Results 1 to 19 of 19
    Established Member Two Rings DubAudi3's Avatar
    Aug 14 2007
    01 a4 1.8tqms
    Canton, CT
    s4 seats in a4??
    Just wondering i wasnt sure if people have put full power s4 seats in an a4 1.8t without power seats... i know the seats will bolt up but is the wiring there for the swap?? Thanks
    01 A4 1.8T QMS
    www.BishopMotorsports.com
    Canton, CT (PM me for details)
    Established Member Two Rings ricebeater's Avatar
    Mar 02 2008
    98 a4 1.8TQM
    Malvern, PA
    Re: s4 seats in a4??
    Quote Originally Posted by DubAudi3 View Post
    wiring isn't there unless you have power seats already. I had power so it hooked up. I still have to figure out my passenger airbag seat sensor is Fed up so Im still working on it.
    1998 black 1.8t A4 QUATTRO
    MODS:S4 front bumper:S4 gauge cluster:S4 seats:S4 Grill:VDO boost gauge:Forge SMIC:Neuspeed Exhaust:Forge Spltr DV:18"x8" ADRs:
    Coming Soon: AWE DTS, A/F and OP Gauges, two tone paint job, lowering springs and more...
    Aug 14 2007
    01 a4 1.8tqms
    Canton, CT
    Good to know.. Thanks
    01 A4 1.8T QMS
    Senior Member Two Rings tonelee1316's Avatar
    Oct 11 2006
    rancho cucamonga
    The seats will not bolt up u will have to
    Modifly the rails and cut the original bracket I will be doing this this weekend
    Genesis Autosport
    Evolution Racewerks
    Veteran Member Four Rings JumboBlack1.8's Avatar
    Sep 16 2006
    '98 528i
    Boston/West Hartford, CT
    I believe it'll work if you have ANY power going to ur seats, including just heat or lumbar....I believe power S4 seats will plug right into cars with heated seats
    2000 Audi B5 S6 ** 4.2L 40v S6 6spd - http://www.audizine.com/forum/showth...n-s6-4-2L-swap
    Veteran Member Four Rings SFexBOY's Avatar
    Feb 25 2004
    1990 BMW 325iX
    Staten Island, NY
    Quote Originally Posted by ricebeater View Post
    not true.
    My 01 had manual seats. I hooked up S4 alcantara seats to my car....and the plugs were there. Just had to plug them in, and it worked.
    '90 BMW 325i...SOLD!
    '89 BMW 325ix...SOLD!
    '05 BMW M3
    01.5 A4 1.8TQ (175K, owner since 4K)
    My cars.
    Established Member Two Rings nytoy's Avatar
    Aug 13 2008
    Rochester, NY
    Quote Originally Posted by SFexBOY View Post
    not true.
    did you have to mod the seat rails?
    Feb 25 2004
    1990 BMW 325iX
    Staten Island, NY
    Quote Originally Posted by nytoy View Post
    not the rails. The S4 seats slide right in. The problem you will have is trying to move the seat all the way up + you'll find that there are no threads to screw the front screws into (there is a hole there no threadings like in the S4).
    2 things you need to do:
    1. Grind off the front bracket that keeps the seat from moving all the way up (keep in mind you can't put your stock A4 seats back after you do this)
    2. Find an alternative to bolting the front screws of both seats down. I included a pic below showing how I did mine. Two self tapping screws right into the floor.
    Other than that....its straightforward and an easy swap.
    '05 BMW M3
    My cars.
    Veteran Member Three Rings A4tsleeper's Avatar
    Apr 18 2005
    2001 s4 avant
    PA
    If you have the power lumbar. It will plug right in. You have to take the front braket off.
    B5 S4 Avant, Aka the Avantador.
    EPL tuned, Tial 605.2, ev 14 injectors, apr bi-pipe, 034 044 fuel pump, CM fx400, ssac v2 twin1 exhaust, SRM V3 intercoolers, aquamist hfs-3, 034 motor/ tans mounts, awe dtc... 460wph/420wtq @ 24.5psi
    Veteran Member Two Rings 0000_a4's Avatar
    Aug 03 2004
    Chi-Town
    Will they hold if you track your car?
    K04|Custom FMIC|310cc Injector|GIAC PC-16|APR Inlet Hose|2.5" Scorpion Exhaust Turboback|EVO MS DV|South Bend Stg II Clutch|Unorthodox LFW|18" BBS CH|RS4 Look Front|S4 Rear and Side skirts|Koni Coilovers|A.W.E. Drive Train Stabilizer| 6000k 50w HIDs|Valeo 1 piece Headlights| Stratosphere SS
    Senior Member One Ring Pearl00's Avatar
    Apr 24 2007
    99.5 A4, 04 VW R32, 04 Tundra
    Idaho
    Will they hold if you crash your car? I wouldn't trust them and sure wouldn't want to find out
    Veteran Member Four Rings t1demont1's Avatar
    May 08 2007
    1999 1.8tqm gt3071r
    Orlando, FL
    Its not hard powering the seats if your didnt have power. I spliced the power on the seat and ran it. Just make sure you have a 30amp fuse for each seat.
    BetaAlphaTau Member #40
    1999 2.0 hx35 dbw conversion
    Sep 13 2007
    I just did this to my car the seat will fit If you dont have power seats all you need to do is run a power and ground wire and as far as bolting hte seat I used what they call a nut cert look them up online.
    Veteran Member Four Rings sixfiveoh's Avatar
    May 19 2007
    Bay Area
    Quote Originally Posted by Pearl00 View Post
    Seriously, why has nobody answered this question yet?
    SIXFIVEOHphoto
    2001 Brilliant Black 1.8TMS A4
    Unitronic|APR|H&R|Neuspeed|Falken|Carbonio|Apex'i| VDO|VMR
    FS: Buncha B5 parts, CLICK
    Sep 16 2006
    '98 528i
    ^^+1
    I need to know too.....I wanna throw some of these in my car
    Senior Member Three Rings LowSantorin's Avatar
    Oct 19 2007
    Dub State
    Could you put a high strength nut through the hole and back it with washer and nut to make up for lack of threads. Or what about tapping the hole to next thread size?
    Feb 25 2004
    1990 BMW 325iX
    Staten Island, NY
    Quote Originally Posted by sixfiveoh View Post
    They seem to hold in fine.....but hopefully i'm not in a crash like that to find out if they would hold up or not.
    '05 BMW M3
    My cars.
    Feb 25 2004
    1990 BMW 325iX
    Staten Island, NY
    Quote Originally Posted by LowSantorin View Post
    I guess that might work if you can get the nut or bolt on the other end of the floorpan.
    You'd prob need to have someone weld a plate over the hole, and then drill & tap into that. I opted the easy way out, and just tapped thru right in front of the hole...in 2 places.
    '05 BMW M3
    My cars.
    Sep 01 2008
    Palo Alto
    Yeah, those screws you used won't hold up well in a crash. From an engineering perspective, they just don't have the strength compared to the OEM method of fastening the seat down. Do that at your own risk.
