Results 1 to 40 of 63
    Veteran Member Four Rings quattro16's Avatar
    Feb 05 2007
    Long Island, NY
    Car WAS running awsome!!!Pics!!!!
    Until a slight exhaust leak became louder then mil then no power on the way into work one day. Got the car up on the lift and found the entire t3 flange cracked all the way around the merge collector. Got the turbo off and found it has completely broken off and cracked the flex pipe for the wastegate also!
    Well I contacted 034 and they said to send it in and they will fix it. Looks like something is causing to much stress on that area. But I don't want to have the car down for another 3 weeks as summer is about to end. So I will have a local wled back up and go from there.
    BetaAlphaTauMember #17
    20 Year Audi Master Guild Technician
    Long Island, NY. Instagram @andyaudiman
    Oct 30 2006
    B8 A4 Avant 6spd
    Re: Car WAS running awsome!!!Pics!!!!
    Do you have a flex pipe on the rest of the exhaust?
    -18 718 GTS
    Feb 05 2007
    Long Island, NY
    Yes sir, 3 inch flex bellow right after the dp and the dp is also attached to the spring bracket on the trans.
    97 A4 2.0TQM
    Rochester, NY
    did you have a brace on the turbo?
    Feb 27 2005
    North Wales, PA
    definitely have a brace made for the turbo
    Senior Member Three Rings bernB5's Avatar
    Nov 13 2007
    Long Island, NY/ Hartford, CT
    or, be smart and run a cast manifold :) spa ftw
    Old: 97 30r'd A4 ---> headaches
    New: Evo IX MR ---> 354awhp/349tq and couldn't be happier
    BERNSTEINphotography
    Veteran Member Four Rings pipe7284's Avatar
    Sep 14 2006
    `07 Audi A4 S-Line 6MT Quattro | '01 Audi S4 AVANT 6spd
    Lansing, MI
    waw thats bad news for 034
    '01 Audi S4 6spd Black AVANT DAZ E85 Tune Frankenturbo F21s / 034 RS4 inlets / BOSCH EV4 72# injectors / Walbro 450L fuel pump / Daz 89mm maf housing / AFE Intake Cone / SRM SMICs / 034 street density trans and motor mounts / SSAC downpipes / Vibrant catback exhaust / H&R Ultra Low Coilovers / 18x9.5 Rota Grids / 17z Brembo front BBK / 034 Rear BBK / JHM Short shifter / JHM stg 3 clutch / PODI Boost gauge / [/CENTER]
    SOLD
    Veteran Member Four Rings JumboBlack1.8's Avatar
    Sep 16 2006
    '98 528i
    Boston/West Hartford, CT
    Those don't look like good welds at all.....thats too bad, especially since that manifold is nearly $1k......haven't you been havin several problems with this manifold since u bought it??
    2000 Audi B5 S6 ** 4.2L 40v S6 6spd - http://www.audizine.com/forum/showth...n-s6-4-2L-swap
    Jan 25 2006
    A4 2.0T
    MD
    That really sucks.
    Veteran Member Four Rings boostedup's Avatar
    Sep 01 2005
    01 a4 1.8T,00 suzuki GSXR 600, 1974 Mako 171
    internationally known, Florida
    WOW........that looks scary.
    Santorin Blue 2001.5 Audi A4 1.8turbo Quattro with Sports, Celebration, Cold Weather Packages.
    Engine:APR 93 octane. Catch Can. Air Intake/Heatsheild. 710N .
    Interior:VDO Vent Boost gauge. Short Shift. Garmin GPS. 2-10" subs. Suede interior
    Exterior:19" ASA St4's/NITTO rubber. Neuspeed Race/Bilstein Sport shocks. 15% tint. Debadge. Clear Corners. 4300K HID. MS Design Front lip
    Established Member Two Rings STASIK A4's Avatar
    Sep 28 2004
    Audi A4 1.8 Turbo Quattro
    Melbourne Australia
    So is this their race manifold made from stainless????
    "I don't intend to grow up there's no future in it"
    96 B5 A4 Quattro
    2.0l GT25 440HP powered by Autronic SM2 with CDI 750cc injectors Walbro intank Bosch 044 external fuel pumps
    B5 S4 6Spd Drive train, Porsche 996 Front brakes over S4 rotors, PWR Custom FMIC, PWR Custom Power Steering Cooler, PWR Custom Gear Box Cooler, Tilton Gear Box Cooler Pump Ect.....
