Results 1 to 5 of 5
Thread: Vag Com Codes
    Mar 28 2008
    Northern NJ
    Vag Com Codes
    Hey guys im looking for the Vag Com codes to do independent fogs and Rolling windows down with key. Anyone know a website or have the codes thanks!!!
    Things I am selling just PM me
    - RS4 Pedals (Automatic)
    - USP Lower Valence
    Veteran Member Four Rings mholme's Avatar
    Jan 29 2007
    08 S4 00 S4
    MD
    Re: Vag Com Codes
    Quote Originally Posted by Retard Riot View Post
    http://www.ross-tech.com/vag-com/cars/audiB6.html
    Mar 28 2008
    Northern NJ
    Re: Vag Com Codes
    god thats a confusing page anyone help me understand it http://www.ross-tech.com/vag-com/cars/audiB6.html
    - USP Lower Valence
    Aug 26 2005
    Re: Vag Com Codes
    Only an '02 can recode for independent fogs, without some hardwiring mods to the lighting switch, or using a '02 specific Central Electric Control Module part number. For your '05, recode only allows DRL, that are fogs plus side lights and parking lights on whenever the ignition is ON. The windows with remote, is figured by adding all of the decimal values shown for each feature that you want to activate, then use that summed decimal number as the coding number to enter in the convenience control module. Adaptation channel 062, 063 or 064 ( I forget which one now,) must also be configured to allow "convenience functions by remote". The adaptation coding value is the sum of the individual features you want activated. For example, if only one feature is to be added activated, take the original coding/adaptation value and add the decimal value of the new feature to be activated, store the resulting decimal value in the coding of the controller and adaptation channel as needed.
    Mar 28 2008
    Northern NJ
    Re: Vag Com Codes
    Yeah thats what i meant its cool if fogs and side lights are on. I Thought those were called independent Fogs. My bad thanks for all your help and quick replies guys!
    - USP Lower Valence
