Results 1 to 8 of 8
Thread: Light Vibration
    Veteran Member Three Rings lENrok1's Avatar
    Nov 30 2007
    B7 DTM S4, VW MK2
    Florida
    Light Vibration
    So i've just noticed a small vibration feeling from my car @ about 45-80mph. The steering wheel doesn't shake, and I gave the car a wheel alingment less than 2 months ago. I'm running h&r coilovers. I also just purchased a set of new tires which were mounted and balanced at discount tire. what could it be? bearings?
    Veteran Member Three Rings caitovS4's Avatar
    Nov 19 2006
    Re: Light Vibration
    If you just got new tires and are just noticing the vibration, I'd check there first.
    Go back and explain to them what you're noticing and ask them to recheck.
    Nov 30 2007
    B7 DTM S4, VW MK2
    Florida
    Re: Light Vibration
    Don't think the tires are the problem. They have driven fine. I got the tire's over a month ago. I'm thinking it could something to do with suspension parts. If i hear a hum, could that be the bearings?
    Senior Member Three Rings guglielmo's Avatar
    Feb 02 2008
    Westchester, NY
    Re: Light Vibration
    tire balance or bent wheel
    B7 RS4 mugello
    B7 S4 moro
    Q5 meteor
    Nov 30 2007
    B7 DTM S4, VW MK2
    Florida
    Re: Light Vibration
    i'll have to get them rebalanced and go from there. wheels not bent.
    Registered Member Three Rings turbo4s's Avatar
    Mar 27 2006
    AUDI B7 S4 / MKV GLI
    Re: Light Vibration
    I had my tires put on at Mavis dicount tire, they balanced the wheels but did a shit job so I went to audi and prob was taken care of. If you hear a hum it the hub or bearing (could be worn or bent)
    _______
    Artic White B7 S4 Fully Loaded
    Mods= Titanuim RS4 Grill
    Salsa Red MKV GLI Fully Loaded
    Mods= Revo Stage III KO4, Carbonio, AWE Full Exhaust, AWE FMIC, H&R spring & Sways, AWE Vent Guage,
    ECS Blacked Out Coners, ECS Snub Mount, KMD Fuel Pump, KMD Cam Follower
    Veteran Member Four Rings GFRRS3's Avatar
    Dec 06 2007
    LI NY
    Re: Light Vibration
    Check to see if all wheel weights are on the wheels still, that would give you a quick idea of wether your wheels need to be rebalanced, they have a tendancy to not stay on if the surface wasnt cleaned properly.
    2017 - AUDI TTS
    2017 - PORSCHE 911 C2
    2019 - VOLVO XC60 R-DESIGN
    2021- AUDI A6 ALLROAD - SOLD
    2020 - AUDI RS3 - SOLD
    2006 - AUDI A3 - SOLD
    2005 - AUDI S4 - SOLD
    2004 - AUDI A4 USP AVANT - SOLD
    1999 - AUDI A4 AVANT GT28RS - SOLD
    IG- Greyfoxresearch
    Feb 14 2008
    Black B6 S4 & B5 A4 2.8
    TDOT
    Re: Light Vibration
    Quote Originally Posted by FTYAVANT View Post
    Agreed you probably through a weight. As for no vibration in the steering wheel if its more in the seat or in the floor, get them to check the rear tire/wheels.
