Ok so on the way to work I noticed the sound to be completely gone
. However once I started heading back towards home the sound started coming back more and more
. So I decided to investigate it further and I noticed that even with the panel off and banging on the dash I could still hear the noise. I found the noise was coming from the right "bracket" and you can reproduce the noise just by flicking it. Is this attached to any other piece of metal? I noticed there were two screws holding this piece in and I was wondering if there would be any repercutions to taking this piece out. Also do you think that if I add even more insulation as an option on the right side that the bracket will be less likely to "jiggle"?
Thanks in advance.
Note: Left bracket does not produce the sound when flicked theres a barely noticeable low pitch vibration but not nearly as annoying as the right bracket that is causing the problem.
