Results 1 to 3 of 3
    Registered Member Two Rings
    Jan 03 2007
    Atlanta
    DV hose diagrahm
    Does anyone have a diagrahm of the hoses that connect to the dv? i've searched but i can't find it. the hose that connects to the tip needs replacing and i will NOT (i hope) pay the dealer for that hose. If anyone has one lmk. mine is cracked etc time for replacement.
    Active Member Four Rings Jung's Avatar
    Jul 07 2007
    Tempe, AZ
    Re: DV hose diagrahm
    are you talking about the vacuum line coming off of it? if so it's available at any autozone. i believe it's 3mm.
    '07 S4 Avant - The Purpetrator
    there's just something about her, maybe it's her awful accent but i've always wanted to tonguepunch her fartbox - cruz
    Jan 03 2007
    Atlanta
    Quote Originally Posted by jungb5s4 View Post
    nope not the vacuum line. the best way i can explain it is this. if i'm taking the stock dv off, and installing a 007, when i turn it reverse, the hose that the dv goes into faces the ground.
