Results 1 to 27 of 27
    Veteran Member Three Rings TheHeggi's Avatar
    Aug 03 2008
    05.5 2.0t A4 + 02 CBR600 F4i
    Redlands, CA
    Climate control off, hot air coming from engine bay
    So basically like it says. If I have the climate control turned "off", after a while I can feel the heat coming in the cabin from the engine bay, by my legs. It actually builds up and gets pretty damn hot in there, even with the windows down. I know it's probably a simple fix, but it's annoying and I can't figure out how to drive with the windows down and not have to run the a/c. Drives a man crazy I tell ya....so what's the fix peoples?
    05.5 DG 2.0TM FWD
    [Stasis SS][RS4 Rear Sway][APR 91][AEM intake][034 HFC][podi/stepper boost gauge][Satin Black B6 USPs][S-Line front bumper][RS4 Grille][Satin Black S4 blades][DIY Ti vinyl][DEPO projectors w/6000k]
    Veteran Member Three Rings jdubbs119's Avatar
    Sep 30 2007
    California, l.a., the valleyyy
    Re: Climate control off, hot air coming from engine bay
    Quote Originally Posted by TheHeggi View Post
    ill help you, you use a finger or two and push the window button down, wait till they go down, then apply foot to brake if automatic and put into drive, and their you are
    Aug 03 2008
    Redlands, CA
    So I waited up for this? A cheesy edit of my text, a 3rd grade how-to, and an incorrect useage of "their"?! Really?! Seriously?! Thanks.
    Unfortunately, I have a 6 spd, so if you can modify the directions accordingly, I'd really appreciate it. Oh and try to hurry, the car's running...and it's getting hot
    05.5 DG 2.0TM FWD
    Registered Member Four Rings
    Jun 14 2007
    2007 A4 2.0T QM 2008 A8L
    New York
    LOL
    I agree I sometimes get a little hot around my legs on a hot sunny day with the windows down. All I know is my replacement for the A4 MUST have ventilated seats.
    Apr 18 2008
    Jacksonville, FL
    i notice it even when i'm driving with the windows down. it seems to come from just below the steering column.
    2011 Toyota Tacoma Double Cab SR5
    SOLD 10/2011
    2008 A4 Avant 2.0TQ Tip in Quartz Grey
    APR Stg 1; RS4 Rear Sway; 034 Turbo Inlet Pipe; 35% tint; 640 SWITCH mod; GROM-I2-VAGD + Proclip
    Apostrophes: how to use them Baby Jesus cries when you misuse apostrophes.
    Senior Member Three Rings rayiish's Avatar
    Feb 03 2008
    Brooklyn, NY
    I just noticed this a couple of days ago. It got really hot and I thought my engine was overheating or something.
    Ray
    2006 Audi 2.0T Quattro w/ Tiptronic -Dolphin gray | APR 93 | RS4 Rearsway bar | Tinted head lights/tail lights/side reflectors | Bulbs changed | Clear Corner
    Nov 16 2007
    Westerly//Providence
    sounds dumb, but do you have the climate control set to hot air before you turn it off? i find that if you set it to hot before u turn it off hot air disburses from the vents and if its cold then cold air comes threw the vents.
    Aug 03 2008
    Redlands, CA
    Quote Originally Posted by CoreyRandmetz View Post
    Nah man, it's triple digits daily out here right now, I wouldn't dare test the heat I have it set at a synced 70. It's mostly noticeable at night though. Maybe because it matches the heat during the day so I can't really feel it...so now we've got multiple members confirming but no fix? What the deuce? There's gotta be an obvious fix
    05.5 DG 2.0TM FWD
    Veteran Member Four Rings eMacPaul's Avatar
    Jul 26 2008
    Marysville, WA
    Same here... if the top's down, I have the A/C off, and I get hot air over my feet. I know when A/C is on you can control which vents (top, middle, bottom) it comes though, so it seems it should be possible to shut off the lower ones regardless.
    2007 A4 2.0T CVT Cabriolet S-Line Phantom Black
    APR, K&N air filter, Podi boost gauge, chrome-stripped grille, RS4 RSB
    Smoked side reflectors & markers, smartTOP, Eibach Pro-Kit, 12F/15R spacers, ER SMIC
    Xenon match DRLs, LED fogs, city w/ fogs, S4 mirrors, red LED interior, CC, 034 HFC + Magnaflow 14829
    Awaiting Confirmation Four Rings
    Feb 29 2008
    2006 A4 2.0T Quattro, Dolphin
    San Francisco Bay Area
    One thing I didn't realize at first (only had my A4 for a handful of months) is the climate control does not blow air according to the temp.setting, it actually adjusts to the outside temp. If it's 100 out, and you have it set to 75, it will blow cold. If it's 68 out and you set it to 75, it will blow hot. It's pretty obvious, I know, but sometimes cars use temp. numbers that people associate w/ cold as opposed to actually trying to match the interior temperature to the number setting.
