Results 1 to 8 of 8
    Veteran Member Four Rings Kittrell's Avatar
    May 07 2008
    B8 S5 - 4L Q7 TDI
    Broomfield, CO
    Which Injectors?
    I am going GIAC 1+ soon enough and I am curious if anyone has done a comparison with all of the available injectors.
    Siemens
    Genesis
    Bosch
    Dealership/Audi
    Whats good?
    May 07 2008
    B8 S5 - 4L Q7 TDI
    Broomfield, CO
    Re: Which Injectors?
    Bueller.......
    Dec 28 2006
    '13 A5, '24 Tiguan SEL R-Line
    Western Maryland
    The GIAC FX (1+) was developed using the Siemens so they should be fine. The Genesis 380 is closer to the Bosch 386 (TT225) injectors as they both have a dual cone spray pattern. Clicky click Personally I would recommend the Genesis or TT225's over the Siemens because of the OEM type spray pattern. I would stay away from the Bosch 380's. They have a single cone spray and there have been numerous reports of hard starting issues in the cold with these.
    Senior Member Three Rings demea's Avatar
    Jun 12 2008
    2004 A41.8q | 05 Tr. Blzr LT
    Warminster, PA
    I just popped in my Genesis injectors and got the GIAC injector program from AWE last night. Feels like getting chipped all over again, but the fuel consumption you reallyyyyy have to watch. It's a pig if you get into boost...which is real easy to do now.
    2004 Moro Blue A4 1.8TQTip
    GIAC | Genesis | Forge | Magnaflow | RS4 | ABT | Sport | Premium | Cold | Dings mod ~ Painted lowers are overrated
    Want to see a fun coverband in the Philly area?
    Veteran Member Four Rings rudtf's Avatar
    Dec 27 2005
    07 A4 2.0TQM S-line Ti Ibis
    Ft lauderdale
    genesis! you can buy mine, had it with giac fx or whatever their newest file was called and it ran flawlessly
    May 07 2008
    B8 S5 - 4L Q7 TDI
    Broomfield, CO
    So it looks like am going to get the benefit out of the TT or Genesis units. Thanks guys, I'll probably just spring for the TTs then. I wanted to make sure I wasn't just paying more for a name.
    Feb 15 2008
    AWE powered B6 1.8T
    Severna Park, MD
    I have the Siemens and they work fine, no issues what so ever...
    Veteran Member Four Rings Pr0n's Avatar
    Jul 10 2007
    Bus pass + 2004.5 A4 1.8TQM6
    trunk
    Quote Originally Posted by demea View Post
    ...but the fuel consumption you reallyyyyy have to watch. It's a pig if you get into boost...which is real easy to do now.
    QFT! Any chip and the associated fun kills your mileage. I went back to "Sunday" type driving one night and got 33+ MPG; haven't seen that in a while.
    2004.5 B6 A4 6 speed Transmission 02X AWD Quattro GJW + rear diff for sale
    Red on Black Team Member #1 (sorry you can't join, invite only)
    Red on Black leather interior makes me feel special
    Stage 0 minus - .5
    Running an ST (small turbo) making mine the slowest B6 A4 "evar!"
