Results 1 to 28 of 28
    Registered Member Two Rings one2gamble's Avatar
    1965 Mustang, 01.5 S4 6spd
    Monterey,CA
    Aux Water Pump -
    Im assuming the big puddle of water in the middle of my engine block is from the Aux Water Pump?
    I dont have anywhere to do the swap myself so does anyone know how much this would usually run at the stealership?
    Veteran Member Three Rings MiniRS4's Avatar
    Aug 11 2005
    Re: Aux Water Pump -
    dont replace it.
    DELETE IT! just get an extension or get a hose long enough to make it to both ends.
    Monterey,CA
    I still have to rip off the top of the motor to do it though correct?
    Aug 11 2005
    Quote Originally Posted by one2gamble View Post
    yea, im pretty sure the intake mani has to come off. but you maybe be able to do it w/o removing it. after disconnecting, pull it our the back, by the firewall.
    -G
    Feb 17 2004
    Sterling, VA
    Quote Originally Posted by MiniRS4 View Post
    dont replace it.
    Geno, you should not delete it. The reason it is there is to pull boiling coolant from the CHRAs when you shut the car off and pull it up to the coolant tank to allow the gas bubbles to re-condense.
    You should buy the OEM relocation kit and move it to the from of the motor right above the alternator. This way, should it ever leak again, it's a 30min job to replace.
    Brett - Moderator
    Issue?: email me.
    _____________________
    Stage 3 2004 A6 2.7T 6M
    Jan 29 2007
    08 S4 00 S4
    MD
    It can be done with the manifold in place, though it's not easy to do.
    Aug 11 2005
    Quote Originally Posted by Daft View Post
    you have a very valid point, but the remedy is letting the car idle longer before you pull the key. in my case, i just let the car sit and cool via turbo timer. also, unless you run the car really really hard n shut it down right away, it shouldnt be an issue, no?
    my 2 cents.
    Feb 17 2004
    Sterling, VA
    According to the 2.7T self-study guide, the pump is meant to pull coolant in a backwards flow through the CHRAs and cylinder head to ensure that any vapour bubble actually do make it out of the cooling sleeves. I'm assuming here that even the normal flow of coolant (that flow being from the actual water pump) isn't capable of drawing these vapour bubbles out properly and thus the need to use a reversed flow pattern.
    It also says that the Aux pump coolant sensor will activate the pump any time the coolant in the rear pipe exceeds the preset value. It also runs the fans at 40% speed at those times too.
    Brett - Moderator
    Issue?: email me.
    Senior Member Three Rings lowered97a4's Avatar
    Mar 08 2007
    08 turbo busa 09 nissan Gtr
    ct
    u can pull it right out from underneath the manifold gotta take the air pump out if u have it and some vacumme lines and couple small things
    2001 s4 stage 3
    Sanitorin Blue
    10secs4 tune
    meth injection
    JHM/AMC trans rebuild
    03 Rs6
    Wagner intercoolers carbon fiber shrouds
    Ecu/Tcu tune
    Cats Removed
    Monterey,CA
    Does this have to be sourced from Audi, I dont care for my dealer much.
    Jan 12 2008
    WV
    I just replaced my aux water pump. I called my dealership about the relocation kit. They had no idea what I was talking about. I even had a tech bulliten (found in Bently) giving them the part numbers and still had no record. My dealership SUCKS. I was unable to find the relocation kit so I just replaced it. Hope it doesn't start leaking again.
    Established Member Two Rings k_harley's Avatar
    Apr 05 2007
    2001 Audi S4 STG 3- / 2001 Passat TDI
    MA
    If you delete do you have to install resistors to keep CEL light off? Ive done this on VW's before and it never tripped one, but I know these ecu's are a lot smarter.
    Veteran Member Three Rings 2k1audiS4's Avatar
    Oct 30 2007
    Pasadena, MD
    I will aviod this thread because I am still in denial that mine is leaking.
    2001.5 S4 Silver 6MT......GIAC X, APR Bi-Pipe, FMIC, "Custom" UUC VM1, RS4 Clutch, APR R1 DV's, AWE DTS, K&N, Eibach pro kit, D3........SOLD
    2000 S4 Black 6MT.....Stock........SOLD
    2000 A6 2.7T 6MT.....Stock..... SOLD
    2001 S4 Sport Black 6MT.....Stock......SOLD
    2001.5 S4 Santorin 6MT....Stg2.....SOLD
    2001.5 S4 Sport Santorin 6MT....Stg2....SOLD
    2001 S4 Sport Silver 6MT.....Stg1....ACCIDENT THEN SOLD
    Veteran Member Three Rings VR4-S4's Avatar
    Jan 24 2008
    2013 S6, 2000 S4
    Columbus, Ohio
    I replaced mine. It sucks that you cant just buy a new gasket because thats the only thing that was wrong with my original one.