    Drive Fast Drive Safe Never ending Modding
    Veteran Member Three Rings big_greasy_taco's Avatar
    Apr 28 2008
    Houston, TX
    Sorry to hear that man... hope you get it squared away fast. However, those welds look terrible. There are many joints that have almolst no penetration. I can see why it broke. I could probably weld it up better than that, and I am a terrible welder!
    Feb 05 2007
    Long Island, NY
    Yes once I get it all back together I will definatly be making a brace for the turbo to the head. Just curious anyone have any pics they could post up to get some ideas? Yeah I have had several problems but they have been fixed them and just took a long long time. I'm not gonna bash any companys on here, but the pics speak for themselves! They should've made a new header when the first problem arised!
    Veteran Member Three Rings JaVa's Avatar
    Jan 07 2007
    01 A4 2.8, 85 Yota, Isuzu
    there is no penetration on the welds.....
    NWQuattro - NorthWest Audi Group
    ----01 A4 2.8 QS Tip |GIAC|Zapco|Alpine|Dension|Tint|
    Jul 07 2004
    630AWHP A4, Nissan Titan
    socal
    Quote Originally Posted by quattro16 View Post
    I used to run a brace on my old DSR manifold, but even with the brace it only lasted a month or 2. Have never found a need to use one on the full-race manifolds. You can try searching for some posts from Tom, he runs a brace on his turbos.
    Even with a brace the welds can break because there are just so many different pieces of metal that can expand in different directions.
    Aug 21 2008
    Minneapolis
    Man that too bad....
    Active Member Four Rings bassed's Avatar
    Sep 24 2005
    always in design
    Quote Originally Posted by bernB5 View Post
    I second that. Glad I was the giuny pig with it:) have 8+k on it now not one issue!
    Veteran Member Four Rings fred2ka4's Avatar
    Nov 26 2005
    Audi A4, Honda Pilot
    NM
    I would send the bill to 034 for the welding repair. Either that or have them send you a new manifold express mail and you send them the broken one back once you receive it as you should not have to foot the bill for the repair and the down time.
    BetaAlphaTau member #18
    2000 Audi A4 w/ APR stage III & ...
    APR // GReddy // RACETEC // Bilstein // IForged // ECS Tuning // STaSIS // Neuspeed // H&R //
    And a whole bunch of other stuff ...
    http://i78.photobucket.com/albums/j9...4/fredscar.jpg
    Veteran Member Four Rings UN-PIMP-Z-A4's Avatar
    Jan 29 2007
    MR VTEC Lives...
    Yes We Can!!! Obama N Beyond!
    Quote Originally Posted by fred2ka4 View Post
    that seems the most logical.
    If they express it that would be a courtesy but they should send you a new one then you send them the replacement.
    Homebrew PES Powered Stage 3 A4 1.8TQM It can be yours for only $5k PM for details
    I have a JUSTINTERCOOLER 27 X 6 X 2.75 WITH 2.5" inlet / outlet (Brand New in Box) FMIC for Sale $90
    QUOTE OF THE YEAR:
    "Another thing, dont go flashing 15 second timeslips!"
    Sep 24 2005
    always in design
    Quote Originally Posted by UN-PIMP-Z-A4 View Post
    Considering how many people have had issues now, I'd say.
    Apr 05 2007
    Bend
    I say just ask for a refund and listen to bassed and bernb5.
    My B5's For Sale PM ME!
    UberFellas
    stanceworks.com
    ^^Superior^^
    Nov 26 2005
    NM
    I think the courtesy SHOULD be extended not only to compensate for the downtime of the car but also to take care of a customer. I have had problems with manufactures before but the way they handled the problem made me speak highly not only of their product once I received a working part but also of their customer service.
    Feb 05 2007
    Long Island, NY
    I know this is all logical to us, but this is the fifith problem with this same header and company. I guess I'm to nice of a guy to start breaking balls over the phone and wish they would just f#ckin own up for once. I just deal through emails, because I don't have time to be on the phone. As far as fabrication skills, I will never buy another product that they make in house. Every single product they made did not fit at all. Even after it was sent back and built on and actual car IT DIDN'T FIT. I had to sublet out to another shop or someone who could fix it right. And you all are right I may need a brace on the turbo, but mind you I only have 1700miles on the car and it dosen't take a f#ckin genius to look at those welds and know that shit is horrible. Guess I should've been a dick the first time it went back and wouldn't still be having problems!!!!!!! End rantttt.