    Given you set it to 70 and its triple-digits out, I doubt this is a problem, but perhaps your external thermometer is having a problem?? Maybe it got busted and thinks its cold out....heat can mess with pretty much anything electronic.
    Veteran Member Four Rings Slo.Mo.Shun.'s Avatar
    Oct 14 2006
    MK6 Jetta
    South,FL
    The hot air coming from the engine bay is normal, all B7s do it.
    -Unitronics Stage 2+ ECU/TCU tune.
    -EI AL CAI.
    -Driver Mod.
    Established Member Two Rings Zonacat's Avatar
    Jul 24 2008
    La Jolla
    Hmmm, triple digits? Why not just run your A/C? Use it or lose it.
    I run my A/C nearly 100% of the time.
    My fix, run the AC.
    2008 A4 Avant, 2.0T Quattro 6MT, Ibis White, S-Line, Titanium, APR 91, BMC Filter... more coming
    Veteran Member Four Rings airbornerifleman's Avatar
    May 20 2008
    2013 Passat TDI
    Toronto Ontario, Canada
    I noticed the same thing in my car. It seems to me that the A4s don’t have a "flow through" ventilation system. What I mean by flow through is like what I had on my Jetta MKV, you turn your fan to off and change you temp setting to hot/cold (out side air not a/c) and drive at a good rate of speed, air will actually come through the main vents and if you crack one of your windows you feel even more air flow. In the winter I hardly used the blower fan. I just turned the temp knob to hot and the air in front of the car came through the vents heated. I’m guessing that the heat we are feeling by our legs is the heat coming from the engine through firewall.
    Aug 03 2008
    Redlands, CA
    Quote Originally Posted by Zonacat View Post
    My fix, run the AC.
    Haha, if only it were that simple. Trust me, I use the A/C during the day, but I like to cruise with the windows down at night or whenever its below 90 at least. I love the feeling of the open air, it doesn't feel like you're in your own quiet, secluded world. I hate that feeling. I usually have the windows down from light sprinkle to below 90 degrees.
    So its common and it doesn't bug anyone else? Seems kinda crazy to me. It's not just a little hot air, it gets pretty warm down there. I know what recirculation thing you're talking about. In my last car if the lever was in outside air-in position, air would creep in even with the system off, but if you switched it to only inner recirc, it would cut that off. We don't seem to have that option...maybe they just figure old people drive these things and use the climate control 24/7, kinda like why we have a tape deck in a car produced after 1995 I'm bustin out the Top Gun soundtrack this weekend with the windows down, everybody's gonna know I'm on the highway to the danger zone!
    05.5 DG 2.0TM FWD
    Veteran Member Four Rings akasch's Avatar
    Jan 30 2008
    Santa Clara, CA
    why don't you just run the a/c while the windows are down? Its not that big of deal..
    May 20 2008
    2013 Passat TDI
    Quote Originally Posted by akasch View Post
    thats out of it
    Veteran Member Three Rings Kid Red's Avatar
    Feb 05 2008
    Orlando, FL
    Quote Originally Posted by HID View Post
    All my cars did it. The vents are open so air will get in and come out the bottom. I don't think the issue is unique to Audi, I think it's an indicator that the vent system does not really open or close, it just blows air of different temps maybe?
    2010 BMW 335i Sapphire Black + Black leather interior + Sport + Nav + PDC. Mods - Carbon Fiber wrapped interior - Gloss Black grill - 15% tint - more coming
    2006 A4 2.0T Quartz Grey + Black leather interior + Convenience. Mods - 19" VM RS4 reps - FK Silverline coilovers - APR 93 - Navigation - S4 mirror caps - S-Line E-Codes/Bi-Xenons - XenonMatch Hoen Fogs - RS4 sport pedals - LED License plate lights - black grill - 15% tint all around & More mods coming.
    Aug 03 2008
    Redlands, CA
    There's been a way to block it off in all of my cars, you just have to close the ventilation system from outside air, but those were all manual controls...I thought there would be a simple fix, but I guess I'll really dig into it myself and figure out a way, there has to be a way! If I find a way, I'll be sure to post it.
