Results 1 to 8 of 8
    Established Member Two Rings stilldubbin203's Avatar
    Aug 05 2007
    99.5 A4 1.8TQM
    New Haven, CT
    someone needs to help me before i burn this thing to the ground!
    ok as some of you may have seen in my previous posts ive been having some trouble since installing mt gt2871r eliminator a couple weeks ago. My throttle body would not adapt with the new ecu and new setup. During adaption if i held the metal piece on the side of the throttle body that moved during adaption and kept it from moving it would adapt, but as soon as i hit the gas it would get an error and not adapt again. Im throwing a throttle control code saying its the fault in basic settings but to matter what i do it wont adapt. When i put my ko4 ecu back in it adapted rite away but i dont know if that was just a coincidence. Im hoping my throttle body shit the bed and not the ecu which i just payed $800 for! Any insight would be awesome!!!!
    SoCo Dubs Bitch!
    99.5 A4 1.8TQM - / GT2871r elim. \ / Tapp Tuned \ /ATP High Flow Turbo Manifold \ / FMIC \ / siemens 630cc \ ATP Hard TIP \ Coolingmist/Labonte Meth injection \ Fprd Lightning Maf \ / stasis coilovers \ /StopTech Rotors + Hawk Pads \ / tyrolsport afpr \ / borla catback \ / DIY intake \ / clear corner mod \ / 8000k hid's \ / vdo center vent boost gauge \ / s4 bumper with shaved center grills \ / aem wideband \ / 18" RPM 505 Wheels \ / Forge 007\ /Turbo XS MBC \
    Veteran Member Three Rings nrowensby's Avatar
    May 04 2008
    1999 Porsche Boxster
    Columbia, SC
    Re: someone needs to help me before i burn this thing to the ground!
    My TB took a shit on me when I chipped my car as well :) Hopefully that's all it is :D
    ▄▀▄▀▄▀▄▀▄▀▄▀ B8.5 Squad ▄▀▄▀▄▀▄▀▄▀▄▀
    2014 Audi A4 - Stg2 - Monsoon Gray Metallic
    2015 Audi A4 - S-Line - Ibis White
    Aug 05 2007
    99.5 A4 1.8TQM
    New Haven, CT
    well your word are encouraging, but it worked when i out the ko4 ecu back in so i cant figure it out. THIS SUCKS!
    SoCo Dubs Bitch!
    Established Member Two Rings ricebeater's Avatar
    Mar 02 2008
    98 a4 1.8TQM
    Malvern, PA
    Quote Originally Posted by stilldubbin203 View Post
    What tune did you go with? Mika or Uni?
    1998 black 1.8t A4 QUATTRO
    MODS:S4 front bumper:S4 gauge cluster:S4 seats:S4 Grill:VDO boost gauge:Forge SMIC:Neuspeed Exhaust:Forge Spltr DV:18"x8" ADRs:
    Coming Soon: AWE DTS, A/F and OP Gauges, two tone paint job, lowering springs and more...
    Aug 05 2007
    99.5 A4 1.8TQM
    New Haven, CT
    neither, chris tapp
    SoCo Dubs Bitch!
    Mar 02 2008
    98 a4 1.8TQM
    Malvern, PA
    It could be the tune?!?! Try swapping out your TB with someone elses or try another tune.
    Established Member Two Rings VTECCURED's Avatar
    Nov 07 2007
    98 audi a4 quattro
    PERTH AMBOY, NJ
    same issue with my CTapp tune...
    it seems that everytime i try to adapt the TB.. i get a DTC for "error in basic..."
    i was at one point able to adapt after taking it apart and cleaning the connections and the trac inside...
    But shortly after, im not able to adapt again.
    I havent tried to adapt for months now.. car runs fine, no problem at all.
    It seems like a software issue.. but ill let you know as soon as i get my upgraded TB.
    Let me know if you find anything out about this issue!
    thanks,
    john
    May 04 2008
    Columbia, SC
    Mine did the same thing... When I put the stock ECU back in, it would adapt and run, but the new ECU wouldn't... Changed the TB and it worked fine, with both ECU's
