Results 1 to 9 of 9
    Apr 10 2008
    jakarta
    (Sorry - Ask Again) Will this big brake kit fit into my B6
    Sorry,
    asking again :)
    http://cgi.ebay.com/ebaymotors/Stopt...spagenameZWDVW
    - Can i use this StopTech BBK 4 piston into my Audi b6 ? It's just plug and play or i need modify the bracket, etc ?
    - It's look like have been used by Audi A4 b5.. it has the same PCD as well as b6 ?
    - How about the Quality about this Stoptech ? any testimonial ?
    thanks.
    Veteran Member Four Rings F16HTON's Avatar
    Jul 04 2004
    992 Carrera
    Makai - Kaka'ako
    Re: (Sorry - Ask Again) Will this big brake kit fit into my B6
    Direct bolt on, decent brakes. I would be weary about purchasing used brakes from eBay. If the rotors are warped, you just lost and $$ you may have saved.
    To much anomynity with eBay.
    Veteran Member Four Rings golgo13's Avatar
    Apr 29 2007
    Tampa Bay
    They guy has 100% feedback with 100 items sold. Im sure he will answer al the questions you may have and will refund if they are messed up if you do everything right.
    SweetnLou!
    Apr 10 2008
    jakarta
    how about the prices ? it's good? how if we compare Stoptech w/ brembo brakes ?
    thanks
    Feb 19 2007
    2001 BMW 540i M-sport
    Charleston, SC
    Honestly I dont see spending all that money on just a 332mm kit. Unless you like to run smaller diameter wheels....then might as well spring for a 355mm kit.
    -Sami-
    Veteran Member Three Rings RASTA4's Avatar
    Feb 26 2005
    2002 A4 3.0
    Metro Detroit
    Direct bolt on as long as it's the right application (ie bracket fitment). You'll be limited to running wheels that are 18" or larger
    |2002 3.0 SEDAN Q6MT|POLAR WHITE|PLATINUM BUFFALINO|SPORT|CONVENIENCE|COLD|BOSE|BNS-NAV|PARKTRONIC|SUNSHADES|ODO=34XXX|
    MODS
    |PES G3 SC|SUPERSPRINT|AFE PRO-DRY|18x8 BBS RE-G FORCE SPORT|17x8 BBS RC-CONTIEXTREME|H-SPORT S4 SWAYS|AMS SS|APR SNUB|STOPTECH 332 FRONT-BREMBO X-DRILLED REAR|HAWK HPS|SS LINES|OPTIMA-REDTOP35|XENON ECODES|LED CITYLIGHTS|HOEN|SYMPHONY II+|DICE|35% SOLAR GARD|S4 DOOR FLARES|MOTUL 5.1|MOBIL 1 0W40|
    Veteran Member Four Rings Kittrell's Avatar
    May 07 2008
    B8 S5 - 4L Q7 TDI
    Broomfield, CO
    Quote Originally Posted by golgo13 View Post
    No go there chief. Ebay took it upon themselves a while back to restrict feedback from sellers to buyers. So now EVERYONE has 100% feedback. You can only leave feedback for sellers these days. I had a couple negatives from some previous asshats, and they are no longer on my list............
    Apr 10 2008
    jakarta
    FYI , my b6 running on 20 inch wheels. so it'll be good if i put these brakes on ?
    Mar 11 2008
    B7RS4 & e46Ms
    Quote Originally Posted by Kittrell View Post
    true that... they only go back a year now. eBay's done some weird things over the past couple years that seem to create even further anonymity. I liked it better in the old days, when you could really tell who the d-bags were...