    As for running the A/C with the windows down, I tried that and it feels weird getting differentiating whirls of cold and warm air. Plus my mommy said I can get sick that way... Not to mention, the A/C eats up some extra gas and power unless WOT/plaid speed is engaged, and clutch engagement off idle is a little trickier (bog or overreving are both easy to accomplish).
    05.5 DG 2.0TM FWD
    Veteran Member Three Rings Alkemix's Avatar
    Apr 23 2008
    2019 Lexus NX (wifes)
    You all forget that we are running turbocharged cars. I'm sure we've all seen a youtube video of some yeehaw rednecks turning their trubo inlet into a jet or running it red hot. Our turbos get pretty close to red hot and create a LOT of heat. Heatsoak being a major performance issue in our cars. I too feel that same heat radiating from my leg room area... first thing i thought of was the turbo. Am i wrong?
    Gone:
    2008 2.0T Quattro 6 MT Dolphin Grey / APR 91 / APR Catback / APR Intake / Sway Bars
    2013 S4 S-Tronic Black / Magnaflow / USS / STOCK
    Aug 03 2008
    Redlands, CA
    Quote Originally Posted by Alkemix View Post
    I think you are. If that was the case, by your logic, every turbo car would build up excessive heat in the cabin. Frequent rides in my friend's WRX have convinced me otherwise. I think it's the lower ventilation system not closing entirely since no air/heat is felt through the top vents and hope it's not just improper/ill designed insulation from the bay to the cabin..
    05.5 DG 2.0TM FWD
    Apr 23 2008
    Am i wrong? - me
    I think you are. -you
    Alright f**k*r, Lets fight!
    Jk... Don't mind me... I'm hopelessly vulgar and sarcastic. You're probably right though because the open window in everybody's scenario def. creates the necessary drop in cabin pressure for your theory. You're my hero you big sexy. Anyways, I kinda like the heat. When i wear flip flops, the warm air caresses the hairs on my feet. Anybody else get that too?
    Gone:
    Veteran Member Four Rings a4dc89's Avatar
    Nov 07 2007
    Land Rover Disco I
    Washington DC
    I think this is normal for any car..
    2006 A4 B7 2.0TQ Dolphin Gray Metallic 6MT
    REVO Stage II, 034 HFC, AEM turbo inlet/intake, OEM Piston DV, BSH PCV Fix, HID Fogs/Fog Mod, AWE Boost Gauge, Debadge
    All go no show
    Aug 03 2008
    Redlands, CA
    LOL, I wouldn't mind the heat either, but when it's ~85 degress at night, I'm trying to cruise with the windows down to get some fresh air because at that point it doesn't feel too bad. But that extra air turns the heat up a notch, and it gets a little clammy = no bueno. Then I must go faster to bring in cooler air, it's a viciuos cycle...so when I get pulled over for 100 in a 35, I'll just say "sorry occifer, it's HOT in here!"
    It's normal to an extent, but you should be able to shut the vents, thats the abnormal part. I'm sure I'll get used to it, or when winter comes around it'll be ok, but when I take my car in to Das Stealership for the damn regulator on the pass front window that sounds like it's grinding glass, I'll be sure to ask someone
    05.5 DG 2.0TM FWD
    Feb 29 2008
    I dunno what to say, other than I don't notice this heat you all speak of...it could just be my Arizona blood....did I get a special one?!?!
    Veteran Member Four Rings aaronz's Avatar
    Jun 10 2008
    Spiders
    Chicago And NJ
    I am in the same damn boat. Just noticed it today especially when driving back from the lake. 85 degrees outside and I was in shorts. My damn legs were sweating! I was told before this is normal but I don't see how it getting that hot can be normal! Just doesn't make sense at all. I even took a picture of what I thought was the issue and everyone that responded said that it is normal..... something is not right. Do a search for hot foot well and you can find my pictures.
    2016 TTS Launch Edition
    SOLD!!! 2013 S4 DSG Build Thread
    VAG-COM equipped if you need help
    Aug 03 2008
    Redlands, CA
    Quote Originally Posted by aaronz View Post
    I'll have to check that out, thanks! I still need to take her in for the passenger front window regulator, so I'm gonna run it past them too.
    05.5 DG 2.0TM FWD
    Jun 10 2008
    Spiders
    Chicago And NJ
    anything?
