    Awaiting Confirmation Two Rings
    Jul 22 2007
    2000 s4 stg 2+, 1996 a4
    Santa Cruz, California
    taillight wiring problem
    i just put on a new pair of stock S4 magneti marelli taillights which included the lens and bulb holder from the partsbin.com on my car. now when i use my turn signal or flashers the clear white reverse light comes on instead of the red strip right above it. when i put the car in reverse no light comes on at all. could this be because the previous owner put tinted A4 taillights from ecstuning.com on the car and had them programmed in? any help would be greatly appreciated. i dont want to reverse into someone in a parking lot
    thanks
    Veteran Member Four Rings infinkc's Avatar
    Feb 14 2004
    S Ã C, CÃ*
    Re: taillight wiring problem
    what do the lights look like that you took off, if they are the pre facelift ones then they were probably rewired. Do any of the wires look spliced?
    Jul 22 2007
    nothing appears to be cut. the taillights the previous owner put on were these
    thanks for the response
    Jun 30 2008
    Vancouver
    You need to re-pin the plugs. I remember I had to switch one of the pins but don't recall which one. you have to use a multimeter to find out and no need to splice the wires the pins can be pull out.
    Jul 22 2007
    so do i touch red rod to pin A and black rod to corresponding pin A2 to test for a light response while the battery is connected and my blinkers, reverse lights, etc. are engaged? i've only used a multimeter on guitar amps. thanks for the help
