Results 1 to 35 of 35
Thread: Timing Belt
    Veteran Member Four Rings andru1313's Avatar
    Apr 13 2007
    Audi 2018 RS3 2006 Evo IX MR
    Frisco, Texas
    Timing Belt
    Ok guys. Just had to dump alot of cash into my car. Clutch went. I have 63k on my 2001.5 S4. I want to do the timing belt. I am asking if anyone in the philly area that has done this would lend me a hand. I know how to wrench I am just nervous to do this un supervised. I can pay in food and booze. Oh and I will make the little lady hang out in the garage in a thong.. Let me know if anyone wants to help me out. Thanks.
    Oct 29 2005
    10speed
    San Francisco, CA
    Re: Timing Belt
    man you cant beat that, I may just have to stop by! lol jk im busy with school but it shouldnt be too bad
    - Clint
    Apr 13 2007
    Frisco, Texas
    Re: Timing Belt
    LOL Thanks.. Oh and she Wrenches as well. Come on guys help a fellow AZ'er out!
    May 18 2007
    01 Laser Red 6MT, 13 Touareg TDI
    Baytown, TX
    Re: Timing Belt
    Is she hot too? Wouldn’t want to see a huge chick in a thong!!! Just messing with you. Would help, but live in Houston. What all are you doing with your t-belt job?
    Could I make a suggestion from my experience? Change all of your seals at the same time… it's preventative maintenance and saves you the headache for later. I wish I would have done this because now my front cam seals are leaking. The front cam seals are in front of the car and the rest would be easier to change while you have the car in the service position. Basically, get this kit along with your t-belt kit… and don’t forget to rent the tool (or buy it).
    http://blauparts.com/proddetail.asp?prod=GF21002
    I’m gonna wind up doing another t-belt job because of this… so I’ll have to spend the money again and the time again… I only put like 25k miles on since I did the t-belt.
    Feb 24 2004
    Minneapolis
    Re: Timing Belt
    Quote Originally Posted by RedRocketS4 View Post
    Could I make a suggestion from my experience? Change all of your seals at the same time… and don’t forget to rent the tool (or buy it).
    I couldn't agree more. I did my cam seals and crankshaft seal last time I did it. You're right there. And yea, I rented the tools from Blau also. Once you get that camshaft alignment tool, it's not such an intimidating job. It's hard to screw up the timing with that tool.
    I'm in MN, so am not going to help w/o a picture that documents the "little lady" in the thong.....
    Apr 13 2007
    Frisco, Texas
    Re: Timing Belt
    I will get a pic up soon. I was going to order the Kit from ECS. Comes with the tools needed. So should I order cam seals from there as well?
    Feb 24 2004
    Minneapolis
    Re: Timing Belt
    Quote Originally Posted by andru1313 View Post
    Yea sure... I've bought lots from them. Don't know if they rent the tools though. And the tool that pulls the crankshaft seal is real nice to have given the clearance you have down there.
    Oh, and the pic.....no Google image stuff. She needs to be standing by your Audi....not on some secluded beach somewhere with professional lighting. We are NOT naive.....
    May 18 2007
    Baytown, TX
    Re: Timing Belt
    I would use the blau kit because it comes with the valve cover gaskets, cam tensioner gaskets, cam plugs, and cam seals, which all have a tendency to leak oil. You can also get the tool rental from there for the cam tensioners
    Oct 29 2005
    10speed
    San Francisco, CA
    Re: Timing Belt
    crank seal must be tricky, do they rent you the tool to bang the crank bolt off?
    - Clint
    May 18 2007
    Baytown, TX
    Re: Timing Belt
    sure do
    http://blauparts.com/proddetail.asp?prod=N1A1009%2DD
    and here's the tbelt kit:
    http://blauparts.com/proddetail.asp?prod=GH21113%2DA
    the kit is missing a tensioner, which comes with other kits, but you can normally re-use it if you slide a piece of coat hanger in it... it also comes with instructions, which are nice if it's your first time on this car.
    Dec 06 2007
    Calgary, AB, Canada
    Re: Timing Belt
    Gear puller, my friend.
    Oct 29 2005
    10speed
    San Francisco, CA
    Re: Timing Belt
    Quote Originally Posted by The_Jerbel View Post
    theres a VERY large bolt attached in front of that gear lol.. how do you get that off without a ton of air pressure?
    - Clint
    Active Member Four Rings
    Dec 11 2006
    Boston
    Re: Timing Belt
    Muscles and leverage. Neither of which we have.
    Stage 3+ RS6's
    Apr 13 2007
    Frisco, Texas
    Re: Timing Belt
    Wow OK thansk for the links. I will order from there. I did a Motor Swap on a DSM so I know about saving the Tensioner.
