Results 1 to 34 of 34
    Veteran Member Four Rings mattman's Avatar
    Oct 23 2007
    1978 Honda CB400T Cafe Racer
    Ontario, Canada
    Talking Everyones favorite! another thread on HID's!!!
    So i'm upgrading to OEM DOT xenon housings...but i'm in need of bulbs and ballasts. I'm aware of the kit from HIDconcepts....but before I spend 300$ on a set of used ballasts (and new bulbs), i want to see if theres an alternative.
    I found these ballasts on ebay:
    http://cgi.ebay.ca/D1R-D1S-D1C-OEM-X...QQcmdZViewItem
    sounds too good to be true....anybody ever bought these before?
    If I were to use ballasts from an aftermarket HID kit (usually 55w), would they work with the D1S bulbs?
    Meet Shanice...
    For Sale:
    Stock suspension, slightly damaged stock painted lower front
    Dec 06 2007
    Re: Everyones favorite! another thread on HID's!!!
    thanx for posting, i'm in the market for these 2.
    -Kirk
    BetaAlphaTau Member #58
    Oct 23 2007
    Ontario, Canada
    oh and one more question.
    Regarding the Vagcom settings--do i just have to change it to the xenon settings?
    Meet Shanice...
    For Sale:
    Veteran Member Three Rings Carlitos's Avatar
    Sep 17 2006
    B6 A4 1.8T
    San Juan, PR
    Quote Originally Posted by mattman View Post
    I went from Halogen to OEM S4 Headlights (Xenon) and I didn't change anything via vagcom at all.
    FlexTuning
    Amulet 1.8TM
    BAT#46
    Registered Member Two Rings bigbro's Avatar
    Jul 27 2008
    Black 05 b6 a4 1.8T Quattro AT
    hids are 35w
    05 Triple Black 1.8T Quattro Tip.
    Sep 17 2006
    B6 A4 1.8T
    San Juan, PR
    FlexTuning
    Amulet 1.8TM
    BAT#46
    Oct 23 2007
    Ontario, Canada
    Quote Originally Posted by Carlitos View Post
    really? and there's no autolevel error or anythinig?
    Meet Shanice...
    For Sale:
    Oct 23 2007
    Ontario, Canada
    Quote Originally Posted by bigbro View Post
    hids are 35w
    but a lot of aftermarket kits (i.e.: H7, H11 kits) come with a 55w ballast.
    Meet Shanice...
    For Sale:
    Aug 26 2005
    Don't get the referenced eBay ballasts. Use the OEM Valeo ballasts. They fit the headlights, mounted to the housings on the mounting flanges provided, with a gasket.
    The needed wiring harness connectors that fit the Valeo ballasts are already present in the housings. Besides the ballasts and D1S lamps, a pair of ballast > D1S connecting cables should be included with the HIDConcepts kit. As an alternative, you can source the kit components separately, and will take longer etc. No VAG-COM coding needed. Because there is nothing to code. There is no auto range/leveling so, there is no range / level error to deal with. There is a coding option for the Central Electric Control Module, for Halogen or Xenon, but that is not relevant if there is no auto range level controller present.
    Oct 23 2007
    Ontario, Canada
    thank you for your input. so if i understood this right (about the VAGcom), I do not need to because the actual Autoleveling wont work without that sensor?
    Meet Shanice...
    For Sale:
    Aug 26 2005
    Correct. OEM HID retrofitted to OE Halogen, there is no autoleveling contorller or sensors. The headlights will NOT have the leveling motors either. (EDITED)
    As always, be sure you aim you HID lamps properly after install. And, if you add a load of PAX after dark, be aware that you should lower you beam aim manually.
    Oct 23 2007
    Ontario, Canada
    Correct. OEM HID retrofitted to OE Halogen, there is no autoleveling contorller or sensors. The headlights will have the leveling motors, but they won't be connected or active.
    is there a way to retrofit the sensor? or is it just not worth it?
    Meet Shanice...
    For Sale:
    Dec 06 2007
    ^^he's back yes!
    -Kirk
    Veteran Member Four Rings 04QuattroTurbo's Avatar
    Jun 15 2008
    Fairfield, CA
    I thought Rim threads were everyone's favorite?
    2004 (B6) Audi A4 Quattro 1.8L Turbo 6-Spd Man
    Premium Pkg, Cold Weather Pkg, Ultra Sport Pkg, Lighting Pkg, Sirius Satellite. Dolphin Grey
    APR Stage I, K&N 33-2209 Drop-in filter, Apr Snub mount, RS4 pedals
    VIN Decoded: http://www.motoverse.com/tools/vinDe...LC68E84A219972
    USP Member 110
    WANTED: Roof Spoiler, PM me with Offers.
    Oct 23 2007
    Ontario, Canada
    Quote Originally Posted by 04QuattroTurbo View Post
    touché
    Meet Shanice...
    For Sale:
    Jan 07 2008
    04 A4 1.8tqm
    Montreal, Canada
    This auto leveling mod could work.
    http://www.audiworld.com/tech/elec161.shtml
    Veteran Member Four Rings pyro's Avatar
    Mar 18 2007
    '05 A4
    Tampa, FL
    seriously...all of these questions have been answered so many times before.
    if you have oem housings, stick with oem stuff.
    55w HID kits are all aftermarket and trash. HIDs are OEM 35w for a reason.
    you do not need to change anything in vagcom to switch to HIDs, and autolevel is a PITA to install, and you dont need it for anything. just aim them like normal and you will be fine.
