Results 1 to 9 of 9
    Dec 05 2007
    Coilover Question
    I just saw a pair of B&G coilovers on ebay. They are brand new, but the kit is missing some peices. But for the price, I figure get them and then source out the extra peices needed. Can you tell me what else I would need (by observing the photos from the advertisement) for the set? And the average price of the missing peice(s) may help also.Thanks!
    Link
    Mar 09 2004
    99.5 A4 Avant, 01 allroad
    nw michigan.
    Re: Coilover Question
    Don't bid on them until you're sure you can get the pieces.
    I bought used Bilstein HD struts knowing one was missing a lower mount bushing. No Bilstein distributor could get the parts including their two national distribution hubs. I ended up ordering Energy bushings and having aluminum bolt sleeves turned out on the lathe.
    Jim
    I Do Werk.
    Dec 05 2007
    Thanks for the advice. I will take heed.
    Mar 09 2004
    nw michigan.
    Two things;
    1) There are three front spring collars shown. This one collar looks like the only part missing. Adjustment wrenches aren't shown but they are easy to get and aren't always necessary. I like using the strap wrenches like plumbers use.
    2) 2001 and up usually means B6 fitment since they were 2001 and up in Europe. Suspension listed for a B5 is usually listed as 96-00 or 96-01.
    Jim
    I Do Werk.
    Veteran Member Four Rings pipe7284's Avatar
    Sep 14 2006
    `07 Audi A4 S-Line 6MT Quattro | '01 Audi S4 AVANT 6spd
    Lansing, MI
    that is definatelly for a B6 chassis A4. I ust installed a set of stassis coilovers on my friends B6 and thats how the rear springs look. On the rear of the B6 the strut is installed separate from the spring. on our B5 the springs actually goes on the the strut, like the front does.
    Buy my coilovers i have for sale check my sig
    '01 Audi S4 6spd Black AVANT DAZ E85 Tune Frankenturbo F21s / 034 RS4 inlets / BOSCH EV4 72# injectors / Walbro 450L fuel pump / Daz 89mm maf housing / AFE Intake Cone / SRM SMICs / 034 street density trans and motor mounts / SSAC downpipes / Vibrant catback exhaust / H&R Ultra Low Coilovers / 18x9.5 Rota Grids / 17z Brembo front BBK / 034 Rear BBK / JHM Short shifter / JHM stg 3 clutch / PODI Boost gauge / [/CENTER]
    SOLD
    Veteran Member Four Rings Nebone's Avatar
    Jan 21 2006
    6MT BT Avant Ti
    RI
    You're selling FWD coils; he has Quattro.
    Ibis White 2008 Audi A4 2.0T Avant 6MT S-Line Titanium APR Stage 3
    Deep Sea Blue Pearl 2010 Audi A4 2.0T Premium Tip
    Dolphin Grey 2005.5 Audi A4 2.0T Avant 6MT *Sold after 7 years of ownership*
    Goodwood Green Pearl 2002 Audi A4 1.8T Sedan Tip
    Santorin Blue Pearl 2001.5 Audi A4 1.8T Sedan 5MT *Sold after 9 years of ownership*
    Sep 14 2006
    Lansing, MI
    they wont fit?
    SOLD
    Veteran Member Three Rings creechsa4's Avatar
    Jan 06 2005
    san diego
    the front will fit, however the rears will not. no spring collar and the strut is too long (b6). plus the bottom link is too wide to fit on the a arm.
    82mm je pistons, scat rods, ported & polished aeb head. gt2871r, atp hi flow manifold (ported). 580cc injectors on custom giac tune. Once you boost, you'll never go back....
    Sep 14 2006
    Lansing, MI
    ^^^^oh ok. thanks for the clarification.
    SOLD
