Results 1 to 8 of 8
    May 21 2007
    Nashua, NH
    Brakes Questions!!
    Hello,
    I need to replace the front rotors and pads on my 2000 S4. The problem is I have no idea what to do with this brake set up. I've done hundreds of brake jobs but don't know where to start with this job. Can someone please post a step by step for replacing rotors. Searched and can't find what I'm looking for.
    Also the connector for the sensored pad was cut off (wires showing). The pads I'm putting in aren't sensored but I was wondering how to disable this so I don't have my brake light on anymore. Any ideas? Thanks
    Veteran Member Three Rings Rajan147's Avatar
    Nov 23 2007
    Columbus, OH
    Re: Brakes Questions!!
    http://www.audiworld.com/tech/wheel39.shtml
    that should get you started.
    B5 S4 AWE Stage 3 - sold
    May 21 2007
    Nashua, NH
    Yea that covers the pads but not the rotors. How do I take apart the caliper and stuff holding the rotor on?
    Jan 29 2007
    08 S4 00 S4
    MD
    Quote Originally Posted by Grinster24 View Post
    Take out the caliper bolts
    Senior Member Three Rings jakecro's Avatar
    Feb 08 2007
    '00 S4 6MT 324K mi stock K03s
    Pittsburgh
    There are two 22mm bolts securing the caliper to the knuckle. They will more than likely be tight so be sure to use lots of PB Blaster (also pre-soaking where the disc meets the hub). Once the caliper is out of the way, get out a hammer and start beating on the disc since it will prob be seized to the hub.
    -Jake
    [email protected]
    www.audidatabase.com <--feel free to contribute material
    new siggy
    710Ns|CC|VDO Vent Boost Gauge|Piggies|LW Crank Pulley|034 Snub|Hawk HPS|K&N|Continental ExtremeContact DW
    Jan 29 2007
    08 S4 00 S4
    MD
    Quote Originally Posted by jakecro View Post
    I'm pretty sure they are 18mm bolts
    Veteran Member Four Rings S4_NE's Avatar
    Aug 07 2008
    just my two S4's
    Fairfield County CT
    They are 18 mil. IMO the best and easy way to get them off is to hit them with the inpact gun, it took me about 1 hour for left and right pads and rotor swap out, also I tq the bolts back into place with 90 foot pounds of TQ , it helps to put anti sze on the bolts as well. this is how i did mine hop,e it helps you out
    2001 S4 TIP STG 3 EPL tune,517 trans shop, and Stuff
    1998 Jeep Grand Cherokee , beater/off road rig (pending lift WIP)
    2001 S4 Avant TIP Sold to a good home
    Turbo's are the Perfect Drug
    Veteran Member Four Rings Rated S's Avatar
    Apr 02 2007
    '01 S4 '94 D21
    Studio City, CA
    Make sure you have a rubber mallet to beat the crap out of the rotor to make it unsieze from the hub.
    SoCalS4.com/Repair - For All Your Delicious B5 S4 Tuning/DIY Needs
    Don't like me? Feel free to email me and tell me all about it - [email protected]
