Results 1 to 8 of 8
Thread: please help
    Apr 26 2007
    Detroit
    please help
    When I start my 2004 a4 1.8T the engine shaking and doesn't idle at the right level of revs (ie idle at about 800 rather than 1000). also white smoke coming out exost. and engin loght on, and im losin coolant. sorry for bad english and thanx for help.
    Aug 26 2005
    Re: please help
    Quote Originally Posted by dober174 View Post
    The head gasket has failed. Don't try and drive the car anymore until you can get the gasket replaced. The symptoms you described, missing, rough running, white smoke and loss of coolent, all confirm the head gasket failure, being common symptoms of a leaking head gasket.
    Veteran Member Four Rings 04QuattroTurbo's Avatar
    Jun 15 2008
    Fairfield, CA
    Re: please help
    As always, Diagnosticator, hit on the nail, the sure fire way to know, would be to do a compression test. You will notice 1 or two of your cylinders have very little pressure while the others are ok. Did the car overheat? Not a cheap job, unless DIY.
    2004 (B6) Audi A4 Quattro 1.8L Turbo 6-Spd Man
    Premium Pkg, Cold Weather Pkg, Ultra Sport Pkg, Lighting Pkg, Sirius Satellite. Dolphin Grey
    APR Stage I, K&N 33-2209 Drop-in filter, Apr Snub mount, RS4 pedals
    VIN Decoded: http://www.motoverse.com/tools/vinDe...LC68E84A219972
    USP Member 110
    WANTED: Roof Spoiler, PM me with Offers.
    Apr 26 2007
    Detroit
    Re: please help
    thanx. Its proboly head gascet, and yes its gonna be DIY my warranty is expired i have 14000 on the clock. How hard is to chenge gascet? comper to timing belt and water pump? and what do i need to do it?
    Thanx
    Jun 15 2008
    Fairfield, CA
    Re: please help
    Diagnosticator, probably has more detailed instructions, but basically, you need to take the head off, scrape off the old gasket and put on the new head gasket. Sounds simple, but it is way more involved than I put it.
    USP Member 110
    Aug 26 2005
    Re: please help
    Thanx
    It's one of those "if you have to ask" situations. As such, at the minimum, have someone help you that knows what they are doing and has some experience with this kind of engine repair. The detailed help and instructions you need, is beyond the scope of the forum.
    Apr 26 2007
    Detroit
    Re: please help
    how much is head gasket?
    Aug 26 2005
    Re: please help
    The OEM stock head gasket is the best, and costs about $60.
