Results 1 to 40 of 51
    Veteran Member Three Rings XCELR8's Avatar
    Jan 23 2008
    NW Indiana
    So I installed the LED bulbs in licence plate.... no light out error
    Bought the exact things in this thread to do the mod
    http://www.audizine.com/forum/showth...ight=LED+plate
    I put the bulbs in first and thought I'd turn the lights on and see if the bulb out warn came on w/out installing the resistor. Put them in, no error. Drove it around the subdivision still no error on dash. Does it take a while for the system to recognize them not being there? I also pulled one of the bulbs out completely and still didn't get an error message. Is it possible I don't need the resistor I bought? They work and look great. Just wondering why I don't have any errors showing.
    Does this mean I can swap out my 194/168 city lights with LED's also?
    Senior Member Two Rings gervi's Avatar
    Nov 20 2007
    2006 Audi A4 2.0T
    Winnipeg, Canada
    Re: So I installed the LED bulbs in licence plate.... no light out error
    Just wondering if you have the Color DIS? If you don't, then I don't think it will show a bulb out.
    Senior Member Three Rings edwardabodnar's Avatar
    Mar 08 2008
    Miami
    Thumbs up Re: So I installed the LED bulbs in licence plate.... no light out error
    Post Pix
    Veteran Member Four Rings ibiski's Avatar
    May 21 2008
    what year is your car?
    Veteran Member Four Rings cstarky15's Avatar
    Feb 16 2008
    Oakdale, MN
    do they flicker?
    The usual things!!
    Resistor Install
    Jan 23 2008
    NW Indiana
    Quote Originally Posted by gervi View Post
    No color display on the dash. Just shows miles till empty, radio channel, and a quick system check via the check button on the dash. Pretty basic dash layout.
    Quote Originally Posted by ibiski View Post
    06 Preim pack. Nothing special
    Quote Originally Posted by cstarky15 View Post
    do they flicker?
    Not that I've noticed. I'll post pix tonight if I remember.
    Veteran Member Four Rings redlabel81's Avatar
    Nov 24 2007
    A4 1.8TQ 2005.5 + A6 1.8T 1998
    Tromsoe, Norway
    Have you installed both the bulbs? Had just one bulb installed and then it didn't flicket, but as soon as I put in the other one it started flickering.
    What bulb excactely did you buy from autolumination? There are so many different bulbs!!!
    E
    Life is too short to drive ugly cars!
    Phantom Black B7 A4 1.8TQ Avant
    //BSR PPC stg 1, 98 Oct//BSR cat back//S-line front rebuild//S-line suspension//Supersport loweringcaps//Votex valence//S4 doorblades//RS4 mirrors//S-line roofspoiler//S-line door sills//LED interior//Hoen fogs//mTec 6000k HID//RNS-E//S4 grill//MMR HR4//H&R 8mm//Dectane HL//LED licenseplight//Euro RS4 steering wheel//Sonniboy "Tint"//RS4 rear sway//
    Jan 23 2008
    NW Indiana
    Quote Originally Posted by redlabel81 View Post
    E
    Both are in there, bought the 39mm 9 LED super white festoon bulbs. I'll check again tonight to make sure they are not flickering. I might not have noticed that last night. Guess it can't hurt to put the equalizer in anyway.
    Established Member Two Rings hhuynh14's Avatar
    Jul 01 2008
    2008 A4
    Orange County
    are these the ones you got?
    Jan 23 2008
    NW Indiana
    no these..
    39mm = 1-1/2" Long 9LED
    Order Festoon Dome Bulbs (shown above): $6.99 ea.
    Replaces: 3423 3425 6411 6418 6423 6461
    Mar 17 2008
    2007 A4 2.0T Tip
    arlington, Va
    thats false, I dont have the color display and i got a bulb out warning when trying to change license plate lights to LED. I ended up getting the Hoen bulbs and they work great.
    Veteran Member Three Rings pretarion's Avatar
    Jan 02 2007
    Plano, Texas
    Apparently 06's are OK to have LED's in them without resistors. I have SMD LED's in my 06 A3 without any problems or codes, however, I can't have them in my 08 A4.
    The best thing to do is vag it and see if there is any soft code.
    Good luck
    2012 Audi TTRS Carbon Package
    Registered Member Three Rings SGVA4's Avatar
    Mar 03 2008
    07 3.2 Quat SLine, 08 MKV SE
    626 SoCal
    Quote Originally Posted by MYaudi View Post
    where did you get the hoen bulbs??
