Results 1 to 8 of 8
    Veteran Member Four Rings Quattrocket's Avatar
    Sep 02 2004
    2001 Audi S4
    Guelph, Ontario
    Rear brake pads and rotors, opinions needed.
    Hey guys,
    looking at getting some slotted and cross drilled rear rotors and performance pads as they are worn out and in need of an upgrade.
    I want to have a quiet pad that won't fade during high speed braking and I could also track if I ever choose to. I am looking at the hawk HPS pads right now and it doesn't say anything about how quiet they are or how fast they wear out. Also looking at PBR's ceramic brake pads. Would these be better suited to my needs than the HPS pads? Or does anyone know of a better street/high performance pad. Also, i don't want to be cleaning off brake dust every day.
    As far as the rotors go, I was eyeing ECS's slotted/cross drilled rotors. Is there a cheaper higher quality rotor out there that will compare with this one? Also, I understand that the slots will eat through brake pads, so is there maybe a company that just has crossdrilled ones? I used to see zimmerman rotors all the time on ebay for pretty cheap but they seem to have disappeared. TIA guys.
    Mitch
    MITCH
    "Audis are like strippers. They only work when you throw money at them."
    FORGE MOTORSPORT DVs*K04 TURBOS*034 TURBO INLETS*STAGE 3 SOUTHBEND CLUTCH(MANGLED PP MOD)*
    Jan 17 2005
    2001 S4 - 2018 Subaru Legacy
    New Jersey
    Re: Rear brake pads and rotors, opinions needed.
    I got the DBA slotted for the rear with the HPS pads. I also have HPS pads in the front and Powerslot Cyro rotors in the front. So far, I can say that braking feels much softer. I do not like it! I feel like I have to put more pressure on the pedal to stop. I also did stainless steel lines. They people who did them only put in 4 of the 6 lines and I'm not sure they flushed the system. I am having the other 2 lines put in along with a flush. Hope that makes a difference. If not, I wouldn't really recommend this set up.
    Veteran Member Four Rings infinkc's Avatar
    Feb 14 2004
    S Ã C, CÃ*
    i got have some pbr currently, think im going to switch to hawk when i need to change. the pbrs sometimes squeek and seem to fade when hot. I have dba slotted rotors, a8 in the rear.
    Veteran Member Three Rings nateS4's Avatar
    Apr 25 2008
    01.5 Nogaro S4 6spd, 02 GSXR, MkIII TDI
    Baltimore
    I purchased Adams cross drilled and slotted rotors for all around. Couldn't beat the price and quality. A lot of people use Hawk pads or other performance pads but I just used factory pads and there is no noise and the braking over 125 is excellent .
    2001.5 S4 Nogaro Stage III
    Test Pipes|AWE Twin1|Forge Hybrid BOV/BPV|JHM MBC|VAST Tuned|FrankenTurbos|034 Mounts|Hotchkis S-bars|RS4 Grille/Knob|50w HIDs|Vogland/Bilstien|JHM SS
    02 Suzuki GSXR Telefonica Movistar
    88 Bimmer E30 Vert
    98 Jetta TDI
    90 Corrado G60 Sold!
    92 Audi 100 Sold!
    http://photobucket.com/nateS4
    Veteran Member Three Rings seadoo4563's Avatar
    Aug 10 2007
    Annapolis,MD
    i have the pbr's now an im not a fan they dust a lot. i just bought the akebono ceramics
    Apr 25 2008
    Baltimore
    http://www.audizine.com/forum/showthread.php?t=186185 check that out, I definitely recommend them.
    88 Bimmer E30 Vert
    98 Jetta TDI
    92 Audi 100 Sold!
    Oct 31 2005
    Ashburn
    I have Zimmerman rotors up front and i hate them, they were rusted to hell in about the first 2-3 weeks after install. didn't look nice and shiny like when i bought them.
    I would def go with hawk pads though there great, or mintex red box.
    I'll subsribe to this thread as i need rear rotors now to.
    - Instagram: @Sinister_rs5-
    Apr 25 2008
    Baltimore
    ^^^ Adams rotors come in Silver Zinc plated, you can also get black or gold. I've had mine since June and they still look new...just need to paint the calipers and maybe put and S4 symbol on them.
    88 Bimmer E30 Vert
    98 Jetta TDI
    92 Audi 100 Sold!
