Results 1 to 17 of 17
    Veteran Member Four Rings NastyNogaro's Avatar
    Oct 31 2006
    2008 RS4 Exclusive/Premium
    Can you fit a 245/40 on an 18x8 RS4 DTM wheel with no issues?
    My Contisports are starting to get balder than a brazilian waxed happy valley. Am I going to have rubbing issues or anything of that sort, and also, can I squeeze a 245 on there without it creating a bubbly effect for a sidewall?
    Also, if anyone has pictures of their setup, feel free to post. The wheels are a Hartmann RS4 DTM rep, 18x8 with a 35 offset. Tires now are 235/40 continental contact sports.
    I would love more meat for the winter season, but if it's going to be too much of a hassle, I'll probably stick with what works.
    Side note, if I do have to roll the fenders, my uncle told me about a good tool that attaches to the wheel and you just turn it and the tool does the rest. Anyone heard of this, or is he bullshittin me? He builds and races chevys in Nopi for a living so I'd assume he knows his shit.
    thanks guys
    Edit: pic of wheels for reference. (other car is tiker0z i think)
    "Fazz" | Interactive Web & Application Developer | ig: @turbofazz
    2007 911 Turbo 6MT
    2015 Nogaro S4 DSG - Sold
    2008 RS4 Exclusive/Premium - Sold
    2000 Nogaro S4 6MT - Sold
    Jan 29 2007
    08 S4 00 S4
    MD
    Re: Can you fit a 245/40 on an 18x8 RS4 DTM wheel with no issues?
    I'm pretty sure you're gonna have issue running those wheels with those tires, but there's a fender roller for ya:
    http://www.4induktion.com/catalog/pr...23bd9cc573953b
    Senior Member Three Rings xx_s4quattro_xx's Avatar
    Mar 11 2008
    00 s4 and 00 bimmer 323ci
    san diego ca
    i have 235 40 18x8 on mines and that thing is cutting the shit outta my front tires.
    Oct 31 2006
    Quote Originally Posted by xx_s4quattro_xx View Post
    huh? what thing?
    As my car sits, the inner fender wells now have gotten eaten up pretty bad. I could certainly use new ones.
    mholme: awesome post. Thanks for that link. Would you recommend I do this? I hope I don't f anything up..
    2007 911 Turbo 6MT
    Aug 06 2008
    Canadia
    the manufacturer of the tire will probably be the most important, what the claimed width is on the sidewall and the tires footprint are always differant from one manufacturer to the next, what i would do after you decide what brand tire you want is to go to the manufacturers website, and hopefully they list the physical dimensions of their tires there, then see what kind of clearance you will have comparing the specs off the website to your current tires.
    Mar 22 2005
    2019 RS5 SB / 2017 Jeep SRT
    FL
    If you're gonna go with a 245 you'll need to go with a 245/35. 245/40 will likely be tall and rub on the fender and maybe even the uprights. Obviously this will be tire dependant, since some tires run wider than others. But I very rarely see people running 245/40's because of the rubbing issues.
    Oct 31 2006
    Here's the specs guys:
    Specifications for tire
    UTQG: 280 AA A
    Max Load: 1389 lbs.
    Max Inflation Pressure: 51 psi
    Tread Depth: Oct-32"
    Rim Width Range: 8-9.5"
    Meas. Rim Width: 8.5"
    Section Width: 9.8"
    Tread Width: NA"
    Overall Height: 24.8"
    Revolutions per Mile: 830
    From Continental.
    What do you think? Says 8-9.5...
    2007 911 Turbo 6MT
    Feb 12 2008
    01' S4/ 98' Boxster
    Lake Oswego/Corvallis
    I just Put on my new DTM's today. I am running a 225/35/18 and it fits just right, and looks amazing. Just go with what works, you'll be happy you saved the money and the headache in the long run.
    Jan 29 2007
    08 S4 00 S4
    MD
    Quote Originally Posted by Daness373 View Post
    Why 35 and not 40 if you were staying with 225 anyway?
    Active Member Four Rings
    Dec 11 2006
    Boston
    To be honest Mark, much of it depends on the actual tire itself, as some tires have more sidewall than others.
    When I had the reps, they were an 8.5" width and I ran a KDW2 at 235 and had tons of meat left over. If I ran a 245 it would have been that sidewall look you don't want. But if I had ran a different tire, perhaps a non drag radial, it might not have a side wall so deep.
    However! On my SL's that are 8", I plan to run a DR that is a 245. But that all depends.
    On top of that the, 235's rubbed like a slut, but that has more to do with offset.
    On another side note, I'ma call you tomorrow. I missed your call today, but Clint is going back to school this week. He said he can do it on an upcoming weekend, if you are cool with that. I'll give you a shout tomorrow. (assuming I remember)
    Stage 3+ RS6's
    Feb 12 2008
    01' S4/ 98' Boxster
    Oh sorry i meant 225/40/18. ha Go with that
    Oct 31 2006
    ^ There's no way I would go to a smaller tire than what I have now.
    I'm gonna try to make the 245 contisport II's work. I'll keep y'all updated when I get em.
    Derek: Call me whenever. Would love to get it done asap.
    Thanks for the responses guys.
    2007 911 Turbo 6MT
    Mar 11 2008
    san diego ca
    the inner fender. That thing cut a whole different thread for me lol.
    Mar 09 2004
    99.5 A4 Avant, 01 allroad
    nw michigan.
    245/35-18 is a good fit as long as your fenders are rolled and your wheel has et35 offset like most of our 8" wide wheels.
    I ran 245/40-17 last winter and never had any problems. It actually had more inner clearance than 225s on stock wheels. My fenders are rolled flat and sealed which was very important. I cut the horizontal portion of the plastic inner liner to tell when a tire was interfering with the original fender lip position. It rubbed when coming down after a speed bump. I cut the liner an inch higher and it never touched again. This was on stock 1.8t sport suspension which is lower than S4 stock suspension.
    http://s23.photobucket.com/albums/b3...t=IMG_4882.jpg
    http://s23.photobucket.com/albums/b3...t=IMG_4886.jpg
    http://s23.photobucket.com/albums/b3...t=IMG_4883.jpg
    Jim
    I Do Werk.
    Oct 31 2006
    onemoremile
    Great post. I am definitely sold on 245's for my next tire setup. I do infact have 18x8 et 35 wheels so I will pick that fender roller tool up that mholme posted and go to town!
    2007 911 Turbo 6MT
    Mar 22 2005
    FL
    Continentals run very wide. 245's in the conti's are 255's in other tires. Ah10 on Audiworld has 245/35/18 Continental contact patch 3's on his S4 and they took a lot of work to fit. First he needed the right offset so they wouldn't rub the upright (ET 32 on his 18x8.5 Works) and he also needed to cut the fender lip and then roll what was left, so he wouldn't rub.
    I had 245/35's pirelli Rosso's on my ET 38 work emotions and they fit fine, with no rubbing. So ya, it really depends on the tire. But from what I've seen the Conti 245's will take some work to fit. Not to mention they are freakin expensive.
    Oct 31 2006
    Quote Originally Posted by Dr. Jekyll View Post
    Gotcha. Any recommendations for a decent all season tire that won't set me back as much, and will actually fit on an 18x8 et35 without a major problem?
    2007 911 Turbo 6MT