    B5 S4 - PJK04's Vast E85 Tuned
    452AWHP, 475AWTQ
    C7 S6 - RS7 Turbos Vast Tuned
    B8.5 A5 - GIAC Stage 1
    B8 A4 - Stock
    Senior Member Three Rings eliTTe's Avatar
    Arlington, VA
    you can do the job with or without removing the IM, check the FAQ, there is writeups showing both methods.
    Then: 1985 Audi coupe GT, 1990 Audi 90 sport, 2000 Audi S4 stage 2+, 2002 Audi TT 225.
    Now: 2011 Audi S4
    Nov 17 2006
    b5S4, b8.5 Allroad
    Las Vegas
    common misconception - "the aux water pump is only for cooling turbos down after running." .... hmm wrong. it circulates coolant throughout the entire engine after shutdown. VR6's are n/a and have them.
    dont delete it.
    i dont see how you could do it without removing the intake manifold.... there's barely any space
    Senior Member Three Rings samtimtom's Avatar
    Sep 28 2006
    02 Audi S4 Avant
    SB, CA
    Mine was cracked and the dealership installed a new one at the relocated position per Audi's recommendation under my extended warranty. The dealership SHOULD have a relocation kit.
    First Audi: 1981 5cyl coupe (non-quatro) Silver with Black Leather
    Second Audi: '02 S4 Avant Tip, Stock Everything, Baby Car Seat Mod. Silver with Black Leather
    Need a gift? Go to www.sbgiftbaskets.com
    May 22 2007
    East Bay, Ca
    Anyone have the part numbers for the relocation kit?
    Feb 09 2007
    00 S4
    MA
    I took mine apart and resealed it with RTV. A cheap fix but It hasnt leaked in about 5K mi so far.
    I do plan on replacing the pump eventually. just 100 bucks I would rather spend on something moar awesome. haha
    Buy tools, not labor....
    00 Audi A4, 1.8TQ avant, 6-speed swapped (from auto), s4 brakes, uprights, cluster, grill, OEM bmw style 162 wheels, slammed.
    95 BMW M3 drift car: OBD1 S52, gutted, tubed, flares, angle.
    Veteran Member Four Rings casawhites4's Avatar
    Jan 21 2007
    01.5 Silver Avant
    dc
    part numbers on relocation kit would be great.
    01.5 Stage 3 Casablanca White S4 (GONE)
    01.5 Stage 0 Silver S4 Avant (New Project, def Grocery Getter)
    watch out Casablanca!!! im coming back with a vengeance!
    Silver will be the fastest now!!! :-D
    May 18 2007
    01 Laser Red 6MT, 13 Touareg TDI
    Baytown, TX
    Veteran Member Three Rings jeffp477's Avatar
    Jun 09 2009
    1982%20porsche%20924/%2005%20VW%20Touareg%20V8/2018%20VW%20Tiguan/%2717%20Triumph%20Street%20Twin/82
    temecula,ca(socal)
    Quote Originally Posted by code7rpd View Post
    078998998 go to genuinevwvwaudiparts.com
    Veteran Member Four Rings awd2ks4's Avatar
    Aug 25 2008
    2000 S4, Blown LS2 240sx hatch, LS3 240sx vert, 02 wrx
    Santa cruz
    Quote Originally Posted by jeffp477 View Post
    anybody have a pic of the relocation kit installed?
    Veteran Member Three Rings SummitS4's Avatar
    Sep 19 2006
    2001 audi s4
    Los Gatos
    im also leaking alot of coolant. how can i tell if its the aux pump and not the main water pump? anyone have a pic?
    2001 nogaro s4 2.8 tial 770's........... 1972 Audi 100ls Bagged
    530 awhp 540 awtq on 91
    Sprint Auto Works / Becausebags
    Rotiform/Airlift
    Mar 01 2009
    manchester uk
    Sep 11 2009
    NE
    Too add to this discussion, not engough that you should not delete the pump, you should also replace temp sensor for aux pump system with 93c one so that it actually kicks in each time it is needed. The default sensor is something like 107c which is way to high for this system to trigger on all occasions it might be needed.
    I did this mod and finally I can see it working. It never kicked in for me prior to.
    Nov 30 2007
    SF Bay Area
    Quote Originally Posted by julex View Post
    I know this is an old thread but...
    Julex, I am interested in replacing my default sensor. I also do not ever hear the aux coolant pump kick in. Could you give us a little bit of info about where the sensor is located and where I could find one? Also, is there a way to test the aux coolant pump?
    Thanks so much!
    Veteran Member Four Rings 01audia4's Avatar
    Jan 31 2008
    Philly home of the cheesesteak
    Back of the coolant hard pipe passenger side. PureMS for the sensor.
    Sent from my SCH-I535 using Tapatalk
    2001 A4 2.8-->1999 a4 1.8tq 220K-->2000 K04 S4--->2001 F21 S4 eating corn w/ stock rods
