Results 1 to 7 of 7
    Mar 21 2006
    Revo Tuned 2.0L w/35r
    Lakeland, FL.
    Profec Type S users
    I need a favor. Can someone tell me how the wires for the solenoid are postioned when looking down at the EBC from the top? Which side is the green on and which side is the white on? TIA!!!
    BetaAlphaTauMember#6
    I'm back bitches!
    35r and REVO...what?
    Veteran Member Four Rings mtbrider's Avatar
    Oct 31 2005
    Virginia
    Re: Profec Type S users
    I'll take a look tomorrow when it is light out.
    Some fast things and some slow things
    ~Josh~
    Mar 21 2006
    Lakeland, FL.
    I'm back bitches!
    Mar 21 2006
    Lakeland, FL.
    Bump
    I'm back bitches!
    Mar 21 2006
    Lakeland, FL.
    Thanks, I checked that out and have a manual. The problem is that I bought it used. Its in great shape except for the connector that plugs into the back on the unit for the solenoid, it's broken. So I hard wired it to the unit. I can't get it to regulate boost and just want to make sure the wire polarity is correct.
    I'm back bitches!
    Mar 21 2006
    Lakeland, FL.
    Got it fixed. But now I only get 15psi on max boost. To weak of a WG spring? I run a 4-5psi.
    I'm back bitches!
