matching 18x8.5 with 235/40/18 as my spare and it fits fine, but pushes the cover up very slightly. Everything noted above is fine but it doesn't hurt to have a matching spare with the same tire and work it into your tire rotation so the tread wear is the same.
    Also if you have the money for the matching spare you won't look cheesy rolling around with 3 18" RS4s and one 15" stocker while you get the tire repaired... just my .02
    Buncha motorcycles
    Memphis, TN
    Re: Spare tire
    Quote Originally Posted by pondside36 View Post
    that would be kraft mac and cheese cheesy!
    Feb 15 2008
    AWE powered B6 1.8T
    Severna Park, MD
    Re: Spare tire
    lol.. FTW Mac and cheese is great.
