Results 1 to 7 of 7
    Veteran Member Four Rings Molotov's Avatar
    Feb 24 2007
    2005 USP 1.8TQM Avant
    Burlington, Vermont
    So, what do I do about this? LAMBDA CONTENT
    UGH lean much? Actually did a 3rd gear pull this time. CFs look really good on t4.. think I could bump that up a bit
    some info: 57 degrees outside and 77% humidity. Only did 1 pull, which is good considering the data. I think I had it at b8. I'm also leaking boost somewhere, only peaking 19psi holding about 18. Could that be throwing my data off? (would think it'd have a better chance of running rich than lean by losing boost)
    Where do I go from here?
    - Scott
    Das Build Thread
    Performance parts for sale:
    MagnaFlow Race Muffler - Vibrant 4" Filter - MAF 4" Housing
    Veteran Member Four Rings F16HTON's Avatar
    Jul 04 2004
    992 Carrera
    Makai - Kaka'ako
    Re: So, what do I do about this? LAMBDA CONTENT
    Log blocks 031 and 032
    Jul 07 2004
    630AWHP A4, Nissan Titan
    socal
    Looks like it needs more timing.
    Veteran Member Four Rings JMRQuattro's Avatar
    Jul 04 2008
    Seattle, Washington
    i'm sorry to be a newb but could somebody explain to me what this chart means so i can understand what's happening??
    Jul 07 2004
    socal
    Block 020 is Timing Correction Factor, it shows how much timing is being pulled back in each cylinder. It is best to see some timing pull, you want to keep it as low as possible without going over 6.
    Feb 24 2007
    Burlington, Vermont
    yeh problem is when I use my sps3 the ecu doesn't take to the settings. I'm starting to feel mentally challenged
    - Scott
    Das Build Thread
    Veteran Member Four Rings NightRoller USP's Avatar
    Aug 23 2008
    2008 Rs4
    I looked at the temp. and humidity and figured you were from the 802
    Nice to see another vermonter
    Jacob
    AWE ll APIKOL ll PODI
    USPCLUBMEMBER#190
