    Aug 03 2008
    Yeovil
    Allroad tip gearbox issue
    Howdie folks.
    Audi Allroad with the auto/tiptronic box.
    When im in top gear and accelerate it sometimes jumps to 4th then back to fifth then back to fourth and so on
    Is this the symptom of something serious?
    Cheers All
    Rob
    Feb 17 2004
    Sterling, VA
    Re: Allroad tip gearbox issue
    You could have a flakey RPM sensor on the transmission or even the transmission range switch could be going south too.
    You might be able to see some soft codes from the TCU if you check for codes.
    Brett - Moderator
    Issue?: email me.
    _____________________
    Stage 3 2004 A6 2.7T 6M
    Aug 03 2008
    Yeovil
    Cool, I have a VAGCOM but as yet I am unable to get it working. I will make a concerted effort and get the codes checked. Cheers for the help.
    Rob
    Veteran Member Four Rings MYDWAGON's Avatar
    Jul 08 2007
    Ohio
    Torque converter failure is common
    04 4.2 Allroad w/H-Sports-Full Tint-Armorcoat- RS6 Exhaust/Gutted Kitty-Flaps-Michelin Pilot Sport A/S Plus-Thule Box-OEM Trailer Hitch-226k
    Senior Member Three Rings ckpepper02's Avatar
    02 Allroad 2.7T - Alpaka Beige | 07 Passat 2.0T
    Fuquay, NC
    My tranny is not letting me apply gas in reverse. I can back up reaaaally slow, but if I apply gas, nothing.
