Results 1 to 40 of 41
    Dec 06 2007
    No Boost Help Please!!!!!!!
    I drove today and everything seemed fine i drove 4 miles today and on the last 2, my turbo builds 10 pounds of boost and then dumps it back to zero. What the hell???? it doesn't sound like there are any leaks, no dentist drill noises nothing, and no CEL PLEASE HELP!
    -Kirk
    BetaAlphaTau Member #58
    Dec 06 2007
    Re: Help Pronto My Car Is Possessed!!!!!!!!!!!!!!!
    please help.
    -Kirk
    Dec 06 2007
    no one cares about me anymore??
    -Kirk
    Registered Member Three Rings SlappyB6's Avatar
    May 14 2008
    W-S, NC
    Re: No Boost Help Please!!!!!!!
    I'm definitely no expert, but it sounds like a vacuum pressure loss somewhere. My first stop would be to double-check for leaks.
    02 A4 - 5spd - Sport - VM DP
    Capt. Obvious - "Not me. I fart rainbows, shit rose pedals and piss excellence."
    Dec 06 2007
    thing is it boosted fine, then all the sudden, it boosts and then the turbo kinda turns off.
    -Kirk
    Veteran Member Four Rings kwimberly's Avatar
    May 03 2008
    Orlando
    I'm bone stock, and mine does the same thing. Thought it was normal. lol Get to 10 after pulling hard, then it drops.
    Kevin W.
    2003 A4 1.8T quattro 5-spd. | USP lower | APR ECU w/ TT225's | APR TIP | test pipe | FMIC | Apikol snub | ecodes | Podi® | AWE sport pedals | JHM SSK/linkage | Forge 007 DV | '02 OEM sport suspension | OEM sport wheels | B6 S4 brakes w/ TyrolSport stiffeners | RS4 rear sway bar| Magnaflow 14829's| AVIC F700BT | hard-wired Passport 9500 | Side-mount trash bag hanging from shifter
    Dec 06 2007
    ^^i'm not bone stock and it is suppossed to boost 21 PSI, it turns off. if i climb a hill it is boost no boost boost no boost....
    -Kirk
    Veteran Member Four Rings widgget's Avatar
    Dec 18 2007
    nj
    i'm not expert here but if your boost is dropping it could be due to the waste gate opening, this would be caused by the N75 being stuck closed and as soon as you build up enough pressure to overcome the spring in the actuator then the waste gate is getting thrown open and you loose your boost.
    Again, no expect but that is where i would look, i've replaced two N75 valves so far.
    Senior Member Three Rings demea's Avatar
    Jun 12 2008
    2004 A41.8q | 05 Tr. Blzr LT
    Warminster, PA
    Whats the Mercedes Benz dealer say ?
    Sounds like a nice vacuum leak. Is your car real loud upon a cold start?
    DV shot maybe?
    2004 Moro Blue A4 1.8TQTip
    GIAC | Genesis | Forge | Magnaflow | RS4 | ABT | Sport | Premium | Cold | Dings mod ~ Painted lowers are overrated
    Want to see a fun coverband in the Philly area?
    Dec 18 2007
    nj
    Quote Originally Posted by AudiA4Turbo22 View Post
    yeah, sounds like the waste gate is opening once it gets to a certain boost level, the GTRS actuator is set for 14psi i think (ie: 14psi to overcome the spring an open the waste gate) it might be part open before then though, i'm not sure.
    Established Member Two Rings b6quattro's Avatar
    Jul 08 2008
    '03 A4 1.8t Quattro 5sp
    Orlando, FL
    What were the rpms when it fell off?
    '03 A4 1.8tqm - Brilliant Black on Tan
    Apikol Snub
    S4 Rear Sway
    Cold Weather Package (perfect for FL!)
    Sirius Sat. Radio
    May 03 2008
    Orlando
    at least my bump got you some activity!
    Kevin W.
    Senior Member Two Rings skizsam's Avatar
    Apr 28 2007
    Fairfield, CT
    2002 1.8T A4QM
    APR stage 1 | SouthBend Stage 1 | Reiger | BBS | Remus | AWE Boost gauge
    Dec 06 2007
    it's not a boost leak, it makes no obseen noises and isn't loud, thanx kwimberly, haha i just changed my N75 about 6 months ago, i guess i should try unpluging it and see where i get.
    -Kirk
    Jun 08 2007
    Orlando, Fl
    My car was constantly going into limp mode after installedy GTRS before i hd it programmed. It sounds exsctly like what you are describing. I also never had a cel during it.
    BetaAlphaTauMember #39 GTRS Powered/Revo Tuned
    Veteran Member Four Rings MultiAudis's Avatar
    Mar 12 2006
    01 Allroad 6mt, 01 A4
    NoVa
    sounds like the wastegate to me
    Veteran Member Four Rings aaaudiprotein's Avatar
    Apr 16 2007
    2003 RS6
    Chicago Burbsss
    You make boost, but it doesnt hold it, so i think either westagate or your diverter. Make sure it is connected good.
    BLACKHAWKS 2010, 2013 and 2015 STANLEY CUP CHAMPIONS
    Windows 7 WAS MY IDEA
    Dec 06 2007
    Quote Originally Posted by A4Dit View Post
    exactly, i'm still running the K03, it boosts then dumps all the pressure.
    -Kirk
    Dec 06 2007
    Quote Originally Posted by MultiAudis View Post
    exactly what i'm thinking, how can i fix this?
    -Kirk
    Feb 15 2008
    AWE powered B6 1.8T
    Severna Park, MD
    What kind of DV are you using Kirk?