    Work Euroline FS/Falken/Cupra R/HID yellow fogs/H&R/Eibach/Bilstein/Apexi/Optic Black RS4 Grill
    Hoen plate bulbs/ZiZa city lights/RS4 foglight grill coming soon!!!
    "J Spec B7"
    Mar 17 2008
    2007 A4 2.0T Tip
    arlington, Va
    Quote Originally Posted by SGVA4 View Post
    http://www.hoen-usa.com/licenseplate.htm
    Hoen license plate bulbs
    2007 A4 2.0T Tip Black on Black
    -35% tint
    -debadged
    -black out side markers
    -black out grill
    -red led dome/footwell bulbs
    Jan 09 2008
    '03 BMW M5, '02 Z06; '12 Street Triple R; '03 V-Star 1100
    Crystal Lake, IL
    Quote Originally Posted by pretarion View Post
    Good luck
    This would be fantastic news since I really want to rid my car of 'standard' bulbs
    Veteran Member Three Rings Kid Red's Avatar
    Feb 05 2008
    Orlando, FL
    Good luck
    I don't understand this. From what I understand the entire point of the equalizer is to handle the excess wattage that the low wattage LED does not need. That power/voltage whatever needs to go somewhere and without an equalizer the LED would heat up and over time, would fail.
    Forgive me if I'm wrong here.
    2010 BMW 335i Sapphire Black + Black leather interior + Sport + Nav + PDC. Mods - Carbon Fiber wrapped interior - Gloss Black grill - 15% tint - more coming
    2006 A4 2.0T Quartz Grey + Black leather interior + Convenience. Mods - 19" VM RS4 reps - FK Silverline coilovers - APR 93 - Navigation - S4 mirror caps - S-Line E-Codes/Bi-Xenons - XenonMatch Hoen Fogs - RS4 sport pedals - LED License plate lights - black grill - 15% tint all around & More mods coming.
    Feb 16 2008
    Oakdale, MN
    well if someone for sure can see if the 06 is fine without the resistors that would be sweet. I don't feel like spending $20 on 2 bulbs and have them flicker!
    The usual things!!
    Resistor Install
    Feb 05 2008
    Orlando, FL
    Resistors are like $5. I have the LED lights and the 1 resistor and I have zero issues, no flickers and no warnings. $5 isn't much for piece of mind. I have an 06.
    Jan 02 2007
    Plano, Texas
    Again, I have an 06 A3 without resistors. Been on LED's for 2 years without any Bulb Warning Light. Maybe the wiring is different on the A3 compared to the A4, but I doubt it.
    Mar 03 2008
    626 SoCal
    Quote Originally Posted by Kid Red View Post
    ok
    where did you get the resistors and what kind? and while your at it please kindly point out which led bulbs you bought?
    TIA!
    "J Spec B7"
    Active Member Two Rings vedran's Avatar
    Jun 25 2008
    Norway
    XCELR8, did you check how hot are they after let say half hour of working?
    Jan 23 2008
    NW Indiana
    Quote Originally Posted by vedran View Post
    Not hot at all, they aren't flickering, and no light out error. I have to buy some bulbs for my boat from that site. I'm going to try them in my city lights and if all is good I'll buy some for those as well.
    Veteran Member Four Rings airbornerifleman's Avatar
    May 20 2008
    2013 Passat TDI
    Toronto Ontario, Canada
    So from what I gather guys with the 06 A4 have no issues putting LED bulbs in their car without resisters. I have a 06 A4 with the color DIS and would love the effect of instant on/off of all my marker lights by changing them from incandescent to LED. Has anyone done this kind of setup before?
    Veteran Member Four Rings a4dc89's Avatar
    Nov 07 2007
    Land Rover Disco I
    Washington DC
    yeah, bump on that 2006's dont have that problem then i could buy city lights w/o resistors. can someone confirm?
    2006 A4 B7 2.0TQ Dolphin Gray Metallic 6MT
    REVO Stage II, 034 HFC, AEM turbo inlet/intake, OEM Piston DV, BSH PCV Fix, HID Fogs/Fog Mod, AWE Boost Gauge, Debadge
    All go no show
    Veteran Member Three Rings Echo3One's Avatar
    Apr 02 2007
    Phoenix
    Quote Originally Posted by a4dc89 View Post
    Someone correct me if I am wrong, but I believe some have tried it and they were getting to hot and burning the housing.
    2021 Audi RS7 | Nardo Gray | Cognac Interior | Carbon Optic Package |
    |Eventuri Carbon Intake System |Akrapovic Evolution Titanium Exhaust | CETE Active Air Suspension Lowering Module |
    2010 Audi S5, 6-SMT | Meteor Gray | Prestige Package | Magma Red Interior |
    | APR Supercharger | STaSiS Exhaust | STaSiS Touring Suspension | STaSiS Cast Wheels 20 x 10 |
    May 20 2008
    2013 Passat TDI
    Quote Originally Posted by Echo3One View Post
    I think ppl that put the hoen city light got some melting but I doubt LEDs will heat up enough to cause any issues.