    Feb 05 2007
    Long Island, NY
    Is there anyone making a DP for the spa mani? Also can you get a tial 44mm bolted on there? Thanks
    Apr 05 2007
    Bend
    time for this company to make a mani they can stand behind
    UberFellas
    stanceworks.com
    ^^Superior^^
    Veteran Member Four Rings audiness's Avatar
    Jan 26 2007
    Charleston SC
    holy chit
    Sep 24 2005
    always in design
    Nope just do a custom one it should cost about the same.
    SPA uses 38mm.
    Veteran Member Four Rings maxspeed's Avatar
    Dec 14 2005
    Shakedown street, NY
    daaaamnnn...
    2000 Audi A4 1.8TQM - RIP
    1999 Subaru Outback
    When your spirit is floating down that tunnel, towards the light, You know what's behind the light?
    It's not God, it's me. And I'm gonna kick your poncey soul All the way back down the tunnel 'till you choke on your own fucked up ribs! Now, Wake the fuck up!
    Active Member Three Rings turboquattro068's Avatar
    Mar 20 2005
    99.5 Audi A4, 99 Honda CBRf4
    Upstate, new york
    Quote Originally Posted by big_greasy_taco View Post
    +1 on that shit lol
    Nov 26 2005
    NM
    I didn't know this was the fifth time. I would send it back and demand a full refund and go wit a Full Race from Mike because this is absolute horse s**t that a company like 034 would put you through this kind of hassle. They need to be bending over backwards to make things right with you and at this point I would return it and not deal with them again.
    Jul 07 2004
    socal
    Only one for that would be the Full-race manifold and the good thing is that it just about puts your turbo in the exact same spot, plus it is welded by a robot welder.
    Veteran Member Four Rings sean1.8t's Avatar
    Sep 17 2006
    I wish I had a garage.
    SLC, UT
    ridiculous man. after this many issues with this thing i would expect a full refund and apology in writing from Javad.
    take that money to full-race. have not ever seen any of their mani's look anytihing close to as bad as that.
    even the best looking weld on that mani is not up to par with full races. it's sad
    Current:
    '16 Mercedes-Benz C450 "AMG": Stage 2 w/downpipes & 19" BBS CH-R's
    '88 Harley-Davidson Sporty 880: 1200 bottom - Ported & Cam'd top - S&S In - Screamin' Eagle Out
    Previous:
    '02 Audi A4 1.8TQM: Full GT28RS on meth w/everything else.
    '01.5 Audi A4 1.8TQMS: Tune and exhaust.
    '99 Subaru Legacy Outback wagon Manual: Bone stock.
    I don't even want to remember the others
    Jan 29 2007
    MR VTEC Lives...
    Wow we didnt even give 034 a chance to rectify the situation before the mobb bashes their teeth in...
    Hopefully 034 will take care of him and they can come to terms.
    It's unfortunate that it happened especially after such a short period of time . As for down time with a modified b5 it should somewhat be expected. Just as you get excited by playing with your toy something happens a boost leak or something breaks.
    Give 034 a chance to do the right thing.
    We are to quick to bandwagon and even quicker to burn at the stakes...
    my 2 cents...
    QUOTE OF THE YEAR:
    Sep 17 2006
    SLC, UT
    my 2 cents...
    search his build threads man.
    he has already had to send this very manifold back to 034 multiple times and has had to extend his original build over a month due to this.
    if this was the first time, it wouldn't be that big of a deal. this is what warranties are for. but this has crossed the line IMO
    Current:
    Previous:
    Sep 24 2005
    always in design
    my 2 cents...
    Joo been under a rock mang?
    Mar 17 2006
    00 A4, 49 Ford p/u,
    Vibrant Performance
    traditional hanger that you can pre-load.
    Feb 05 2007
    Long Island, NY
    I see now. Didn't think those little 10mm holes would be strong enogh to bolt to, but I guess not.
    Mar 17 2006
    00 A4, 49 Ford p/u,
    Vibrant Performance
    Yes its actually the tensioner (m8x1.25) that takes all the weight. It lifts the turbo up or down. Its one of the old heat sheild bosses in the head.
    Mar 09 2004
    99.5 A4 Avant, 01 allroad
    nw michigan.
    I'd exchange it with 034 for a SPA manifold and downpipe. The troubles you've had with that manifold are ridiculous especially considering a turbo wouldn't even fit on it the first time around.
    If you had to get a rental car at 30 bucks a day for every day that manifold cost you then a full reimbursement would maybe break even.
    Jim
    I Do Werk.
    Mar 09 2004
    nw michigan.
    Is that a 'filter in a box' or a plenum with a filter on the end? Looks cool.
    Jim
    I Do Werk.
