Results 1 to 8 of 8
    Veteran Member Four Rings savetheclutch's Avatar
    Oct 01 2006
    ducatis and a miata
    Fort Lee, NJ
    staggered wheels set up question.. :)
    I got a good deal on some nice 3 piece wheels.
    Fronts are 18x8.5 with 225/40/18 offset 30
    Rears are 18x9 withi 245/35/18 offset 40
    I am on stasis street c/o. Is anyone running a set up similar? or knows if this will work, do I need spacers? do I need to roll fenders?
    The tires have about 60% life left but if I need to get new tires then what would work good?
    The wheels are Hamann PG made by OZ
    AKA: andresito360
    Mar 09 2004
    99.5 A4 Avant, 01 allroad
    nw michigan.
    Re: staggered wheels set up question.. :)
    These numbers assume a 17x8 et35 as the stock size.
    The 18x8.5 will have 1mm less inside clearance and 11mm less outside than stock.
    The 18x9 will have 18mm less inside clearance and 8mm less outside.
    Jim
    I Do Werk.
    Oct 01 2006
    ducatis and a miata
    Fort Lee, NJ
    mm right now I am running 18x8 oettinger and 235/35/18 tires, Could I use those same numbers to try and measure?
    also that means I pretty much need spacers at least in the back right?
    AKA: andresito360
    Veteran Member Four Rings boostedup's Avatar
    Sep 01 2005
    01 a4 1.8T,00 suzuki GSXR 600, 1974 Mako 171
    internationally known, Florida
    nice wheels,they look like they need to be refinished a little though........
    Santorin Blue 2001.5 Audi A4 1.8turbo Quattro with Sports, Celebration, Cold Weather Packages.
    Engine:APR 93 octane. Catch Can. Air Intake/Heatsheild. 710N .
    Interior:VDO Vent Boost gauge. Short Shift. Garmin GPS. 2-10" subs. Suede interior
    Exterior:19" ASA St4's/NITTO rubber. Neuspeed Race/Bilstein Sport shocks. 15% tint. Debadge. Clear Corners. 4300K HID. MS Design Front lip
    Oct 01 2006
    ducatis and a miata
    Fort Lee, NJ
    they will be, I got them for dirt cheap, considering that they sold for $996 per wheel. I got them for lees than half of one wheel :) one of the lips is bent but it is on its way to PA to get fixed. I don't know if polish them of powdercoat them black or something :)
    AKA: andresito360
    Sep 01 2005
    is your car santorin, if so polished lips/studs, santorin center........that would look tits
    Veteran Member Four Rings njm23's Avatar
    Feb 28 2007
    04 a4 USP ; ATS
    use this, you'll learn a lot and it will answer your questions, I would roll the fenders.
    http://www.1010tires.com/WheelOffsetCalculator.asp
    Oct 01 2006
    ducatis and a miata
    Fort Lee, NJ
    ^^ since you live in NJ do you know of any shop that does fender rolling?
    Thank you for the link, time to do some home work :)
    That santorin center idea has some potential.. I got some paint in my garage so time to try it
    AKA: andresito360
