Results 1 to 8 of 8
    Established Member Two Rings audi4u2nv's Avatar
    Apr 15 2007
    2002 a4
    bayside, new york
    Question Helpppppp What Can I Do About These Codes??????????
    PLEASE HELP..i have a 2002 audi a4 3.0 quattro....ive been having some a/c problems...(not frion)..today i scanned my car for to see whatsup...the codes that came up were..
    00819 - High pressure sensor
    16825 - Evaporative emissions control system incorrect purge flow
    16840 - pinhole leak detected in tank ventalation system
    18036 - powertrain databus missing message from steering angle sensor
    18043 - databus drivetrain missing message from a/c module
    how can i exactly resolve each one of these?
    oh and if it helps i cleared the codes..then drove exactly 18 miles and the CEL came back on..
    if your in queens new york..and you can definitly help me out..ill pay you..
    outt1e
    2002 audi a4 3.0 Quattro
    magnaflows | 15% tints | tein supersport | k&n air filter | debaged | HID's in fog's | trunk lip |
    Veteran Member Four Rings G Men 08's Avatar
    Feb 05 2008
    One trick pony at the time.
    Waterloo NY
    Re: Helpppppp What Can I Do About These Codes??????????
    omg that seems like a headache!!! hopefully its not as bad as it seems!! good luck man
    B6 A4 3.0-sold
    C5 A6 4.2-sold
    C4 A6 2.8-sold
    B5 S4 A few mods-SOLD thankfully!!
    MKIV Golf TDI- SOLD MPG were amazing but other than that...
    C5 allroad 2.7 auto
    Apr 15 2007
    2002 a4
    bayside, new york
    it is a headache..do any of these look familiar? and if they do..what did you do about them?
    outt1e
    Veteran Member Four Rings downhillracer's Avatar
    Aug 20 2007
    97 Jeep Wrangler
    Costa Mesa / Mammoth Lakes
    wow thats a lot of codes. well i would say you have an EVAP problem, check the evap lines for a leak, also look at all of your ground straps, if any of them are dirty or corroded painted etc clean them, dirty or missing grounds can cause all kinds of problems!
    Apr 15 2007
    2002 a4
    bayside, new york
    yeahh its too many...i dont know where to start
    outt1e
    Jan 07 2008
    04 A4 1.8tqm
    Montreal, Canada
    read old guy's post#5:
    http://www.audizine.com/forum/showth...ht=evap+system
    16825:
    Ok so usualy the N-80 or a bad non return valve would be the problem. Here's a picture of the N-80 (left) and a non-return valve (in red). They are located near the air intake.
    N-80 (left): with the car off, unplug the N-80 harness and with a multimeter take the resistance (ohms) on the valve. If the coil is good you should get ~30ohms if the resistance is a lot higher the N-80 is faulty. If the resistance is ok, take the N-80 off and inspect it chances are it's clogged. When you start your car the N-80 should start clicking.
    Non return valve (red): The valve should only circulated in one direction. So take it off and see if air could go in both direction. Be sure to reinstall the valve in the right direction.
    16840:
    -be sure the fuel cap is tight enough.
    -small leak in the evap system. Either try to find it or may want the stealership to pressure test the system.
    Hope it helps
    Apr 15 2007
    2002 a4
    bayside, new york
    yeah....i tried that..that doesnt work..im going to change my gas cap..alot of people told me that my gas cap could be the problem..i smoked the car out..to pin point the leak..nothing was found..from both the front of the car and the bottom of the car..
    outt1e
    Apr 15 2007
    2002 a4
    bayside, new york
    ANYONE?!!?!?!?!?!?!?!
    outt1e
