Results 1 to 21 of 21
    Registered Member Three Rings volks88's Avatar
    May 06 2007
    stg3 s4,02 C32 AMG,88 325IS
    lexington,ky/fond du lac,wi
    shouldn't my fans be coming on??
    lately when i stop in traffic or turn my car off after it gets hot the temp gauge will rise. when i start moving again it drops back to normal. from what i read in searching it never drops into the cold so i was ruling out t-stat. what i want to know is if my fans should be coming on when i turn the car off? i tought i remember them used to coming on. i noticed that they dont anymore. so yesterday i let the car idle with the ac on to run the fans and it didnt flucuate at all. tb/wp/t-stat was done like 45,xxx ago
    Oct 31 2005
    Ashburn
    Re: shouldn't my fans be coming on??
    Quote Originally Posted by volks88 View Post
    Yeah it is suppose to come on. Mine did when i had one.
    - Instagram: @Sinister_rs5-
    May 06 2007
    radiator fan switch maybe??
    May 06 2007
    oh and where is this located? thanx
    May 06 2007
    either im searching the wrong place or im an idiot. i cant find shit on this. anyone?
    Veteran Member Four Rings skunkoncrunk's Avatar
    Apr 18 2007
    2006 Subaru WRX
    Cali/Colorado
    Mine does this sometimes too.
    -Hooked on Meth-
    BOOSTADCT
    -Mike-
    Instagram: @mdundurs
    S4's Video (Watch in 1080p)
    Jan 09 2008
    01'NB'S4 sold 04 LSBlue M3
    VA
    Mine has never done this except for the time I drove through the back roads with the ac on strong. It only went up a little though.
    Sometimes when I turn the car off after a hard ride, then turn it back on a few minutes later, the temp needle is past the middle mark as well.
    May 06 2007
    Quote Originally Posted by JayyyyyC View Post
    yeah its not even after a hard drive. it has been hot but its never done this before. still maybe thinking of the fan switch but i have no idea where its at.
    Veteran Member Four Rings s2the4's Avatar
    Nov 02 2006
    01 Stage 3 S4 Silvaro, 01 S4 Avant Nogaro
    Western Mass
    fan control module might be shitting the bed if not already there. That is what tells your fan to either run or don't run. My AC fan has been constantly running for the past year due to a dead FCM. So I have the complete opposite of what you are saying.
    |MRC-Tuned Stage 3| | RS4 K04 Turbos | | RS4 Y-Pipe | | RS4 Airbox | | RS4 Fuel Pump | | 60lb Siemens injectors | | ER SMIC | | APR Bi-Pipe | | All JHM Goodies | Vogtland GT | | Porsche 993 TT Brakes | | 034 Motor & Trans Mounts|
    ...For now
    417whp @ KTR Ayer, MA 110 octane with open dumps
    clicky
    May 06 2007
    fan switch changed and no fans kicking on any way to check to see if its the fan clutch or the fan module?
    May 06 2007
    so when i turn on my ac now the fan will come on for 20 seconds and then shut off allowing the cars temp to rise a little. shouldnt it stay on the whole time the air is running?
    Jun 14 2007
    2000 S4
    Connecticut
    yeah for sure. when the AC is on your fan is on with it... maybe some sort of switch that went bad ?
    May 06 2007
    ^^ thats what i thought. if its at idle without the air on, their stopped and the temp rises. when i turn the air on, they spin for 20 or so seconds. after they stop i can turn the air off for a few seconds and then turn it back on and its the same thing, they run for 20 seconds then shut down. anyone?
    Senior Member Three Rings jakecro's Avatar
    Feb 08 2007
    '00 S4 6MT 324K mi stock K03s
    Pittsburgh
    sounds like your A/C fan is going out on you. Same thing happened to me and I just replaced the fan itself with a unit from a B5 A4 1.8t. I did have to rewire the 'new' fan since the plastic connector was different but it works fine. The replacement is the same part with just a different connector (p/n off by one letter). You could use a direct replacement but at ~$230 I opted for the used A4 unit for ~$50.
    Check out my links here for more info (at top of list)
    Hope this helps and feel free to ask more ?
    -Jake
    [email protected]
    www.audidatabase.com <--feel free to contribute material
    new siggy
    710Ns|CC|VDO Vent Boost Gauge|Piggies|LW Crank Pulley|034 Snub|Hawk HPS|K&N|Continental ExtremeContact DW
    Veteran Member Three Rings nateS4's Avatar
    Apr 25 2008
    01.5 Nogaro S4 6spd, 02 GSXR, MkIII TDI
    Baltimore
    Did you try looking @ the Thermo switch and have you tested the fans by unplugging them and giving them power? Oh and the Thermo switch is in the lower hose near the radiator.
    2001.5 S4 Nogaro Stage III
    Test Pipes|AWE Twin1|Forge Hybrid BOV/BPV|JHM MBC|VAST Tuned|FrankenTurbos|034 Mounts|Hotchkis S-bars|RS4 Grille/Knob|50w HIDs|Vogland/Bilstien|JHM SS
    02 Suzuki GSXR Telefonica Movistar
    88 Bimmer E30 Vert
    98 Jetta TDI
    90 Corrado G60 Sold!
    92 Audi 100 Sold!
    http://photobucket.com/nateS4
    Veteran Member Four Rings mrpeterparker's Avatar
    Oct 17 2007
    01 Silver B5S4
    minneapolis, mn
    RESURRECTION FROM THE DEAD.....sorry
    has there been a definite answer to this problem? I have the exact same symptoms.
    Or is there a good checklist maybe to start checking off?
    Lurker
    Veteran Member Four Rings wdbdy2000s4's Avatar
    Oct 08 2008
    1998 pathfinder, 2000 s4
    MA
    To start, you can see if there is an issue with the electronics. Use a volt meter to see if the fan motor is getting power when the AC is on, see if the FCM is getting power.
    Frimmel: i only speak when i have something negative to say.
    Grah4m: i lost to a giraffe. be careful out there.
    ThirdStrike:leave your feelings at the keyboard
    Oct 17 2007
    01 Silver B5S4
    minneapolis, mn
    works when A/C is on
    Lurker
    Oct 08 2008
    MA
    see if your FCM gets power when the car is off. Just to give you an idea of what you're looking at, here is a pick of a B3 passat fan wiring diagram. It will obviously be different but this shows how many switches/relays/fuses are used in a typical vw/audi system.
    Oct 17 2007
    01 Silver B5S4
    minneapolis, mn
    k.. i'll dig at it after work here ...
    Lurker
    Senior Member Three Rings mcjim's Avatar
    Nov 13 2006
    Atlanta
    My car did the same thing when I had a nice sized leak in my coolant after run pump. New pump, problem gone. Dont really know if its related though????
    Current: 2014 S4
    Sold: 2008 911
    Sold: B6 S4
    Sold: B5 S4
    Sold: B5 A4
