Results 1 to 2 of 2
    Veteran Member Three Rings ehfour's Avatar
    Feb 19 2005
    2002 A4 1.8T
    Vancouver
    Best way to remove overspray?
    Just need to find out the best way to remove some overspray?
    I have a Silver B6 A4 and I have some Silver overspray on my Ext B-pillar on the passenger side.
    Ive tried used some Megs Clay bar( removed a bit), if you can suggest something else?
    I can post some pics if need
    Aug 24 2008
    Pennsylvania
    Re: Best way to remove overspray?
    did u use an agressive clay bar? did u use a clay lubricant? otherwise an agressive compound would work. since it is silver the minor scratches/swirls will not show too much. also if u have a buffer, buff on the compound with a wool pad, then polish with a foam polishing pad and a swirl mark remover.