    Oct 23 2007
    Ontario, Canada
    Quote Originally Posted by pyro View Post
    ...thats great but when i was searching i've herd of people 'modifying' their OEM ballasts to produce 55w (which supposedly makes it brighter) but no other information provided. This is one of the reasons i ask about the aftermarket ballasts.
    Meet Shanice...
    For Sale:
    Aug 26 2005
    Retrofitting the auto leveling requires the controller, 1ea front and rear suspension sensor assemblies, and the wiring harness connecting the components to each other and to the headlight servo motors. Not worth the expense and hassle, IMO. Provided that the beam aim is lowered as needed manually if the car is loaded up in the rear seats or trunk, or not driven loaded up at night. Remember the auto leveling only compensates for load, not bumps in the road.
    Jun 15 2008
    Fairfield, CA
    Why would you want the stock HIDs for the brighter than they already are. With my headlights on I can see everything just fine. I think brighter would just make things too bright for the oncoming driver or will have the effect like brights on a foggy day. It is not like horsepower where you want more and more. There is such a thing as too bright.
    USP Member 110
    Aug 26 2005
    Tests on driving 35 watt HID burners with higher wattage ballasts, on other HID forums, shows that the lamps burn with a yellower light than at the design rating of ~35 watts, and have a very limited life span. Not to mention the possible housing damage from the higher heat at 55 watts.
    Jun 15 2008
    Fairfield, CA
    So, again, why do it?
    USP Member 110
    Aug 26 2005
    Another important factor seldom realized, concerns excessive Foreground light intensity. When this is allowed, the road directly in front of the car, out to about 30 feet or so, is over illuminated and causes the reflection from the road to cause the drivers eyes to constrict in response. The effect is that the drivers field of vision and distance visual sensitivity is reduced a lot, compared to the same lighting performance using lower foreground luminosity.
    Jun 15 2008
    Fairfield, CA
    What I know about light is from photography, and you can definitely have too much light.
    USP Member 110
    Dec 06 2007
    ^^post whore/smartass lol j/k Garret is kool.
    -Kirk
    Oct 23 2007
    Ontario, Canada
    don't really WANT it....was just curious.....
    doesn't sound like such a great idea anymore.
    Meet Shanice...
    For Sale:
    Oct 23 2007
    Ontario, Canada
    is this why some people run 3000k foglights (besides the look)....reduce this reflection?
    Meet Shanice...
    For Sale:
    Veteran Member Four Rings initiala4's Avatar
    Feb 24 2004
    Land of the smiles
    pleh...DOT approved...
    2019 B9 RS4 - O.CT Tuning Stage 1 | Wagner Intercooler / Radiator | Ohlins R&T DFV | 034 Motorsports Dynamic + Sway bars | 034 Motorsports Transmission mount | Ignition Projects Coilpacks | HHC Rear rotor upgrade 370mm + Endless MX72 brake pads
    Formerly - 2003 Audi B6 A4 1.8T QM, 2013 VW Passat Variant 2.0 TSI
    Aug 26 2005
    Quote Originally Posted by initiala4 View Post
    Yeah, a lot of the DOT regs are antiquated and irrelevant, and just don't mean much anymore. The ECE regs are much more current.
    One confounding US rule, is that ECE lighting is not legal, regardless of the fact that the ECU lighting specs are technically superior to the US specs. Go figure.
    BTW, there is no "DOT Aproved" lighting, DOT does not provide approvals. That is the manufacturers job, to submit only lighting that conforms to the existing regs. and requirements.
    Aug 26 2005
    I can't say, other than when used to help cut reflection from snow or fog, I don't know of any reason to run with the yellow fog lamps on.
    Oct 23 2007
    Ontario, Canada
    Thnanks diagnosticator.
    and thanks to eveyone else who had helpful inpuit. guess i'm going OEM everything.
    Meet Shanice...
    For Sale:
    Veteran Member Four Rings A4 KiDD 810's Avatar
    Aug 25 2007
    B6 S4
    Westchester, New York
    There's a groupbuy going on right now for HID fogs but I think Alex@GMS will do headlights too, and I just ordered some from DDMtuning.com. Someone in the B7 thread recommended them, said they're real popular with the BMW forums. They are really good priced ($110 shipped), new generation balasts, lifetime warranty and 35 or 55 watt HIDs in alot of color ranges, and plug and play.
    -Nick
    -2004 Brilliant Red S4 6Spd - Thermal R&D Catback, FK Coils, Piggie pipes, JHM Tune
    -2002 Brilliant Black 1.8T 5Spd - (traded in) Gone but never forgotten
    Veteran Member Four Rings Tgr_Clw's Avatar
    Jul 20 2005
    2003 Audi A4 1.8TQM
    Toronto, Canada
    That's the proper way to do it.
    Appearance: OEM+
    Interior: B6 S4 Recaro Seats
    Performance: MTM Stage 3 / Milltek Exhaust+Milltek HFC / JJ TIP / ASP FMIC / SB FE SS
    Suspension: Vogtland Coilovers / HSport S4 Sways
    Braking: Stoptech 332 BBK
    Wheels/Tires: BBS CH 18x8.5, ET35 / GY Eagle F1 GSD3 235/40/18
    Jun 15 2008
    Fairfield, CA
    Quote Originally Posted by AudiA4Turbo22 View Post
    Yep, we are birds of a feather, Kirk...we are both post whores, it keeps my work day flowing! LOL
    USP Member 110