    Dec 06 2007
    Calgary, AB, Canada
    Re: Timing Belt
    Use the crank lock pin and also whatever else you can muster to secure the shaft from rotating
    Feb 24 2004
    Minneapolis
    Re: Timing Belt
    Yea that crankshaft locking pin (tool you use to hold the lower half of the engine at TDC) + a breaker bar + a pipe over the end of the breaker bar.
    Oct 29 2005
    10speed
    San Francisco, CA
    Re: Timing Belt
    damn we dont have a crank lock pin (1.8T)
    - Clint
    Feb 24 2004
    Minneapolis
    Re: Timing Belt
    Then you should rent one to do that timing belt job. It keeps the lower half of the engine locked at TCD so you can match that with the cam shafts.
    Mar 21 2008
    Re: Timing Belt
    so...wheres teh pic =X
    Apr 13 2007
    Frisco, Texas
    Re: Timing Belt
    i don't have anyone offereing to help.
    Veteran Member Four Rings Videlov's Avatar
    Jul 01 2008
    Chicago, IL, Bulgaria
    Re: Timing Belt
    Well the guys need some motivation...
    "Some Redbull, some water, some nice fresh house music!"
    2000 Audi S4 (Sold)
    2010 Audi S4 (Next)
    Apr 13 2007
    Frisco, Texas
    Re: Timing Belt
    ahaha. Well i will find something to post but that being said it will be a teaser can't show all the goods i need help dammit!
    May 18 2007
    Baytown, TX
    Re: Timing Belt
    I don't know how far away Maryland is from you, but I'll be somewhere in Maryland all weekend if you wanna drive there
    Apr 13 2007
    Frisco, Texas
    Re: Timing Belt
    thanks Red MD is a bit far but appreaciate the offer.
    Mar 21 2008
    Re: Timing Belt
    U need a Teaser picture
    Jul 01 2008
    Re: Timing Belt
    That's what I told him, that way he will reel in some hard lonely machenics...lol
    2000 Audi S4 (Sold)
    2010 Audi S4 (Next)
    Aug 06 2008
    Canadia
    Re: Timing Belt
    you can do it without tools, i did my timing belt job without them. use a wrench to hold the passenger side camshaft pulley steady when you put on the belt, compress the tensioner via the pulley and slip the belt over it, and make sure to turn the engine over a few times to make sure everything is bang on before re-assembling. I also highly recommend changing the t-stat, I ended up having to do my t-stat after the belt, wouldn't call it a hard job, but it was time consuming.
    if your doing seals you probably will want to get the tools because the camshaft sprockets don't have an alignment pin or woodruff key, etc to make sure they are installed properly.
    Apr 13 2007
    Frisco, Texas
    Re: Timing Belt
    Quote Originally Posted by Videlov View Post
    Oh yah and she does her own motor work. w00t. Usually pantless in the garage.
    Feb 24 2004
    Minneapolis
    Re: Timing Belt
    Quote Originally Posted by MacDaddy View Post
    Mac you can do that....but you get more accurate timing if you loosen those cam shaft sprockets. That way the tension on the belt is distributed evenly across the cams, tensioners and other pulleys. Then you crank down the sprockets.
    Jul 01 2008
    Re: Timing Belt
    Damnit I'm at work... Can't view...
    2000 Audi S4 (Sold)
    2010 Audi S4 (Next)
    Apr 13 2007
    Frisco, Texas
    Re: Timing Belt
    I posted the pics and nothing.. wth....
    Feb 24 2004
    Minneapolis
    Re: Timing Belt
    I think we were all just having a little fun with it. No one wants to say anything too "personal" about another guy's wife....at least not on this site.
    My advice? Rent the tools, save your wife's equipment for the next morning. You'll be too tired at the end of the day.
    Apr 13 2007
    Frisco, Texas
    Re: Timing Belt
    She can hold her own. and not the wife.. And I was refereing to the help with the timing belt not comments for the pics.
    Aug 06 2008
    Canadia
    Re: Timing Belt
    Quote Originally Posted by mtroxel View Post
    without a doubt that will work better, i was just meaning the job is still doable without the tools.
    Veteran Member Three Rings papuc14369's Avatar
    Apr 06 2008
    NorCal
    Re: Timing Belt
    test
    2001.5 Audi S4 - Santorin Blue - Stage 1 & dearly missed - RIP
    2000 Audi S4 - Nogaro Blue - Tial 770r - SOLD
    2001.5 Audi S4 - Black Avant - Bone Stock - SOLD
    2001.5 Audi S4 - Nogaro Blue Avant - Stage 3 RS6 Turbo - Daily Driven
    2000 Audi S4 - Laser Red - Sold
