Results 1 to 12 of 12
    Veteran Member Three Rings JayStang's Avatar
    Jun 23 2008
    2008 Audi A4 S-Line Ti 2.0T
    Boston, MA
    Zune Hardwire Kit
    Is there any type of hardwire kit for microsoft zune out there for our cars?
    I'm sure i'll get 50 posts with people saying zune is crap and to get an ipod. I just purchased an iPhone so I now have my "like new" 30 gig zune just sitting there collecting dust so might as well put it to use.
    Thanks guys.
    Registered Member Three Rings SlappyB6's Avatar
    May 14 2008
    W-S, NC
    Re: Zune Hardwire Kit
    Zune FTW! Ipods are garbage, break all the time. But honestly, I'm interested in this as well.
    02 A4 - 5spd - Sport - VM DP
    Capt. Obvious - "Not me. I fart rainbows, shit rose pedals and piss excellence."
    Veteran Member Four Rings El_Chapusca's Avatar
    Jun 06 2008
    Long Island, NY
    Zune Zune Zune........
    -Joey aka Chappy
    GCC Law/Rule #22 Enforcer.
    GCC: Its Serious Business
    Tastefully Modded
    Veteran Member Four Rings kwimberly's Avatar
    May 03 2008
    Orlando
    There are kits that will give you an AUX input so that you can run a stereo mini --> RCA via the CD changer port. I have a DICE that has an iPod cable and a separate AUX that I use for my XM radio. I guess it would be a waste to buy one just for the AUX jack. I bet there are solutions that just add an AUX jack via the CD changer port.
    Do you want to control the Zune from your head unit, or do you just want to get good sound via the hardwire and control it from the Zune itself?
    Kevin W.
    2003 A4 1.8T quattro 5-spd. | USP lower | APR ECU w/ TT225's | APR TIP | test pipe | FMIC | Apikol snub | ecodes | Podi® | AWE sport pedals | JHM SSK/linkage | Forge 007 DV | '02 OEM sport suspension | OEM sport wheels | B6 S4 brakes w/ TyrolSport stiffeners | RS4 rear sway bar| Magnaflow 14829's| AVIC F700BT | hard-wired Passport 9500 | Side-mount trash bag hanging from shifter
    Jun 23 2008
    Boston, MA
    Quote Originally Posted by kwimberly View Post
    Thanks for the response. I'd love to be able to control the Zune from the head unit, but if that's not possible I'd like the best/cleanest solution possible.
    Veteran Member Three Rings Gallep's Avatar
    Mar 22 2004
    2014 Q7 3.0T, 2012 A6 3.0T
    Castle Rock, CO
    Mind if I jump in too? I just want the best quality of sound. I also have XM and want to keep that feature. what is available?
    Previous
    USP B6 A4
    May 03 2008
    Orlando
    Something like this would be clean - it's essentially like the DICE/Blitz/etc iPod interfaces - minus the iPod interface. It will just give you an AUX input. You wouldn't be able to control the unit, but you could run the wire into the glovebox, armrest, etc and have a clean install
    I have my XM (non-OEM unit) on a panavise mount and my iPod on the change holder - you can barely see the cables, and the sound quality is great. And honestly, even though I can control the iPod via the stock radio, I keep it in the mode where I control the iPod via the Ipod itself - it's just easier.
    http://enfigcarstereo.com/shopsite_s...X_DMX_V1B.html
    P.S. - the one nice thing about the DICE iPod thing is that it charges the iPod. So, if you went with the above product, you might consider hard wiring another cigarette adapter in for a charging cable. I ran an Add-A-Circuit thing off the Homelink fuse and ran another cigarette adapter behind the center console to power my XM RoadyXT.
    Kevin W.
    Jun 23 2008
    Boston, MA
    So to connect this directly to the zune I would just need an RCA to 1/8" jack adapter?
    May 03 2008
    Orlando
    Quote Originally Posted by JayStang View Post
    From the same place:
    http://enfigcarstereo.com/shopsite_s..._35RCA6MM.html
    One end in your headphone jack on the Zune and one end routed to the BlitzSafe adapter. (keeping in mine that you'll be running off battery power unless you use a cigarette-type charger)
    Kevin W.
    Jun 23 2008
    Boston, MA
    Ok sounds perfect. Thanks for the help!
    Veteran Member Four Rings pyro's Avatar
    Mar 18 2007
    '05 A4
    Tampa, FL
    zune > ipod any day of the week. i already have the hookup in my wrangler, hope to do this soon too. woot!
    May 03 2008
    Orlando
    Don't forget to get FOUR radio removal keys if you don't have them already... The cheap three-spoke ones are fine.
    Kevin W.