    Dec 06 2007
    ^^2 month old 710N
    -Kirk
    Feb 15 2008
    AWE powered B6 1.8T
    Severna Park, MD
    I would test that first being the easier route.. and if failed upgrade to a Forge or other piston type. Diaphram anything is inherantly prone to failure...
    Dec 06 2007
    ^^i mean it is holding boost fine up to 10 pounds then just dumps it to zero for no reason. the DV is very strong still i had one on here for awhile before i changed just for the heck of it.
    -Kirk
    Feb 15 2008
    AWE powered B6 1.8T
    Severna Park, MD
    It is strange.. but isn't the KO3 internally wastegated? Checking the DV, checking for boost leaks and what would be first to eliminate the easy stuff before you start tairing into the turbo stuff... just my .02
    Veteran Member Three Rings nihil's Avatar
    Oct 01 2007
    Too small
    N/A
    I had a similar problem last week, except my boost was falling off gradually rather than a sudden cut out (but then, I'm stg1/k03). There were two of those braided sheath vacuum lines that had gone to shit, IM to DV, and IM to <something mounted under IM>. Replaced both lines and it was good to go.
    2002 A4 1.8TQMS (sold)
    1982 MB Geländewagen 300GD
    1968 Charger R/T
    1987 Porsche 944 (sold)
    2015 Tacoma TRD/OR
    2007 4Runner
    2022 Tenere700
    2009 TW200
    Dec 06 2007
    All Vac Lines And Check Valves Are New. This Sux Up The Rear.
    -Kirk
    Dec 18 2007
    nj
    i've got money on the N75 being bad.
    it makes even more sense that your falling off at about 10psi if you have a K03 still since the spring pressure is going to be less then the 14psi on the GTRS actuator.
    Every time you get to 10psi you have enough pressure to over come the spring in the actuator and it releases the pressure, as soon as the pressure is released the waste gate is closed by the spring in the actuator and then you build up again until you get enough to reactivate the actuator. This is what is giving you the "boost, loose all boost, boost, loose all boost, ect, ect...."
    If you had a piston type DV then i might question that, but a diaphragm DV is not going to build up till 10psi and then dump it all at once if it has a tear in it (it would just leak steadily) what you are seeing is what you would expect from a piston DV that has a bad line going to the top of it to hold it closed or if the spring in the DV wasn't providing enough resistance. i wouldn't expect this to be the issue so i wouldn't spend to much time screwing around with the DV, although a nice piston DV woudl be a good idea before you install the GTRS.
    Veteran Member Four Rings RLB6's Avatar
    Sep 20 2006
    '05 MV Agusta F4-1000
    MD
    VAG-COM. Check the duty cycle of the N75 valve. Second thing to check is the DV. Third thing to check is vacuum lines.
    Current: '23 etron-GT | Prestige
    Previous: S5 | Prestige
    Dec 06 2007
    ^^u rule man(Widdget), i hope it is the N75, i'll check tonight ad it is an easy fix, i remember, when i was installing the new N75 when i blew through one hole it kinda leaked, maybe it was the problem, does the dealer have warranty on these things?
    -Kirk
    Dec 18 2007
    nj
    Don't know about a warranty on part from the dealer, i got my first N75H (H is the "race" version, just holds boost longer) valve from ecs tuning and the second i picked up here in the classified. but yea, mine was leaking like you just mentioned so i replaced and and it's much better now.
    Feb 15 2008
    AWE powered B6 1.8T
    Severna Park, MD
    NIce explanation Widgget, that makes perfect sense... Good luck and let us know what was the issue..
    Dec 18 2007
    nj
    thanks guys, just trying to spread what knowledge i picked up from everyone else here. I try to explain whats going on (or at least how i understand it to work), personally i want to know why it's not working not just what to replace when something isn't working right.
    RLB6 had a great idea if you have vagcom, although i am not sure if the duty cycle will still register correctly if it's stuck since the power to the solenoid will still be present. does anyone have input/comments on this?
    let us know what you find Kirk.
    Dec 06 2007
    ^^u got rep
    -Kirk
    Established Member Two Rings utripn's Avatar
    Jul 13 2007
    2006 Audi A6 4.2 S-line
    Mission Viejo
    get a new N75 valve and call it a day, then check your diverter valve and move on. It happened to me and it was the N75 valve, go to 034 motorsports and get the race version. all done.. see it was not that bad :)
    Dec 06 2007
    Well guys luckily i had my old N75 in my garage and everything was fine, except i recently changed my 02 sensor and i shifted into reverse today and the car stalled, ran it real hard and tested and all is well.
    Thanx WIDDGET!!!!!!!
    -Kirk
    Feb 15 2008
    AWE powered B6 1.8T
    Severna Park, MD
    Nice...
    Buncha motorcycles
    Memphis, TN
    1+ cars seem to over boost and go into limp mode with the race valve
    APR Stage 2/AWE Intake
    Dec 06 2007
    ^^i'm using the C valve i think, came on 02's only i'm gonna raise hell at the dealership about their part.
    -Kirk
    Dec 18 2007
    nj
    Great to hear you got it resolved! how much longer until you get the new turbo in there?
    Quote Originally Posted by Papachristou View Post
    Thats what i would expect and i'm not debating you, but from experience mine never did over boost using the N75H with APR S1+ or S2, and now i'm on Revo S3.
    i'm sure it happens though.
    Dec 06 2007
    ^^AS SOON AS I SELL MY WHEELS. Now there is a new problem, i shifted into reverse yesterday and my car turned off, today the car is bucking? if i leave a light it goes power...no gas...power...no gas....power, changed my O2 last week i hate this car with a passion.
    -Kirk