    Someone please confirm that LEDs w/o resisters on a 2006 A4 color DIS does not give any problems. I am so excited.
    Veteran Member Four Rings Dangler's Avatar
    IDK if this helps any....but i have a 06 a4, pretty much base model 2.0t quattro, and i took the bulbs out for the license plate and went to turn them on, and recieved no bulb out warning.
    I plan on replacing all interiors with leds, and maybe try the led bulbs in for the tail lights, see what happens
    PRIME MOTORING
    F.T.W.L.T.B.D.W.I.C.T.W
    Jan 02 2007
    Plano, Texas
    My 06 A3 does not have the color display, and I have NOT tried the LED's in the city lights. I only have them in the license plates. I can only confirm no bulb warning on the license plates.
    May 20 2008
    2013 Passat TDI
    Quote Originally Posted by audinoob06 View Post
    Do you have a color DIS? Post a follow up after installing LED tail lights.
    2006 Audi 2.0T quattro Tiptronic
    APR Stage 2+
    OEM+
    _______________
    2013 Passat TDI
    Apr 02 2007
    Phoenix
    Here's an other option. I have the Xenon standard interior kit with all options installed in my 2005.5. Probably one of my best up-grades. I get no bulb out warnings.
    http://www.xenonfactory.com/products...light/audi.htm
    Nov 20 2007
    2006 Audi A4 2.0T
    Winnipeg, Canada
    I believe this 06 thing is connected to the B6 platform which underlies the B7 model. I remember in another thread which talked about license plate leds it stated that B6 models did not require anything additional for installation. If any B6 members can chime in and confirm this that would be helpful.
    May 20 2008
    2013 Passat TDI
    What you are saying is that the CECM on the 06 B7s are the same as the B6?
    APR Stage 2+
    OEM+
    _______________
    2013 Passat TDI
    Nov 20 2007
    2006 Audi A4 2.0T
    Winnipeg, Canada
    Quote Originally Posted by airborneriflema View Post
    Yeah. Here's the link to the thread which I was referring to in my previous post.http://www.audizine.com/forum/showth...&highlight=led
    Veteran Member Four Rings muffinman's Avatar
    Jul 01 2007
    Ask, USA
    ordered the festoon bulbs that the OP ordered.. maybe the 9 high intensity led one draws *just* enough current to avoid the dash light warning? who knows... either way, i have a 2007 MY w/ red DIS so hopefully this works (i doubt it); and i can report my findings here.
    2015 Audi S3 Prestige with Performance Package - on order
    2015 Audi Q3
    2009 Audi S5 Coupe - Tiptronic, B&O, Technology Package, Navigation, Carbon Atlas
    2009 BMW 328i
    2007 Audi A4
    FS: CPO 2009 Audi S5 - Tiptronic - Warranty - Seattle, WA
    Senior Member Two Rings cfujikawa's Avatar
    Feb 04 2008
    got a question for you guys. if you get a bulb out warning for your lights, do you need to vag clear those codes? or do they go away when you replace the bulb?
    : 2017 Daytona Gray Pearl Q5 2.0T Premium Plus / Tech / Sport / 20" Rim Pkg :
    : 2007 Silver Acura TL Type-S :
    : 2013 VW Golf 4-Door TDI : *gone*
    : 2006 Quartz Gray A4 2.0T Quattro S-Line Tiptronic : *gone*
    Nope i dont have color DIS...just a standard red readout of DTE.
    PRIME MOTORING
    May 20 2008
    2013 Passat TDI
    Quote Originally Posted by cfujikawa View Post
    goes away after you replace the bulb
    APR Stage 2+
    OEM+
    _______________
    2013 Passat TDI
    May 20 2008
    2013 Passat TDI
    BUMP
    anyone have any new info?
    APR Stage 2+
    OEM+
    _______________
    2013 Passat TDI
    BUMP
    Im still waiting on my shipment, i should be getting them sometime this week
    i ordered bulbs for all my interior bulbs...and two for the tails....and two bulbs to try in the tail lights...
    all the bulbs are the same in the tails, so i only ordered a pair to test in all the sockets, to see how they behave as brake/tail/reverse lights
    PRIME MOTORING
    Jan 23 2008
    NW Indiana
    still no flickering, no light out warning, and they are running cool to the touch
