    Jul 17 2008
    d
    adjusting ride height
    I have searched this but didnt really get an answer.. I installed my coils yesterday and the rear still has like a 3 finger gap from the wheel and the front a 1 finger gap. I want to eliminate the gap in the front and lower the back 1.5 in.
    So today I put the car on jack stands and took off the rear wheels. I tried to bring down the spring perch in the back with the spanner wrench but there is absolutely no room to turn the wrench. I do realize that I can cut the wrench but I wanted to see how others have done this. I'd rather not cut it.. Also I read that bringing the height down is easier than raising since you're uncompressing the spring.
    I really don't feel like taking the struts off the car again just to adjust the height... any help is appreciated.
    Registered Member Two Rings manufan's Avatar
    Nov 16 2007
    98 A4 2.8 QM 93 Ducati 900ss
    northern pa
    Re: adjusting ride height
    Taking them off is easier and faster
    Veteran Member Three Rings big_greasy_taco's Avatar
    Apr 28 2008
    Houston, TX
    I can adjust mine just fine with the wrench... sure space in kinda tight, but half a turn is all you need. Just be patient and do it half a turn at a time.
    Jun 04 2007
    01' A4 1.8TQM;15' Wrangler
    Austin/DFW, TX
    Did you take the wheels off?
    BetaAlphaTau Member #12
    01' A4 1.8TQMS 5spd swapped
    My 5-Speed Swap DIY
    - B6 USP
    Jul 17 2008
    d
    yes i did still tight
